WilzGarage
Go Back   Sportbikes.net > Sportbikes > Honda Sportbikes
Honda Sportbikes CBR1100XX - Blackbird, CBR1000RR, RC51, CBR954RR, CBR929RR, CBR900RR, CBR600F Series, CBR600RR, Super Hawk, Interceptor, 919, 599
Adaptiv Technologies LLCBazzaz PerformanceJazzMotorsports.comMotorcycle.com Classifieds!HardRacing.comAdvanstarMotorcycleShowsSpringfield ArmoryChainDrain.comSuperbikeToyStore.comNice CycleSportbikeTrackGearCycleGear.comSportbikeTrackGearSee your ad here!
Old 06-05-2005, 03:14 AM   #1 (permalink)
GIXXERGUY
GIXXERGUY's Avatar
Sportbike: NONE CURRENTLY IT GOT STOLEN, XR 50 IS MY FUN FOR NOW
GIXXERGUY is on a distinguished road
Default f4i starting issue
here we go I just sold my crf50 and bought me a 01 f4i with 1266 miles on it, bank repo. bike sat for 5 or 6 months, we put a battery in it and it won't fire, don't hear the fuel pump priming up? so we spray ether in to see if it will fire, yup getting spark, runs on ether and dies after it's all gone lol.
wire the fuel pump direct with a jumper to the battery and it primes but still don't get fuel to throttle bodies to start her up.
my question is what in this bikes system will allow this thing not to get fuel and fire? could it be that the fuel pump is just weak and on the verge of taking a poo, or wut, but it still don't explain why the fuel pump didn't prime with the regular wiring on keyon, but it did when we jumped to the battery!
is there a fuel relay? fuse? I checked all fuses and they are all good. all wires plugged in, it don't have plastics on it but the gauges are there and the tip over sensor is still there and plugged in, enough fuel in tank............
I would be greatly appreciated if anyone with knowledge of this problem or these bikes information would be awesome.
P.S. if anyone has the diagnostic codes I am going to try to pull them as well.
THANKS IN ADVANCE.
Ron
WWW.M50M.COM
WWW.STUNTLIFE.COM
GIXXERGUY is offline   Reply With Quote
Old 06-05-2005, 06:52 PM   #2 (permalink)
JohnSchubert
Sportbike: 01HondaF4i
JohnSchubert is on a distinguished road
This will sound dumb, but you double checked the Engine Kill is set to off (right clip on). Is it the same if you try to push start it? I'd think with no carbs that sitting too long wouldn't be as much of an issue, but my 01 F4i is around 50k miles so it's never sat long. Did you dump and replace the fuel?
I rarely hear my pump upon turning the key, usually the instrument cluster self checking
JohnSchubert is offline   Reply With Quote
Old 06-06-2005, 03:37 AM   #3 (permalink)
skater_107
skater_107's Avatar
Sportbike: 2002 cbr F4i
skater_107 is on a distinguished road
try the fuel pressue regulator? somthin nasty could have been stuck in there or its stuck shut or somthin along those lines
skater_107 is offline   Reply With Quote
Old 06-06-2005, 02:15 PM   #4 (permalink)
Moses
Moderator
Moses's Avatar
Casino Cash: $32254
Sportbike: 2003 Honda CBR600RR, 2002 Honda XR50R, 2006 Yamaha FZ6
Moses is on a distinguished road
Oh, the poor fiddy...
I don't have a specific answer, but the first things that I would do is drain the gas, change the oil, change the plugs, and check the obvious...the kill switch.
If you need me to look up anything in the tech manual...or if you would like to "see it", just let me know
Off topic, the vids you guys have on m50m rock My friend Dave and I got 60's style bells on our fiddys after seeing one on one of the bikes in one of your vids.
Brian
Wisconsin Forum Moderator
Any questions, comments, or concerns? Feel free to PM me.
"Some say his favorite pint is Shell Rotella Synthetic. Some say he rides a All we know is, he's called the Stig"
Moses is offline   Reply With Quote
Old 06-09-2005, 05:11 PM   #5 (permalink)
GIXXERGUY
GIXXERGUY's Avatar
ok I am not new to big bikes lol, yes the kill switch is in the run position lol, I have checked and swapped relays out that i had gotten from buddies shop no go. I have been told to check the continuity on the diode on the ignition switch?, I still don't get no vroom......
new plugs oil is fresh, all wires connected.
MOSES you got a manual?
btw the bell you are referring to is SonicJay, pretty cool cat.
WWW.M50M.COM
WWW.STUNTLIFE.COM
Old 06-12-2005, 09:28 AM   #6 (permalink)
Moses
Moderator
Moses's Avatar
Casino Cash: $32254
Service manual, microfiche, etc...
Check your PMs.
Brian
Old 06-12-2005, 02:51 PM   #7 (permalink)
GIXXERGUY
GIXXERGUY's Avatar
Check your PMs.
thanks I already got it off my old hard drive.
WWW.M50M.COM
WWW.STUNTLIFE.COM
Old 06-13-2005, 10:29 AM   #8 (permalink)
thebird_19
thebird_19's Avatar
Sportbike: '01 Honda CBR 600 F4i
thebird_19 is on a distinguished road
Is the tip over sensor setup right? Disconnect the headlight plug and run a jumper wire from the red wire to the green wire which will close that circuit. It sounds like something isn't right there. Then see if it kicks on the fuel pump. I've had problems with my 01 and my cousins 02 but it has always been a blown fuse or a bad connection with the tip over switch. I just always bypass it and test it.
thebird_19 is offline   Reply With Quote
Old 06-13-2005, 06:32 PM   #9 (permalink)
GIXXERGUY
GIXXERGUY's Avatar
are you talking about the connector for the headlight or for the tipover switch
"Disconnect the headlight plug and run a jumper wire from the red wire to the green wire which will close that circuit"
I WAS JUST INFORMED BY A GUY ON EBAY i AM LOOKING AT HIS BIKE HE HAD ISSUES WITH AN 02 NOT FIRING AND HE PLUGGED IN THE HEADLIGHTS AND IT FIRED. i TRIED GROUNDED THE GROUND OUT TO THE FRAME AND IT STILL NO GO, SO i AM IN THE SAME BOAT NOW.
P.S IF ANYONE NEEDS THE PDF FOR THE F4I HIT ME UP ON PM'S
WWW.M50M.COM
WWW.STUNTLIFE.COM
Old 06-14-2005, 12:14 PM   #10 (permalink)
thebird_19
thebird_19's Avatar
You don't need the headlight hooked up if you run that jumper. The tipover sensor is attached to the headlight and the two wires I said to close circuit are the ones that keep it from running when the light isn't connected.
Old 06-14-2005, 05:03 PM   #11 (permalink)
GIXXERGUY
GIXXERGUY's Avatar
give me a few minutes and i'll givee you a picture from another site.
WWW.M50M.COM
WWW.STUNTLIFE.COM
Old 06-15-2005, 08:48 AM   #12 (permalink)
thebird_19
thebird_19's Avatar
^ Thats what I mean, but yours isn't a CA model is it. It shouldn't have an 02 sensor unless its a ca model. If that doesnt' do it, I'd trace the wires through the system back to the fuel pump and test them with a multimeter. You may just have a bad connection or a dirty connector somewhere. I just installed an alarm with remote start on mine the other day and had a heck of a time getting the pump to work with the remote start. I'd put the key in and it would work, but it wouldn't power it up. I finally gave up and put everything back together and it started working??? It still sounds like something from one of your connectors or switchs. You also might try taking apart your kill switch and cleaning it. The connections in it get dirty sometimes and screw with the power transfer.
Old 06-15-2005, 11:23 PM   #13 (permalink)
GIXXERGUY
GIXXERGUY's Avatar
Default update........still not running
swapped harness's and ecm, rectifier
no fuel pump runnage, but if I jump the connector at the relay it will buzz and pump, but won't cut off(due to the fact I have a constant connection to it.
I have reverified the tipover switch is good, kickstand switch is bypass'd and has continuity in the wires, I tried bypass'n the gauges and still nothing.
the only thing I have not tested is the resistor in the ignition, but if I tested the ignition for continuity like the honda manual says then I shouldn't have to test the resistor right?
I don't think the bike is getting spark either, cuz i pulled number 4 coil/boot and put a screw driver in it and held it to the frame and no arcage.
please help i am about ready to sell it back to the guy I bought it from, but don't want to, it has 1266 race miles which is about 5k street miles, looks good, and will serve my purpose well and for a great price $2k(was a bank repo)
HELP ME GET ON THE ROAD.
PEACE
WWW.M50M.COM
WWW.STUNTLIFE.COM
Old 06-16-2005, 01:45 PM   #14 (permalink)
thebird_19
thebird_19's Avatar
Don't sell it back. It still sounds like its in that switch. Try another ignition switch and like I said I've heard of the kill switches getting corroded inside and not allowing it to make a good contact. That would also make it not spark or the fuel pump start. Try bypassing the kill switch if you can't find another one to try. Too bad you live that far away cuz I'd help you look for the problem. I'm pretty good with these bikes now since mine is a 01 and my cousin has an 02 and we just swapped the engine in my brothers 99. He is carbed but the fi is much better. Just gotta get the system functioning. If everything is hooked up though and you get power to everything but the pump and no spark, I would say its most likely the kill switch, because that is what controls both the initial pump startup as well as the spark.
Old 06-16-2005, 04:38 PM   #15 (permalink)
GIXXERGUY
GIXXERGUY's Avatar
BUT IF THE BIKE WILL CRANK OVER THEN THE SWITCH IS WORKING.?
I don't know I am going down to mess with the switch to see if it's nasty or not and i'll let you know later.
peace and thanks for the help
Ron
WWW.M50M.COM
WWW.STUNTLIFE.COM
