06-26-2004, 11:49 PM
#1 (permalink)
Sportbike: sold
Taking oil filter off F3, WTF
Today I was going to change the oil on my cbr f3 that I got about a month ago. I have a manual, and I'm looking through it, I get an oil filter and a filter cap socket... Now I take the plastics off and there is no way to put any kind of oil filter wrench on the filter because the exhaust is too close. In the manual it says just slip the filter cap socket on and use an extension between the pipes, but the pipes are too close to the filter to get the cap on, and the one pipe is blocking room to get an extension to it anyways.
I tried out a strap style filter wrench, and couldnt get it on the filter either. The exhaust I think is stock cept for the slip on. wtf?
06-27-2004, 12:21 AM
#2 (permalink)
Sportbike: '89 Fizzer again
Screwdriver through the side method, works every time. I use a strap wrench on my Gixxer, btu the pipes are a good 1" apart.
06-27-2004, 12:28 AM
#3 (permalink)
Sportbike: sold
What do you mean screwdriver through the side? You use a screwdriver to force the strap wrench over the filter?
06-27-2004, 12:39 AM
#4 (permalink)
Sportbike:
im assuming hes saying punch the driver thru the oil filter and use the driver as a "wrench"
have you tried an open ended wrench, or using a u joint to change the angle.
06-27-2004, 12:46 AM
#5 (permalink)
Sportbike: sold
open ended wrench to do what?
I just dont understand because the manual says just put the filter socket cap on and use an extension between the pipes, but theres no way of doing that.
06-27-2004, 01:26 AM
#6 (permalink)
Insert user title here
Casino Cash: $5009
Sportbike: 2006 Yamaha Roadliner S with Stratoliner stuff added.
the honda shop can get yopu the one that you need. it slips over the top and slides down to lock on the notches on the side ansd has a handle that extends out the side.
06-27-2004, 02:41 AM
#7 (permalink)
Sportbike:
never seen the cap your talking about.
some automotive caps have a "bolt" that you can use a open end wrench to turn it if its in a tight spot.
06-27-2004, 03:02 AM
#8 (permalink)
World 500 GP Racer
Casino Cash: $350
Sportbike:
Do what Gixxer told you if you can't get it off with your hands. There's really no need for special sockets/wrenches. To clarify, he means take a screwdriver, and hammer it into the side of the oil filter, then twist by using the screwdriver handle.
06-27-2004, 10:32 AM
#9 (permalink)
Casino Cash: $665
Sportbike:
i use a hole punch instead of the screwdriver. if you get a good jab then the hammer won't be needed
06-27-2004, 11:52 AM
#10 (permalink)
Sportbike: sold
What about for tightening the filter back on?
06-27-2004, 12:22 PM
#11 (permalink)
Midnight Rider
Sportbike: 01 R6
yeah, that is the problem with that method. i wouldn't reccomend doing it unless you can put the new one on. i used one of them grip wrenches with a strap on my R6 and it came off. you should be able to slip it on the filter and get a little bit of leverage. otherwise you are going to have to go to the dealer and get the wrentch. or take the exhaust off.
06-27-2004, 01:03 PM
#12 (permalink)
You are only suppose to hand tighten oil filters anyway. usually 3/4 to 1 turn past where the o-ring touches.
And yes, what I meant was drive the screwdriver through the side of it. One of the oldest methods known.
06-27-2004, 02:15 PM
#13 (permalink)
Sportbike: sold
Yea, I guess if I hand tighten it enough and as long as it isnt leaking it should be ok right?
06-27-2004, 03:08 PM
#14 (permalink)
Casino Cash: $665
Sportbike:
little oil on the rubber seal and hand tighten. all i've ever done on my '97 f3 and its all she ever needed. comes of with a twist of the wrist when it comes time to change.
06-27-2004, 07:52 PM
#15 (permalink)
My fanclub is here
Casino Cash: $7826
Sportbike: GSXR750K6+, GSXR750K2-, CBR600F3-
Hmm, a import size filter wrench worked on my F3... It has the three gripping teeth that tighten as you turn it.
| Thread Tools |
| Display Modes |
Linear Mode
