Originally Posted by 01cbrf4i
I came home tonight to research a fix for this. I'm wanting to change the sprocket from a 46 to a 55 probably and i dont want the mph and ODO higher than they should be. How much did it cost ya to ur door?
Unfortunately you missed out on the group buy. It was 68 shipped to my door and now I believe that they are back to the 80+ range. As for making the sprocket change, it won't be a problem, just get an accurate reading of your speed. The best way to do that is either with a GPS or riding along next to a car.
Once you get a precise reading of what your speed should be, then go to the speedohealer.com website and run the calculation. It will tell how to program the switches from that point.
I did this last night and just need to test it again.
