Weird start up idle/FI error - Sportbikes.net
Old 12-18-2012, 05:34 PM   #1 (permalink)
2001_cbr
Gameroom cash: $540
Sportbike: 2001/honda/600 f4i
2001_cbr is on a distinguished road
Default Weird start up idle/FI error
I have a 2001 CBR 600 f4i, recently changed the plugs and changed the oil along with putting new lights all around. I also cleaned out the throttle body, bike was in rough shape when i got it as far as how it ran. I had to change the CCT, which i did same time as the oil and plug change.
Problem: When i start the bike it runs at 1000rpm and bogs for roughly 10 sec. then FI light flashes 2 long and 3 short. The bike also runs a little rich.
2001_cbr is offline   Reply With Quote
Old 12-18-2012, 07:19 PM   #2 (permalink)
jeffo8
jeffo8's Avatar
Gameroom cash: $5669
Sportbike: 1987 yamaha fz 600
jeffo8 is on a distinguished road
fI code 23 is the o2 sensor. make certain that it is connected, all connections work, and that the wires haven't broken.
then disconnect your battery for a while to reset your codes.
if the code comes back replace your o2 sensor
Stand on Zanzibar
jeffo8 is offline   Reply With Quote
The Following User Says Thank You to jeffo8 For This Useful Post:
2001_cbr (12-18-2012)
Old 12-18-2012, 07:58 PM   #3 (permalink)
jeffo8
jeffo8's Avatar
https://dl.dropbox.com/u/76073625/CB...e%20Manual.pdf
here is a link to an f4i service manual.
you can grab it from there. it will be very helpful.
you can also look up the "correct" way to clear your codes if you want.
Stand on Zanzibar
The Following 2 Users Say Thank You to jeffo8 For This Useful Post:
2001_cbr (12-19-2012), RugbyCanada (01-02-2013)
Old 12-18-2012, 09:25 PM   #4 (permalink)
2001_cbr
Gameroom cash: $540
ok thanks for your help, ill take a look at it and let you know what i find
Old 12-19-2012, 05:22 PM   #5 (permalink)
2001_cbr
Gameroom cash: $540
i took a look and i didn't seem to see the o2 sensor or connection so i looked at the .PDF of the manual and it shows the California model having an o2 sensor. I don't have the California model. I did notice that something i missing near the MAP sensor that attaches to the bottom of the air box.
there is the pic of what i'm talking about. i have the connection that plugs into the piece that's facing the right. It looks like something else is suppose to plug in to the top of it at well. Any ideas on what it is or if anything is actually missing?
Thanks for the help!
Old 12-19-2012, 05:27 PM   #6 (permalink)
2001_cbr
Gameroom cash: $540
I've got the gas tank and air box off trying to clean the motor off. Whoever had it before me i think literally poured oil and rubbed dirt on it -_- its that bad... took 2 cans of degreaser and its 75% clean. That's how i noticed something might be missing but i have no idea what is suppose to be there. The bike wasn't well taken care of. Its kind of a project bike.
Old 12-21-2012, 11:44 AM   #7 (permalink)
danny500r
Gameroom cash: $8817
Sportbike: 2007 Kawasaki 500R - Totaled / 2003 600 F4i
danny500r is on a distinguished road
MAP Sensor connection or vacuum hose is my guess. I have the same problem intermittently with mine I just haven't gotten around to pulling the tank back off. I also have a California model, but the bike came with a slipon so I don't have an oxygen sensor anymore. Usually bugs me for a couple days, then goes away randomly so I'm guessing mines a loose connection somewhere.
One of these days I need to tear her completely apart and clean everything up. My electrical was cut up (flush mounts and chopped fender) before I got it and I've been having electrical gremlins for the last 1 1/2 years that I haven't found.
danny500r is offline   Reply With Quote
The Following User Says Thank You to danny500r For This Useful Post:
2001_cbr (01-02-2013)
Old 01-02-2013, 12:25 PM   #8 (permalink)
2001_cbr
Gameroom cash: $540
If you do get it torn down i hope you can post a pic or short video of you MAP sensor and where that vacuum hose runs to. I've tried to search of pictures or diagrams of that connection but have come up with nothing. The manual doesn't show where the hose runs from it. I'm sure the vacuum hose is gone because i didn't find any random hoses not plugged in. I'm stumped on how to buy a new one because i cant find a website with a diagram of that MAP sensor and where the hose runs. Thanks for your help
Old 01-02-2013, 12:31 PM   #9 (permalink)
danny500r
I probably won't get to it until closer to Summer when I can take a week off work to just hammer it out and get it done. I use my bike for commuting to keep gas costs down and I can't afford not to have it at this point. Head over to cbrforum.com if you haven't already. Chances are someone can tell you exactly what you need over there if you need to get up and running.
Old 01-02-2013, 06:20 PM   #10 (permalink)
serpentracer
the joke is in your hand
serpentracer's Avatar
Gameroom cash: $80279
Sportbike: 2003 yamaha R6
serpentracer is on a distinguished road
you need to look at a part fiche. it should show you what you need to know.
the parts fiche shows that thing on your airbox is the map sensor for sure.
it's part #13
Fast shipping. Up to 40% off Honda, Yamaha, Kawasaki, Suzuki and Polaris OEM motorcycle parts and accessories. Deep reseller discounts.
now below it notice the E-18-2. that tells you that there is something that goes there and that same code will be on another page of parts.
here it is...
Now it won't start and a Weird Noise too halfstepdown88 Help Me Fix It 12 02-25-2009 03:29 PM
Weird idle and FI light on, 2001 cbr 600f4i 2000t/a guru Help Me Fix It 2 07-04-2008 09:03 AM
900rr Won't start - Weird N4cer Help Me Fix It 6 08-03-2002 05:23 PM
