Bike dies in 2nd - Sportbikes.net
Old 12-04-2012, 08:37 PM   #1 (permalink)
Prier84
Gameroom cash: $675
Sportbike: 07 suzuki gsxr 600
Prier84 is on a distinguished road
Default Bike dies in 2nd
Can somebody please help me. I know my kick stand is weak the guy I bought it from told me it would die sometimes because it the spring is weak or something and the kickstand would come down just enough to trip the sensor. I had a mechanic tell me the same thing when installing a 520 kit. But the weird thing is the only time it dies is when I'm really getting on it in 2nd gear and let off and pull the clutch in sometimes it just shuts off and I have to start it again real quick. Anything else that might cause this or is it just from vibrating the kickstand? Like I said it only happens in 2nd and only a few times not every time. Also if I'm getting on it hard in 1st and go to shift real quick to 2nd it vibrates my foot hard and grinds and only goes to neutral not sure if its my technique or something mechanical that might be related. By the way it's an 07 gsxr if that matters thanks for the help.
Prier84 is offline   Reply With Quote
Old 12-04-2012, 08:45 PM   #2 (permalink)
kevinwilly
Habitual line-stepper
kevinwilly's Avatar
Gameroom cash: $117785
Sportbike: none :(
First- if you know there is a problem with the kickstand, fix that before you start looking other places.
I don't know if that's your problem, but even before I read what you wrote, from the title I was like "i bet it's a kickstand thing".
So yeah- fix the kickstand and see what that does.
As for the grinding, check your clutch cable adjustment. Are you pulling in the clutch while shifting, or shifting without the clutch?
Old 12-04-2012, 08:54 PM   #3 (permalink)
Prier84
Gameroom cash: $675
I always use the clutch I'm too scared to not use it even though I know a lot of people prefer not to I don't want to mess anything up.
Old 12-04-2012, 10:38 PM   #4 (permalink)
RocketPunch
RocketPunch's Avatar
Gameroom cash: $7257
Sportbike: 06 CBR 600RR, 03 R6 street | 05 sv650 race
RocketPunch is on a distinguished road
Change kick stand spring?
LRRS/CCS #604
RocketPunch is offline   Reply With Quote
Old 12-04-2012, 10:43 PM   #5 (permalink)
Prier84
Gameroom cash: $675
Idk if I can I was told I would have to do the whole kick stand assembly but a few people told me I can just bypass that sensor but that sounds kind of iffy to me
Old 12-05-2012, 02:44 PM   #6 (permalink)
Sequentialshift
Sequentialshift's Avatar
Gameroom cash: $11169
Sportbike: KTM 990 SuperDuke / Suzuki RatAtatRat /Kawa Z750
Sequentialshift is on a distinguished road
Bypass as you like , all ya gotta do is remember to put your stand up yourself .. Like we used to before they built bikes with idiots in mind .
"Getting on it hard in first " fnaarr fnarr .. and then shifting to second is the change that benifits most from learning to clutchless shift . When really winding it on throught the gears clutchless is the best way to shift .. but ya gotta know how to do it . Plenty info on the net if you look .
Sequentialshift is offline   Reply With Quote
Old 12-05-2012, 05:20 PM   #7 (permalink)
Prier84
Gameroom cash: $675
So would you recommend bypassing it? And do you guys recommend clutch less shifting all the time or is it bad on the clutch and tranny?
Old 12-06-2012, 02:17 PM   #8 (permalink)
Sequentialshift
I have clutchless shifted every bike I have ever had for their entire lives and never blown a gearbox or clutch yet .
Even if you bypass your switch you will still want to fit a new spring as if it fails worse while your riding along and then lean into a bend ... your gonna know about crashing .
Old 12-06-2012, 03:51 PM   #9 (permalink)
Prier84
Gameroom cash: $675
You know I didn't even think about the part of the stand coming down on me I was just concerned about keeping it running that could have been bad
Bike dies again..400 miles dies at highway speeds..takes few starts to get going aftr Chazell29 Help Me Fix It 34 07-02-2008 05:17 PM
Bike idle drops and dies out when bike is set on kickstand wheelyhappy82 Help Me Fix It 9 10-13-2006 12:24 PM
buddy's bike dies on him... shft600 Help Me Fix It 5 04-10-2006 07:26 PM
Need some help. Bike Dies. Magic8 Help Me Fix It 15 08-23-2005 07:12 PM
Bike dies out? fengler Help Me Fix It 9 09-05-2004 11:18 PM
