ArnottAirRide
SoloMotoPartsArnottAirRideSportbikeTrackGearSportbikeTrackGearKomodoGear.comMotorcycleToyStoreMotorcycle.com Classifieds!Nice CycleMotoGiya.comAdvanstarMotorcycleShowsBazzaz PerformanceSuperbikeToyStore.comSee your ad here!
Old 07-29-2004, 12:59 AM   #1 (permalink)
MattLikesBikes
MattLikesBikes's Avatar
Sportbike: 2001 Suzuki SV650S
MattLikesBikes is on a distinguished road
Default Too much "pull" in my brake lever..
Just noticed this recently..
My brake lever pulls waay further than it used too. I used to be able to bring the bike to a screeching hault using 2 fingers.. Now I need all four, and I can pull the level almost all the way back to the grip. The brakes also seem really "grabby".. like They don't brake much at all, then it hits a certain point and BAM they're on full force. Don't notice it much at higher speeds, but when I'm going slow, like towards a stopsign, it's really hard to stop smoothly.
Any ideas?
MattLikesBikes is offline   Reply With Quote
Old 07-29-2004, 01:08 AM   #2 (permalink)
nig
World 500 GP Racer
nig's Avatar
Casino Cash: $350
Sportbike:
nig is on a distinguished road
Stupid Q, but have you tried adjusting the brake lever (small circular adjuster at the base)?
nig is offline   Reply With Quote
Old 07-29-2004, 01:26 AM   #3 (permalink)
MattLikesBikes
Yeah, I've moved it around.. it helps a little (but not much).. but I was wondering why it would change so much before I ever touched it. I'm sort concerned about it, cause what if they just stop working all together while i'm riding?
Old 07-29-2004, 01:33 AM   #4 (permalink)
nig
World 500 GP Racer
nig's Avatar
Casino Cash: $350
Sportbike:
Changing your brake fluid might help, but hopefully somebody will chime in with a 5 minute fix instead. If you've never changed the fluid and it's a 2001, that just might be your problem though.
Old 07-29-2004, 01:37 AM   #5 (permalink)
nig
World 500 GP Racer
nig's Avatar
Casino Cash: $350
Sportbike:
Does it do this all the time or only after you've been riding for a bit?
Old 07-29-2004, 08:10 AM   #6 (permalink)
MaxPower
Sportbike: '88 Kawasaki EX500
MaxPower is on a distinguished road
I have the same problem... bleeding the brake line helps a bit. I think my bike might need a new brake line.
Be sure to check your brake pads for wear.
Take care of this ASAP, you definitely don't want to be riding around with an ineffective front brake.
MaxPower is offline   Reply With Quote
Old 07-29-2004, 08:27 AM   #7 (permalink)
CasterTroy
So Sexy it hurts
CasterTroy's Avatar
Sportbike: R1
CasterTroy is on a distinguished road
I change my brake fluid once a year....usually get 10k or so a year logged on the bike and thats a good changing point
You've got air in the line SOMEHOW..might be just old fluid. Change the fluid and bleed the lines till they're rock hard at 1/2" pull
Some minds are like concrete, thoroughly mixed up and permanently set
-Troy
CasterTroy is offline   Reply With Quote
Old 07-29-2004, 09:26 AM   #8 (permalink)
stoinkythepig
Sportbike: 2001 ZX9R, 1992 Bandit 400, 1986 Concours
stoinkythepig is on a distinguished road
When the pads are worn out, the lever will come closer to the bar and the brakes will feel different. I'd look closely at the pads for wear.
Assuming you need pads, make sure you clean the rotors thoroughly before installing new pads. The pad materials are sometimes very different and old brake dust may contaminate the new pads making them feel lousy until they wear a bit longer than a "normal" bed-in wear time.
stoinkythepig is offline   Reply With Quote
Old 07-29-2004, 11:22 AM   #9 (permalink)
StumpyNB
Casino Cash: $252
Sportbike: '00 Honda VFR
StumpyNB is on a distinguished road
Even if you change the fluid regularly, it can still develop airbubbles from a number of different things, especially if the fluid level is low.
I would first and formost check for leaks (which I doubt, they are usually pretty obvious) then I would bleed it, and then I would take a zip-tie or something, and ziptie the break lever for a few nights, this lets any remaining air-bubbles "rise to the top" and escape that way.
StumpyNB is offline   Reply With Quote
Old 07-29-2004, 07:06 PM   #10 (permalink)
TK5028
TK5028's Avatar
Sportbike: 1990 Kaw Ninja 600R 1970 Honda CB 750 chopper
TK5028 is on a distinguished road
I agree. Change your fluid. Also, check the res cap to see if it is sealing. Brake fluid will absorb small amounts of air if left exposed.
TK5028 is offline   Reply With Quote
Old 07-31-2004, 11:42 AM   #11 (permalink)
MattLikesBikes
Friends Dad who is also into bikes showed me how to change the fluid.. brakes work fine now.
Thanks for your help everyone
Old 07-31-2004, 12:03 PM   #12 (permalink)
Squid Killer
Squid Killer's Avatar
Casino Cash: $3718
Sportbike: FZ1, R6, Seca 2, EX250, TTR230
Squid Killer is on a distinguished road
Later, consider braided steel brake lines. They help with the feel of the brakes and wont stretch like your stock lines.
MSF Street Rider Coach
MSF Dirt Rider Coach
Squid Killer is offline   Reply With Quote
