Fueling Problems: Suzuki Savage 650 - Sportbikes.net
User Tag List
post #1 of 12 (permalink) Old 06-14-2010, 04:15 PM Thread Starter
arcticamt6's Avatar
Quoted: 12 Post(s)
Ok, so my friend has a Suzuki Savage 650 for a first bike and it's having problems on the highway. I'm helping him fix it since he's going out of town for a month. Around town, it'll run fine, but once it's running 60-70mph for a few minutes, it'll sputter and die. It'll backfire a lot as well. I already swapped the gas in it and put some STP fuel systems cleaner in, but it's still doing it.
Am I going to need to pull off the carbs and clean them? fuel filter maybe? Just keep running the new gas/fuel system cleaner? I just don't want to start pulling stuff off his bike.
arcticamt6 is offline
post #2 of 12 (permalink) Old 06-14-2010, 04:17 PM
Quoted: 0 Post(s)
Fuel filter? check it.
Fuel tank vent line?
ctandc is offline
post #3 of 12 (permalink) Old 06-17-2010, 09:48 AM
Mexican Hard Shell Taco
Süsser Tod's Avatar
Quoted: 17 Post(s)
Well, it is only one carburetor, so it couldn't be any easier. But to me it sounds more like a petcock or fuel tank vent issue. My ER-5 did something like that, it ran great in the city, as you never run WOT for extended periods of time. But hit the interstate, and after a while it would die. Riding at 80mph and then lose all the power. It was the tank vent.
Go soothingly on the greasy mud, for therein lies the skid demon.
Süsser Tod is offline
post #4 of 12 (permalink) Old 06-17-2010, 09:49 AM
Süsser Tod's Avatar
Quoted: 17 Post(s)
By the way, the Savage 650 backfires a lot, that is normal due to it being a thumper. Don't try to fix it as there is no way around it (honestly I love the backfiring on my XT660, it adds to the character of the bike, and if I could, I would make the backfires louder!).
post #5 of 12 (permalink) Old 06-17-2010, 09:51 AM
Turbo nerd.
Tripped1's Avatar
Quoted: 20 Post(s)
Garage
I'd check the filter and then the vent line in that order, it sounds like it is getting starved which generally means the carbs are fine, something outside of the carbs is causing the issue.
A quick test is to run it with the petcock on prime and see if it still does it.
I do wear a helmet, as a matter of fact, along with other protective gear. But, the fact that you “certainly hope” I wear a helmet is so condescending it makes me want to ride a tricycle completely naked doing doughnuts in your front yard screaming Beastie Boys lyrics at midnight. Trust me, you do not want that. My buttocks are extremely pale and unsightly, especially in moonlight.
~Random Interweb Dude whom I very much want to buy a beer.
Tripped1 is offline
post #6 of 12 (permalink) Old 06-17-2010, 09:58 AM
Süsser Tod's Avatar
Quoted: 17 Post(s)
Right, and if it continues doing it while on prime, try running it with the fuel tank open, to rule out the fuel tank vent.
post #7 of 12 (permalink) Old 08-03-2010, 02:36 PM Thread Starter
arcticamt6's Avatar
Quoted: 12 Post(s)
So I had been neglecting to fix his bike since other stuff has come up. I managed to rule out the fuel tank vent. Everything runs fine on prime, which means that a filter is clogged up. Didn't fix the problem when I ran it normally without a gas cap. Problem is, I'm not really sure where the filter is. Here's the bike bandit schematic, and the filter is listed as number 20, but I can't figure out where in the assembly it is. It just shows it as separate from everything else.
post #8 of 12 (permalink) Old 08-04-2010, 06:47 AM
World 500 GP Racer
Quoted: 0 Post(s)
If it runs fine on prime it is not your filter. It sounds like the fuel petcock does not allow suficient flow on the normal position. If it is a vacuum operated petcock it most likely does not open enough. You may be able to take it apart and clean it.
Veefer97 is offline
post #9 of 12 (permalink) Old 01-08-2011, 12:02 AM
Quoted: 0 Post(s)
Faulty Diaphragm on Petcock Probably
Hey, I had a similar problem w/ my Savage 650, and I'm almost 99% sure you've got the same issue.
The diaphragm on the petcock is probably damaged/worn/etc. In addition to what others have said about running it in the PRI/RES position, you can also see if it's faulty by pulling off the vacuum line from the carb. (ie. the other hose on the petcock that's not the fuel hose) If there's any fuel on the tip of the hose, the diaphragm is bad & u'd be better off buying an aftermarket petcock.
Good news, they do make an aftermarket petcock that'll fit the savage for 'round $25, you can find more info on the suzukisavage.com forum.
And as for the fuel filter on the savage, mine didn't have one, so I had to install an external one (the cone-looking types).
Hope this info helps!
cheers,
J
savage_owner is offline
post #10 of 12 (permalink) Old 01-08-2011, 05:45 PM
Umbrella Girl
Quoted: 0 Post(s)
from that diagram it looks to me as if the "fuel filter" is a simple screen located just above the float needle.... a lot of them do it that way. you can usually take it out with the float valve seat as its all one unit.... usually... lol good luck
BlindLOKI is offline
post #11 of 12 (permalink) Old 01-10-2011, 12:32 PM
World 500 GP Racer
Quoted: 0 Post(s)
My XR650R thumper never backfires as it is jetted properly. After fire (back fire is through the carbs) is caused by a lean condition in the idle circuit or just plain lean condition. Shimming the needle or going to a larger idle jet should help.
Veefer97 is offline
post #12 of 12 (permalink) Old 01-10-2011, 05:15 PM
Süsser Tod's Avatar
Quoted: 17 Post(s)
A newer bike, with emissions control systems such as a PAIR valve on the exhaust circuit will backfire unless you remove it. You'd have to be dumping lots of fuel into the exhaust to keep it from backfiring.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
carb problems split4161 Help Me Fix It 13 11-12-2009 11:03 PM
Brand New 09 Kawasaki Ninja 650R......$3000 Ninjabike Bikes For Sale 3 09-10-2009 03:58 PM
Kawasaki KLR 650 oil consumption problems? BarrtRice Motocross / Super Motard 17 03-28-2008 09:04 AM
Safety First Suzuki, GP Suspension and Penske Shocks Together Again in 2007 Lewd Ferrigno Breaking News 2 02-06-2007 11:57 PM
You may post new threads
You may post replies
Refbacks are Off
