2007 ZZR600 wierd problem - Sportbikes.net
Old 03-11-2010, 06:27 PM   #1 (permalink)
danskiz
Gameroom cash: $212
Sportbike: 2007 ZZR600
danskiz is on a distinguished road
Unhappy 2007 ZZR600 wierd problem
Hi Guys, been lurking for a while, but just ran into a very wierd problem with my bike, so I figured I try posting!
Ok, so I get my bike out for the first time this year (2007 ZZR600, about 5500 miles, ran flawlessly last year). Had some trouble starting it at first, but finally got it going, and no problems. I let her run for 5 or 10 minutes to get good and warmed up, burped the throttle a couple times, sounds great! So I get on and go to take off, and once on the road, she seems to be acting wierd as I'm rolling on first. As I'm shifting into second, she stalls. It started right back up, take off again, and as I'm coming up to a stop sign, she stalls again...... but this time I'm putting oil down with lots of smoke. Now realize, I've only gone two "short" blocks from my driveway. I push her home and into the garage. I quickly figured out that the smoke was from the oil pouring onto the pipes, and figured out the the oil is coming from the breather on top of the head (didn't come out, just looks like it's pushing out around it. Still turns over fine (but didn't let her start, just in case), don't think I hurt the motor, but there has to be something blocking the oil from returning from the head. I've worked on many motors before, but never have had one of these ones apart, so short of pulling the motor and breaking her open, I havn't a clue where to even start!! Has anyone run into anything like this before? Any idea's would be greatly appreciated!
danskiz is offline   Reply With Quote
Old 03-11-2010, 06:45 PM   #2 (permalink)
Veefer97
World 500 GP Racer
Gameroom cash: $75354
Sportbike: 98 900RR
Sounds like you are pressurizing the crankcase. See if the breather is clogged in the air filter box. You may have a family of mice that moved in
Old 03-11-2010, 06:52 PM   #3 (permalink)
danskiz
Gameroom cash: $212
I broke open the airbox, and it's clean, checked the breather hose between the head and the airbox, and its clear....
Edit - One thing that is also weird is that right now, the oil fill line in the sight glass is totally covered in oil, making it look like there's too much oil, but the last time I changed the oil was 1500 miles ago. Before I fired her up today, I checked the oil level in the sight glass, and it was perfect.... (and to answer the next question, I don't appear to be low on coolant)
Edit - I've been playing with it, and opening the oil filler, I noticed I can see the oil line about half way up the clutch, if I'm not mistaken, there shouldn't even be any oil up there when it's not running. If I tip the bike back and forth, I can hear the oil gurgling like it's releasing air pockets. Is there an internal valve, or something that may have froze up over the winter that could be keeping the oil from returning to the crankcase properly? Since I have never had one of these motors apart, I don't know how the oil returns work. Could something be blocking one?? That combined with the fact that the sight glass is totally covered with oil, and I'm totally confused!!
Old 03-11-2010, 10:45 PM   #4 (permalink)
RayOSV
RayOSV's Avatar
Gameroom cash: $94068
Sportbike: '05 sv1000s
RayOSV will become famous soon enough
Smell the oil. Does it smell of gas and seem pretty thin?
RayOSV is online now   Reply With Quote
Old 03-11-2010, 10:50 PM   #5 (permalink)
danskiz
Gameroom cash: $212
No gas smell in the oil, oil looks good...
edit - I was wrong about the gas smell in the oil. I was going off of the drips that were coming off of it, and they look fine. But I just drained the oil, and it kept coming, and coming...... Was very thin, and definately smelled of gas. I estimate that I pulled 6 or 7 quarts out of it!! I stupidly didn't shut the tank off when I parked it for winter (didn't think a complete winterizing was necessary since my last ride was in December). Is it possible that that much gas could have leaked from the carbs in a few months???
Old 03-12-2010, 03:40 AM   #6 (permalink)
enos
second chimp in space
enos's Avatar
Gameroom cash: $71693
yes.
or you have some neighbor kids with a very sick idea of a practical joke.
enos is offline   Reply With Quote
Old 03-12-2010, 08:36 AM   #7 (permalink)
Papa Rocket
Papa Rocket's Avatar
Gameroom cash: $26985
Sportbike: 2005 Kawasaki ZX-10R
Papa Rocket is on a distinguished road
+1
Occasionally there could be a stuck float condition (especially with today's garbage fuel). Check the carburetors for this and definitely check the Vacuum operated petcock on that model for a leak.
Obviously you need to drain that oil and filter before you operate it again.
Take the airbox off (so you can see the carburetor bores) and turn the petcck to the "PRI" position. Check to see if there are any carbs pouring fuel into the engine. The other thing you will want to check is the vacuum line going to the petcock from the carb insulators. when you remove it, see if it's leaking fuel from this line. If it is, rebuild the petcock assy.
Papa Rocket is offline   Reply With Quote
Old 03-12-2010, 12:38 PM   #8 (permalink)
danskiz
Gameroom cash: $212
Thanks, I'll check that out. Last night I drained the oil, pulled the filter, drained that out, than put some new oil in. Got her back together enough to start it up, and no problems. Took her about a mile down the road, being gentle at first, then getting on it a little, and no issues, ran perfectly. I've read in a couple different places that since I got so much gas in the crankcase, I should change the oil again very soon. Any opinions on that?
Old 03-12-2010, 03:06 PM   #9 (permalink)
RayOSV
RayOSV's Avatar
Changing the oil and filter again after a few miles (50-100 maybe) would be an excellent idea.
for sale 2007 kawasaki ZZR600 $5600 50246,Ia halcyon rider Bikes For Sale 0 10-21-2008 06:26 PM
2007 Kawasaki ZZR600 - Perfect Condition adamp961 Bikes For Sale 5 09-24-2008 07:44 PM
