R6 wont start - Sportbikes.net
User Tag List
post #1 of 11 (permalink) Old 02-28-2010, 03:20 PM Thread Starter
Quoted: 0 Post(s)
R6 wont start
I have a 2005 yamaha r6 that won't start. The battery is new and after a few days of running it, it wont start. The turn signals, horn, lights, and accessories work fine in the run position and as soon as I try to start it, the bike turns over very weakly and then stops. You can only hear the starter at this point. I kick started the bike and tested the battery with a voltmeter when it dropped down from 12.5 volts, to 11, to 10, 9, then 8 when the bike finally shut off. I'm not sure what the problem may be. I was thinking the alternator or maybe a grounded wire somewhere? Any comments or advice would help...
808built is offline
post #2 of 11 (permalink) Old 02-28-2010, 03:38 PM
not2slow's Avatar
Quoted: 0 Post(s)
Its not in the not run position on the right handlebar right? first things first.
not2slow is offline
post #3 of 11 (permalink) Old 02-28-2010, 03:49 PM Thread Starter
Quoted: 0 Post(s)
No its not. I turn it to the run position and try to turn it on. Cranks maybe once or twice but then dies. Afterwards you can only hear the starter engaging but motor doesn't turn over. If I push start the bike it runs but then dies after the voltage on the battery continues to drop. Ill have to keep on the throttle for it to stay on.
808built is offline
post #4 of 11 (permalink) Old 02-28-2010, 04:11 PM
Superbike Champion
sport-ryder's Avatar
Quoted: 0 Post(s)
you will have to gt a schematic for specs, but id say there is something wrong in your charging system, you will need to know what wires to test for your bike, but you will have to work your way from the stator all the way to the battery, check for loose wires, connections, and test each unit in the system.
sport-ryder is offline
post #5 of 11 (permalink) Old 02-28-2010, 05:55 PM
World 500 GP Racer
Quoted: 0 Post(s)
Check out put voltage at regulator, should be 14.7VDC at 5 K rpm. If not check input voltage to regulator, 3 wires, should be 50+VAC at 5 K rpm. If AC voltage is ok then you regulator is toast. If AC voltage is low the stator is toast.
Veefer97 is offline
post #6 of 11 (permalink) Old 02-28-2010, 07:10 PM Thread Starter
Quoted: 0 Post(s)
I knew it was the charging system just didnt know what to check. Im trying to get the schematics so i know what to check. Thanks guys
808built is offline
post #7 of 11 (permalink) Old 02-28-2010, 10:51 PM
the joke is in your hand
serpentracer's Avatar
Quoted: 94 Post(s)
you can download the service manual for free.
http://www.r6messagenet.com/forums/p...ice_manual.pdf
the 05 suppliment to the manual,
http://www.r6messagenet.com/forums/pdf/2005R6supp.pdf
and here is how you test the R6 charging circuit.
it has to be at least 14v at 5k rpm. minimum. in my experience from being around R6 forums since 2003, it's most likely just a bad regulator or a burnt plug at the regulator. (the regulator on the R6 is visable by looking right by where the rear shock mounts. it's a black box that has fins on it.
there is no specific test that the manual has. it just says to check everything else and then replace it.
serpentracer is offline
post #8 of 11 (permalink) Old 03-01-2010, 06:58 AM
World 500 GP Racer
Quoted: 0 Post(s)
Follow the wires from the alternator cover to where they go into the regulator. This is the AC voltage check location. The wires going out of the regulator to the battery is the DC voltage location. Reading the manual is best but this is a time proven method that works.
Veefer97 is offline
post #9 of 11 (permalink) Old 03-01-2010, 10:20 AM
Papa Rocket's Avatar
Quoted: 0 Post(s)
Also, just for your peace of mind... fully charge the battery and load test it to ensure it is working properly. Just because the Battery is brand new, does'nt mean it is in perfect working order.
It does sound a little like a voltage regulator problem. (bad diodes causing drainage of the battery)
Papa Rocket is offline
post #10 of 11 (permalink) Old 03-02-2010, 01:59 AM Thread Starter
Quoted: 0 Post(s)
Ok sorry for the false information. My friend told me it was brand new but when I asked him again he said it was new when he bought it but had been sitting for a while. The battery does not hold the charge at all. It dropped below 6 volts after an hour of it being properly charged. I jump started the bike and reved the motor to 5k. It climbed from 8 volts from idle to 12 volts at 5k. I know it should be 14 so could it still be the battery?
808built is offline
post #11 of 11 (permalink) Old 03-02-2010, 06:52 AM
World 500 GP Racer
Quoted: 0 Post(s)
The battery could be placing a high load on the charging system.
Veefer97 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Bike won't start! 2001 ZX6R, any help uber appreciated. MattLikesBikes Help Me Fix It 1 10-14-2007 10:22 PM
'01 Gixxer Wont Start cali gixxer Help Me Fix It 10 10-01-2007 02:00 AM
start problems ducsgr8 Help Me Fix It 3 09-18-2007 10:52 AM
Help, bike wont start! Zixxer330 General Sportbikes 6 09-11-2007 10:16 AM
Any females start on an R6? (or 600cc SS) BaileyMoto General Sportbikes 6 02-17-2007 10:03 AM
You may post new threads
You may post replies
Refbacks are Off
