Fuel tank lock stuck! - Sportbikes.net
User Tag List
post #1 of 6 (permalink) Old 11-22-2009, 02:38 PM Thread Starter
Quoted: 0 Post(s)
I have a 2007 ninja 250 that was sitting for about 5 months. The other day I finally had some time to ride and had just gotten the bike reinsured so I went and tried to put some fuel in the tank. Well the key goes in and out just fine, and will turn about 1/8th of a turn. Then it just stops. If I keep trying to turn the key bends. I tried PB blaster, wd-40, white lithium, nothing seems to work! It feels like its almost to the point where it would normally pop open. Any ideas? Thanks.
npr0010 is offline
post #2 of 6 (permalink) Old 11-22-2009, 02:41 PM
rockscaler's Avatar
Quoted: 0 Post(s)
its not the key or lock but the latch and you might have to unbolt the entire gascap assembly if the key is bending
It is good to have an end to journey toward, but it is the journey that is important, in the end.
rockscaler is offline
post #3 of 6 (permalink) Old 11-22-2009, 03:01 PM Thread Starter
Quoted: 0 Post(s)
I tried taking off the screws around the cap, but it appears it still won't come off unless it's already unlocked. Is this something that can be fixed, or will I need to buy a new gas cap after I finally get this one unlocked?
npr0010 is offline
post #4 of 6 (permalink) Old 11-22-2009, 04:22 PM
second chimp in space
enos's Avatar
Quoted: 0 Post(s)
There is one more screw under the lock.
WD-40 isn't much of a lube. Try some penetrating oil or another actual oil (not grease). Put oil in the keyhole and on the key. Wiggle the key in all directions and eventually it'll go.
enos is offline
post #5 of 6 (permalink) Old 11-22-2009, 04:40 PM
YZFHEFF's Avatar
Quoted: 0 Post(s)
Try tapping on it at some point as well to break things loose. Maybe some heat too if you have a heat gun?
When in doubt gas it
YZFHEFF is offline
post #6 of 6 (permalink) Old 11-23-2009, 09:17 PM Thread Starter
Quoted: 0 Post(s)
I had a locksmith come out and open it, really I just needed something stronger than the key. He picked the lock and used a screwdriver to open it the rest of the way. Turns out there was just some grit in the latch, it's working fine now though.
npr0010 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Fuel Tank Over FLow Hose Question? 08KB750 GSX-R750 0 01-29-2009 09:34 AM
WTB Blue FZ6 Fuel Tank TIVOM FZ6 Classifieds 1 07-26-2007 01:26 AM
fuel tank question.. darkbluexplorer FZ6/FZ6R 8 07-25-2007 01:26 PM
You may post new threads
You may post replies
Refbacks are Off
