2001 CBR 929 won't start - Sportbikes.net
User Tag List
post #1 of 10 (permalink) Old 04-03-2009, 12:34 PM Thread Starter
Quoted: 0 Post(s)
Fall of 2008 my son bought a used 2001 929 with about 10,000 miles on it. We trailer it home and rode it a couple of times near the house. He parked it in the garage and started several times as it began to get cold outside. One day it wouldn't start, the fuel injection can be heard and it cranks but won't turn over. Trying to start it eventually kills the battery and he puts it on the trickle charger. We lifted the tank up and checked the air cleaner. The valves open when you turn the throttle and I see fuel mist spraying in. We even tried a small dose of starting fluid but nothing (no start). If a plug was bad it would at least begin to turn over right?
Graygod is offline
post #2 of 10 (permalink) Old 04-03-2009, 12:47 PM
Quoted: 0 Post(s)
if you're that far into the engine, i'd say clean spark plugs, new fuel, put the battery on a charger and start cranking it over. if it floods then give it full throttle, hold it at that and crank it over to de flood the engine.
can you hear it alteast trying to fire up at all?
maci4life is offline
post #3 of 10 (permalink) Old 04-03-2009, 12:53 PM
ghostriders999's Avatar
Quoted: 0 Post(s)
if the injectors are spraying,, then you have no spark,,, spark plugs can be pulled and checked but since there out you might as well change them,,,
its either a firing issue or carb problem,,, but sure sounds like a firing issue,,, check the kill switch on the handle bar and rock it back and forth while crankin it,,, i've seen them corode up on the inside if it was ever getting rained on
STRICKLY BUSINESS
ghostriders999 is offline
post #4 of 10 (permalink) Old 04-03-2009, 01:43 PM Thread Starter
Quoted: 0 Post(s)
yes it sounds normal like it is trying to start just never turns over. We pulled the center two plugs out and my son was about to pull the outside ones out, I just thought before he did that we may find out something online.
Graygod is offline
post #5 of 10 (permalink) Old 04-03-2009, 01:56 PM Thread Starter
Quoted: 0 Post(s)
I mean it sounds normally but it doesn't get that turning over sound, like it is firing up. The first couple of times we tried to start it after it wouldn't start a small cloud of smoke would exit the muffler and you hear a slight sound like it wanted to fire. But know all it does is turn over and all you hear is the starter.
Graygod is offline
post #6 of 10 (permalink) Old 04-12-2009, 03:13 PM
Quoted: 0 Post(s)
i have a 2001 cbr929rr...i had a similar issue...replaced battery, plugs, etc...try checking the regulator/rectifier...it is/was a common problem with honda bikes...you cld get one new for around $100...and it's easy to install...hope it works out for you!
rizzaray is offline
post #7 of 10 (permalink) Old 06-27-2009, 08:33 AM
Quoted: 0 Post(s)
Did you get it to start? I'm having similar issues, same bike nd year. Frustrated.
markonius3 is offline
post #8 of 10 (permalink) Old 07-24-2009, 09:35 PM
Quoted: 0 Post(s)
I might have the same problem
the only way I can get the bike started is using jumper leads on a car and have the car reving so there is a higher voltage going to the bike (it starts immediately every time I do this). Ive tried replacing the battery
wozwasted is offline
post #9 of 10 (permalink) Old 07-25-2009, 09:54 AM
Quoted: 0 Post(s)
You can jump your bike from a car but the car SHOULD NOT BE RUNNING. You will damage the electrics on the bike. A fully charged, GOOD bike battery should start the bike (as if your jumping it). As stated earlier it may not be charging once started however you need a full charge to get it to run...
70115 is offline
post #10 of 10 (permalink) Old 08-03-2009, 12:46 AM
PULLNGS929's Avatar
Quoted: 0 Post(s)
might be a dead cell in battery. a total tune up might help you.
DON'T BUCK THE HORSE JUST HOLD ON FOR THE RIDE............... KNEES IN BABY KNEES IN...........
PULLNGS929 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
FS: 2001 CBR 929 Miami motopsyko32 Bikes For Sale 0 02-05-2008 08:22 PM
2001 Honda CBR 929 - Fuel injected? wrx2k4blue Honda Sportbikes 2 01-24-2007 11:55 AM
CBR 929 Fireblade velo12 General Sportbikes 11 12-21-2004 09:09 PM
Fs: Hyperpro Steering Damper Mounting Kit For Honda Cbr 929 Fireblade 929wOhlinsForks Parts For Sale 0 09-09-2004 09:31 AM
2001 CBR F4i Knoxville Tn f4igrad Bikes For Sale 6 07-18-2004 04:32 PM
You may post new threads
You may post replies
Refbacks are Off
