JazzMotorsports.com
Sixty61Bazzaz PerformanceSumOfAllParts.netSportbikeTrackGear
ArnottAirRideAvonTyresNice CycleBazzaz PerformanceD2MotoSee your ad here!
Old 08-06-2008, 11:13 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Ishibubu
Casino Cash: $2209
Sportbike: 1996 Honda CBR 600
Ishibubu is on a distinguished road
Default Ugh Spark Plug Socket Stuck
So I have a 96 CBR600 and i'm trying to change the spark plugs. I am using a 16mm spark plug socket, an extension, and then hooking the ratchet to the extension. I got through the first one somewhat smoothly, however the extension doesn't hook into the socket strong enough to get the rubber to stop grabbing the plug. Anyway I managed to finesse it out and it has happened again on the 2nd one, this time I'm not having the same luck.
Any idea on what I could use to remove a stubborn socket already in the spark plug hole?
Ishibubu is offline   Reply With Quote
Old 08-07-2008, 04:27 AM   #2 (permalink)
bumblebee
bumblebee's Avatar
Casino Cash: $23219
bumblebee will become famous soon enoughbumblebee will become famous soon enough
Try a flexi extension
"Poor people have been voting for Democrats for the last 50 years............and they are still poor." Charles Barkley
Since Ted Kennedy's brain surgery was successful, does that mean he's a Republican now?
bumblebee is online now   Reply With Quote
Old 08-07-2008, 04:32 AM   #3 (permalink)
YZFHEFF
YZFHEFF's Avatar
Casino Cash: $1270
Sportbike: YZF750
YZFHEFF is an unknown quantity at this point
Just use the ratchet to break 'em loose then get it outta there and use your fingers on the extension.
I guess I don't really get what the problem is.
Ah, you've got the whole thing out and the plug is stuck in the socket? What, there's not enough sticking out to grab? Pliers, vice?
Third read and I'm back to being confused.
OK, one last try. I think I get it now. Long needle-nose pliers or a hemostat. Coat hanger with a hook on the end smaller than 3/8 across? Or bigger and hook the big end.
Best of luck with it.
KEEP RIGHT EXCEPT TO PASS
YZFHEFF is online now   Reply With Quote
Old 08-07-2008, 07:27 AM   #4 (permalink)
rayzzr
rayzzr's Avatar
Casino Cash: $10058
Sportbike: 07 Kawasaki Zizzer 600/06 Kawasaki KLR650
rayzzr is on a distinguished road
Total Awards: 4
I think the op is saying he has the socket stuck down in the spark plug hole, and the socket keeps turning loose from the extension so he cannot manage to get it out.
I'd say buy or borrow from a neighbor another extension.
and I've never licked a spark-plug, and I've never sniffed a stink bug, and I've never painted Daisies on a big red rubber ball, and I've never bathed in yogurt, and I don't look good in leggings, and I've never been to Boston in the fall
"If you wish upon a star, your dreams really can come true. Unless that shooting star is actually a meteor hurtling to Earth to destroy all life as we know it. Then you are pretty much hosed no matter what you wish for, unless it's death by meteor..."
rayzzr is offline   Reply With Quote
Old 08-07-2008, 12:01 PM   #5 (permalink)
Ishibubu
Casino Cash: $2209
Na, its like this. The Socket doesn't hook to the extension very strongly, whenever theres a slight resistance in the socket coming up (i.e. the rubber being "stuck" on the plug) then the extension will just detach itself from the socket. So the socket isn't just sliding out smoothly it's catching on the plug and being a pain in the ass to get out.
Old 08-07-2008, 01:25 PM   #6 (permalink)
rayzzr
rayzzr's Avatar
Casino Cash: $10058
Total Awards: 4
duct tape it
Old 08-07-2008, 04:36 PM   #7 (permalink)
serpentracer
dominant male of SBN
serpentracer's Avatar
Casino Cash: $15500
Sportbike: 2003 yamaha R6
serpentracer is on a distinguished road
Originally Posted by rayzzr View Post
duct tape it
that's not a bad idea actually
serpentracer is online now   Reply With Quote
Old 08-08-2008, 01:28 PM   #8 (permalink)
Tuffguy #2
Speed Racer
Tuffguy #2's Avatar
Casino Cash: $6311
Sportbike: '02 F4i, '99 VFR, '99 1100xx
Tuffguy #2 is an unknown quantity at this point
To get the socket out... cut up a wire coat hanger. Bend a hook on it, and use the square extension hole to hook the inside of the socket. If that doesn't work, try using two of them,,one on each opposite sides of the socket/extension hole.
This is why honda includes a spark plug socket and wrench for every bike. They are all the same size. If you have a friend with a honda, then borrow his. They work great.
Ron Paul for President http://www.ronpaul2008.com/
'02 F4i
'99 Blackbird
Tuffguy #2 is offline   Reply With Quote
Old 08-08-2008, 01:58 PM   #9 (permalink)
tutmondigo
Casino Cash: $3676
Sportbike: Saving for a Ninja250R.
tutmondigo is on a distinguished road
In a situation like this I would just get an appropriately sized deep socket and install it with that. No rubber to pull the socket off of your extension then. I only use the spark plug socket for removal.
tutmondigo is offline   Reply With Quote
LinkBack to this Thread: http://www.sportbikes.net/forums/help-me-fix/398977-ugh-spark-plug-socket-stuck.html
Ugh Spark Plug Socket Stuck - Sportbikes.net This thread Refback 08-07-2008 04:25 PM
How does this spark plug look? Jaxx Help Me Fix It 15 03-14-2008 02:50 PM
Spark Plug question wfd38383 General Sportbikes 4 07-25-2007 12:42 AM
NGK Iridium Spark Plug Question FZ6 FZ6 5 07-02-2007 07:34 AM
Spark Plug playback Suzuki Sportbikes 3 09-24-2004 12:44 PM
Compression coming past spark plug, what can I do? BLACK Z Help Me Fix It 1 07-01-2004 09:49 PM
