CheapCycleParts.com
Nice CycleRacerPartsWholesaleArnottAirRideAdvanstarMotorcycleShowsChainDrain.comMotorcycleToyStoreMotoGiya.comWilzGarageJazzMotorsports.comMotorcycle.com Classifieds!Springfield ArmorySportbikeTrackGearSportbikeTrackGearBazzaz PerformanceSee your ad here!
Old 07-27-2008, 02:09 PM   #1 (permalink)
yamirider
I want to ride again :(
yamirider's Avatar
Casino Cash: $15394
Sportbike: Sold :(
yamirider is on a distinguished road
Default Stainless lines are on...and now weird problems
I put them on without a hitch. All seemed well. Now, I'm noticing a hissing noise when I stop. At first I thought it might be leaking brake fluid. Yes there was fluid leaking, but it was at the master cylinder...and it the cap was just a little loose so I tightened that up.
Now I suppose that the weird hissing could possibly be leaking brake fluid, but the braking power seems okay....although it does seem weaker than it was when I first rode it after I put the lines on. I've ridden my dads bike before when the pads got brake fluid on them, and they were definitely MUCH weaker than mine. So, any ideas?
Cliffs:
1. weird hissing
2. no visible leaks
3. braking power still very good
yamirider is offline   Reply With Quote
Old 07-27-2008, 03:08 PM   #2 (permalink)
93FZR1K
Ready to Ride
93FZR1K's Avatar
Casino Cash: $18612
Sportbike: 2003 Kawasaki Z1000, 2005 Kawasaki Ninja250, 1987 Yamaha TZR250
93FZR1K is on a distinguished road
almost a "zzzzzzzzzzzzt" sound? did you replace pads also? my bike and a few others i've ridden make that noise when braking
93FZR1K is offline   Reply With Quote
Old 07-27-2008, 03:40 PM   #3 (permalink)
kevinwilly
former murder victim....
kevinwilly's Avatar
Casino Cash: $38051
Sportbike: 2000 Ninja 250
Total Awards: 4
Could your line be rubbing on the wheel someplace?
Old 07-27-2008, 07:41 PM   #4 (permalink)
HalfLiterBeater
Duct Tape Engineer
HalfLiterBeater's Avatar
Casino Cash: $4349
Sportbike: 07 Kawi ZX6R, lime green
HalfLiterBeater is on a distinguished road
If any fluid got onto the pads, I'd remove them and spray the friction surfaces down with brake-cleaner....same with both sides of the rotors.... Kevin's got a good suggestion.... And like 93 said, I've heard the same kinda 'zingy' noises from new pads....probably due to them wearing in and scraping across the drill-holes in the rotors.
"I smell blood and an era of prominent madmen"- W.H. Auden
The dead list: 04 EX500(sold), 98 VTR1000F(traded in)
07 Kawasaki ZX6R-Opened exhaust valve, Jumper mod, de-screened stock air filter, -1/+1 sprockets, green EK chain, ZG smoked double-bubble , solo cowl, Scorpio alarm.
HalfLiterBeater is offline   Reply With Quote
Old 07-28-2008, 09:10 AM   #5 (permalink)
yamirider
yamirider's Avatar
Casino Cash: $15394
Sportbike: Sold :(
No new pads. The pads that are on there are actually pretty old and will need to be replaced soon....but I've still got wear bars.
Old 08-02-2008, 10:28 AM   #6 (permalink)
boner
boner's Avatar
Casino Cash: $31884
Sportbike: Ducati s2r1k, old honda cb400t
boner is on a distinguished road
with the bike stopped...
squeeze the lever hard, really hard. now the lever should travel a bit and stop. hold the lever and maintain the same pressure for a little while. if the lever slowly moves towards the bar you have a leak somewhere (assuming the lines are bled properly).
but if the leak was enough to be audible you would see fluid spraying out of some fitting and making a big ol' mess.
I like my headlights big and round
YouTube - VS headquarters on the DML
boner is online now   Reply With Quote
Old 08-02-2008, 10:27 PM   #7 (permalink)
HalfLiterBeater
Duct Tape Engineer
Casino Cash: $4349
/\+1 to that....though I'm doubting a hydraulic issue considering the fluid is full and there's no loss of braking performance.
When you reinstalled the pads, no backing plates or little clips fell out of the pads/calipers, did they? And you did reinstall the pads in their original orientation right?
Old 08-29-2008, 03:24 PM   #8 (permalink)
dale-j
smokin' and (2) strokin'
dale-j's Avatar
Casino Cash: $264
Sportbike: 1993 Honda VFR ('fighter), 1979 RD400F (2 stroke cafe racer)
dale-j is on a distinguished road
I noticed with mine when I switched to steel lines that I could 'feel' that vibration of the pads on the rotor holes, while the old rubber hoses must have damped the vibration by the time it got to the lever. I just wonder if in your case it's actually making an audible noise at the lever or where the hose touches a bracket on the bike (???)
You certainly shouldn't notice any decrease in braking performance from the rubber lines 'baseline', if you do you probably need to bleed the banjo bolts and master cylinder again carefully.
dale-j is offline   Reply With Quote
