06-27-2008, 10:04 PM
#1 (permalink)
Making Horizons Vertical
Casino Cash: $6639
Sportbike: 07 Kawasaki ZZR600
Bike Won't Start
Well after I lowsided at the track I've been piecing it together... I've ran it a few times and it idled ok and everything.. I ran it 2 days ago with no choke lever and it ran ok but stumbled a little bit. After that I forgot to turn the bike off and left the key on for about a day n half.. I charged the battery tonight and I've got nothing.. It doesn't seem to be making any spark..
So basically it was running, I replaced the choke and killed/charged the battery and she won't start at all...
I checked all the connections, but nothing else has changed besides whats mentioned above..
WTF?
Car ~ 2003 Honda S2000 - Stock - Black - 9K RPM
BEATER ~ 1992 Honda Civic LX ~ *fixed* axle, Bad Idle, Burnt 4th Gear Synchro - White
Bike ~ 2007 Kawasaki ZZR600 - Black
Goodies - Yoshi can, K&N Filter, DynoJet Stage 1 Jet Kit, Factory Pro Ignition Advancer, Galfer Brake Lines, Flush mounts, Swingarm Sliders, Pazzo Levers, Grip warmers, n CarbonFreak Windscreen 99.63 WHP
06-27-2008, 10:46 PM
#2 (permalink)
Duct Tape Engineer
Casino Cash: $4349
Sportbike: 07 Kawi ZX6R, lime green
Is this a no-crank? Or a crank but no-start problem?
I'm assuming your choke adjustment is on the left bar...if so, and it's not cranking, check the clutch switch, maybe the connector came loose
"I smell blood and an era of prominent madmen"- W.H. Auden
The dead list: 04 EX500(sold), 98 VTR1000F(traded in)
07 Kawasaki ZX6R-Opened exhaust valve, Jumper mod, de-screened stock air filter, -1/+1 sprockets, green EK chain, ZG smoked double-bubble , solo cowl, Scorpio alarm.
06-28-2008, 03:19 AM
#3 (permalink)
Casino Cash: $6639
The clutch switch is damaged but the connector still makes good contact.
It cranks, real fast, battery doesn't seem to be a prob..
How can you tell if a stator is bad?
07-02-2008, 04:20 PM
#4 (permalink)
Casino Cash: $6639
Think I could have fucked the plugs?
07-08-2008, 08:42 PM
#5 (permalink)
Casino Cash: $6639
Well, not fouled plugs, seems to be a fuel issue..
I sprayed some starter fluid and it started right up..
The tank did get dented, I took it off and there doesn't seem to be any blockage. I can't tell if the fuel filter is clogged, but there's def pressure in the line going into the carbs..
Any ideas?
| Thread Tools |
| Display Modes |
Linear Mode
