Originally Posted by RayOSV
So, how'd you get it started?
It was very strange- after sitting over night, I went out to check it. Fuses were good, turned key on and was surprised to hear fuel pump turn on. pressed the ignition switch and heard it crank like twice then after the ignition switch wouldn't work anymore(didn't sound like a normal startup). turn key off/on again, tried everything again a few more times and it did the same thing. about 5th try it just started up like normal.
I know my description is laughable, I'm not a mechanic.
Now I have a fear in the back of my head that it'll suddenly die on the road.
Thanks for answering my radiator question btw
