SportbikeTrackGearMotoGiya.comAnnitori DistributingSoloMotoPartsCycleGear.comArnottAirRideBazzaz PerformanceNice CycleJazzMotorsports.comRacerPartsWholesaleSportbikeTrackGearSee your ad here!
Old 04-12-2008, 02:48 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Krik
Ducati Twins Rock
Krik's Avatar
Casino Cash: $354
Sportbike: 2005 Yamaha R1 "Raven", 2002 Ducati 998 Monoposto, 2001 Suzuki SV650S
Krik is on a distinguished road
Default Carbed SV650 won't run without full choke
Ok guys,
My 2001 SV650 has been sitting for a couple of years and I want to get it running again. If I recall correctly, I did put some stabil in it but I don't think it will last that long.
So I siphoned out as much gas as I should and put some fresh gas and added some techron fuel injector cleaner.
Took a while to crank over but with full choke on it finally did. A bunch of white smoke coming out of exhaust. Let bike run for about 10 minutes so it was fully warm. Any attempt to give it gas will kill the engine. Any attempt to back off the choke will kill the engine. Any attempt to start the bike once warm with less than full choke was unsuccessful.
I pulled the airbox off and started the bike again with full choke. While the engine was running, I put both hands over the carb intakes. The first time I covered it too much and got my hands sucked on and the bike died. The next few attempts, I limited the amount of air going into both carbs and the bike shot up in rpm's. To about 3500-4000 rpms like you would expect a warm engine with full choke to do.
I didn't have a third hand to give some throttle while I was covering the carbs so I couldn't attempt to rev the bike to see what it would do.
So what do you think? Vacuum leak? Clogged jets? I really need to get this thing running.
Thanks!
Rent this space. PM me now for details!
2005 Yamaha R1 Raven (Nevermore)
2002 Ducati 998 Monoposto (Italian Mistress)
2001 Suzuki SV650S (Track Ho)
Krik is offline   Reply With Quote
Old 04-12-2008, 05:16 PM   #2 (permalink)
Cabanaboy
Project Cheapo Fireblade
Cabanaboy's Avatar
Casino Cash: $20127
Sportbike: 1998 Honda CBR900RR!!!!
Cabanaboy is on a distinguished road
Not being able to get it to do anything but idle sounds like gunked jets. You could try doing a thorough soak down with SeaFoam, or you could take out the carbs and clean the jets by hand. By hand ensures the best results, but you'll need to be wrench savvy witha good repair manual.
Seafoam can also help, you could 'overdose' by warming the engine up, making sure it is up to temperature, then shutting off the gas tank petcock. Disconnect the fuel line from the tank, and then feed seafoam STRAIGHT into the fuel line while the bike is idling. Keep adding seafoam until the engine shuts off. Let the bike sit as is for 30 minutes or so. Start the bike up, let it idle a bit, and then try revving it. Should smoke a bit, but should also clean up the problem for the most part. If it still persists, you could try the above steps one more time, but otherwise, you will need to do it manually (Carb cleaner and compressed air is the best way to clean jets) or have a professional do it.
2006 Subaru Impreza 2.5i
2001 Yamaha Warrior
1998 CBR900RR!
1983 XT550
Cabanaboy is offline   Reply With Quote
Old 04-12-2008, 06:10 PM   #3 (permalink)
bumblebee
bumblebee's Avatar
Casino Cash: $32768
bumblebee will become famous soon enoughbumblebee will become famous soon enough
Time to take the carbs apart and clean them
I find that the harder I work, the more luck I seem to have. Thomas Jefferson
bumblebee is offline   Reply With Quote
Old 04-12-2008, 07:10 PM   #4 (permalink)
Veefer97
Casino Cash: $27389
Sportbike: 98 900RR
You need to remove and dissasemble the carbs. Parts can be cleaned in a strong detergent like Simple Green or Oil eater (my favorite) but these chemicals can discolor aluminum in 100% concentration.
Old 04-12-2008, 07:17 PM   #5 (permalink)
LDS
Unregistered User
LDS's Avatar
Casino Cash: $18947
Sportbike: 05 FZ6, 99 SV650, 01 EX250
LDS is on a distinguished road
Pilot jets sound clogged.
Try and find some Berryman's Chemtool to clean the parts in, but don't get anything rubber in it, it'll eat it up.
I too, have nothing of value to add to this thread...
LDS is offline   Reply With Quote
Old 04-13-2008, 03:08 AM   #6 (permalink)
RayOSV
RayOSV's Avatar
Casino Cash: $37404
Sportbike: '05 sv1000s
Yep, time to tear down the carbs for a good cleaning. Once done, change the plugs as they are now likely fouled.
LinkBack to this Thread: http://www.sportbikes.net/forums/help-me-fix/387207-carbed-sv650-wont-run-without-full-choke.html
Help Me Fix It - Sportbikes.net This thread Refback 04-12-2008 04:37 PM
Full Exhausts & Bolt-Ons GSXR/SRAD Owners Only Need Apply MR.D Parts For Sale 0 03-05-2008 11:58 AM
Help! Rascus Tech Support - Computer Geeks-R-Us 32 09-14-2007 02:36 AM
John "DARREN-RIP 800LB-Gorilla" Hendrickson MEMORIAL North Run 03.18.07 SUNDAY simplydawn Fallen Riders 0 03-13-2007 02:21 PM
Poker run invite 2upfz1 Las Vegas 7 11-10-2004 01:25 AM
sensitive choke enos Help Me Fix It 7 10-19-2004 02:22 PM
