06 Ninja 250 won't stay running unless choke is open - Sportbikes.net
User Tag List
post #1 of 10 (permalink) Old 04-03-2008, 09:11 PM Thread Starter
Got Goose?
Goose Rider's Avatar
Quoted: 0 Post(s)
I have an 2006 Ninja 250 that I gotta admit, did not winterize properly. just charged the battery up and finally got it started..I can ride it with the choke partially open but it I close the choke the bike dies.....Gas in the tank maybe a year old..I did put some Stabil in a few months ago...put some Seafoam in today...
Carbs probably all gummed up? Seafoam help at all?
ideas? advice?
Can ride the piss out of the bike but once I turn the choke off.....dies..can idle all day with choke open a bit abut will not stay running with it off
Goose
Goose Rider is offline
post #2 of 10 (permalink) Old 04-03-2008, 09:28 PM
World Superbike Champion
kxl77's Avatar
Quoted: 0 Post(s)
Is this after the bike has warmed up or before?
kxl77 is offline
post #3 of 10 (permalink) Old 04-03-2008, 09:35 PM Thread Starter
Got Goose?
Quoted: 0 Post(s)
After..once I got it started I let it idle for quite a while
I rode it for about 20 minutes tonight with the symptoms I listed above
Goose
post #4 of 10 (permalink) Old 04-04-2008, 10:59 AM Thread Starter
Got Goose?
Quoted: 0 Post(s)
Did some research and appears the pilot or idle jet may be gummed up
Hoping the Seafoam may break it up a bit...hoping but not counting
Not to good with carbs so not looking at the prospect of shelling out 3 bills to have them broken down and cleaned..oh well my bad ....doh!
Anyone ever have any luck with the Seafoam?
Goose
post #5 of 10 (permalink) Old 04-04-2008, 01:34 PM
Making Horizons Vertical
dubbs693's Avatar
Quoted: 2 Post(s)
Garage
You should drain the tank first.. I'd try some fresh gas... But it may already be too late..
Weekend Car - 2003 Honda S2000 - Black
Daily Driver - 2013 Cadillac ATS 2.0 Turbo - Black
Sportbike/Cruiser/Enduro - 2013 Ducati Multistrada - Red
Beater - 2011 Toyota Prius - Black
dubbs693 is offline
post #6 of 10 (permalink) Old 04-04-2008, 02:18 PM
cbrenthus's Avatar
Quoted: 11 Post(s)
I would try fresh gas and run it quite a bit before taking it in.
cbrenthus is offline
post #7 of 10 (permalink) Old 04-04-2008, 07:05 PM
gboezio's Avatar
Quoted: 0 Post(s)
Gummed idle jet is definitely the most likely cause, but check the boot, spray some carb cleaner on the boot to see if the engine stumble.
gboezio is offline
post #8 of 10 (permalink) Old 04-04-2008, 07:45 PM Thread Starter
Got Goose?
Quoted: 0 Post(s)
fwiw I was able to get the bike to idle on it's own without having to use the choke today. Wasn't able to ride(pouring out) except for some 10 foot rolls in 1st gear but the important part was it didn't stall without the having the choke open. Looks like the Seafoam did it's job to a point! I'm thinking a fresh tank of gas and taking it for a decent couple of spins and I might be back in business...
I mean yesterday this thing sounded like it was on death's doorstep...today after sitting with the Seafoam in it overnight it had a miraculous recovery! Did all the things peeps said Seafoam would make it do(pour smoke out of the exhaust for a bit) but then it cleared up.
2 thumbs up for this stuff!
What is the idle of a Ninja 250? 1000-1500?
Goose
post #9 of 10 (permalink) Old 04-09-2008, 10:09 PM
Quoted: 0 Post(s)
You are on the right track. Try to get the carbs cleaned up and if that does not work check your valves. Valves that are not adjusted properly can cause a bike to run poorly. Go here to learn how to do a valve adjustment. How do I adjust the valves? - Ninja250Wiki On the Ninja 250 you can do this job yourself.
Jeff S.
KS
BadgerMan is offline
post #10 of 10 (permalink) Old 04-09-2008, 10:56 PM
Dental Rider
itch808's Avatar
Quoted: 0 Post(s)
definitely clogged pilot jets
2005 Titanium ZX-6R - Scorpion Slipon|PCIII|FactoryPro Shift Star|Powerbronze Rear Hugger|OES Sliders & Spools|TechSpec|HVMP|Flushmounts|ZeroGravity DB Windscreen|Grip Puppies|Jumper Mod
2003 ZX-6R -- SOLD | 2001 ZX-6R -- SOLD | 1997 ZX-6R -- SOLD
2001 MR2-S 2ZZ-GE Engine Swapped & Revving to 8600rpm -- SOLD
...Adjusting to my current home in Boston...missing Hawaii...
itch808 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Ninja 250 turns over but won't start. GoIllini Help Me Fix It 11 03-16-2009 09:09 AM
Ninja 205R - Kawasaki's best selling bike F4sSprintST Ninja 250R 31 05-06-2008 10:40 AM
2004 Ninja 250 help/suggestion zmeiaspas New Riders 10 03-03-2008 02:06 PM
Ninja 250 delima. Need advice ASAP Murder after Midnight General Sportbikes 19 02-21-2008 11:07 AM
Battle between GS500E/NINJA500R? BigK General Sportbikes 29 09-26-2007 12:15 PM
You may post new threads
You may post replies
Refbacks are Off
