McCoyMotorsports
JardineProducts.comAdvanstarMotorcycleShowsMotorcycle.com Classifieds!Tuck & Run Clothing CoAnnitori DistributingSportbikeTrackGearBikeBanditBluTek Helmets
Allstate
Soupy's PerformanceGravesMotorsportsCycleGear.comSee your ad here!
Old 02-19-2008, 10:37 PM   #1 (permalink)
kuzmi4
Casino Cash: $4165
Sportbike: 04 R6
kuzmi4 is on a distinguished road
Default Headlight problem.
noobish question, well here it comes:
i want to check if headlight is working is it ok to connect it directly to the battery? Cause now i'm not sure if its a headlight or headlight wiring issues.
The headlight does not turn on at all, could it be cause of brocken relay?
Oh, and i checked fuses - they are ok.
Thanks.
kuzmi4 is offline   Reply With Quote
Old 02-19-2008, 11:12 PM   #2 (permalink)
94rf900r
Your mom goes to college
94rf900r's Avatar
Casino Cash: $28405
Sportbike: 94 suzuki rf900r
if its a halogen then yes just remember not to touch the glas with your hand or it will blow out when you turn it on.
did you check both high and low beams? if niether work now and both worked before then its prolly some cennection issue, usuall the high or low blow out and one is still left. check the plug that plugs into the bulb mine vibrated loose a couple times and my light went out.
I wish my grass was emo so it would cut itself
Old 02-19-2008, 11:29 PM   #3 (permalink)
kuzmi4
Casino Cash: $4165
Sportbike: 04 R6
Idk if they are halogen or not. It should be stock 1 for 2004 R6.
high/low beas does not work.
well and the bike was set for track before, so headlight was taken off for some time.
Why would it blow anyway?
Old 02-20-2008, 11:28 AM   #4 (permalink)
2001FZ1
~ Master Technician ~
2001FZ1's Avatar
Casino Cash: $16301
Sportbike: 2005 Suzuki GSXR 1000 & 2004 Kawasaki Ninja 250
2001FZ1 is on a distinguished road
Bulbs can stop working because they get hit hard causing the internal parts to break. If the bulb tests good, start tracing wires and check all the connections. Use a meter to see where you are loosing power.
Joe
My Resume
Need a better riding position? Check out www.convertibars.com. They are great!
Past bikes: '82 Yamaha Maxim 750, '89 Kaw. ZX7, '94 Kaw. ZX9R, '01 Yamaha FZ1, 04 Kaw. EX-250 ~ over 12 years & 90,000miles of riding experience.
2001FZ1 is offline   Reply With Quote
Old 02-20-2008, 01:59 PM   #5 (permalink)
fishnride
John 18:33-37
fishnride's Avatar
Casino Cash: $22757
Sportbike: 05 Honda CBR600RR
fishnride is on a distinguished road
Rather than testing the lights by connecting to the battery, I'd use an Ohm meter to test for continuity. Safer that way, plus it's a great excuse to buy a Fluke multi-meter if you don't have one already.
"But seek first his kingdom and his righteousness, and all these things will be given to you as well." Matthew 6:33
Sensei Performance The Master of All of Your High Performance Needs
www.LawstCaws.com
fishnride is offline   Reply With Quote
Old 02-20-2008, 06:03 PM   #6 (permalink)
kuzmi4
Casino Cash: $4165
Sportbike: 04 R6
Oh dang, i wish i new how to do that.
CAn anyone please tell me what settings to put and what to do with connectors.
I have EMRR's Review: Misc - CEN-TECH - Model 90899 Multimeter
Is it gonna work?
Old 02-20-2008, 06:51 PM   #7 (permalink)
2001FZ1
2001FZ1's Avatar
Casino Cash: $16301
That meter will work fine to test for checking resistance of the bulb and for checking for +12volts.
Put on resistance setting (in ohms) and touch leads together. It should read zero or very close to it. Then read across bulb, it should read very low.
For voltage check, put on voltage setting and put one lead on +12volt line and the other on ground. Practice by reading across your battery. If you battery reads -12v, switch the leads around. Red is positive, black is negative.
Next time by a Fluke 73 or something similar. They are pretty cheap, very reliable and have auto level settings.....however, yours will work fine for most applications.
Joe
My Resume
Old 02-20-2008, 07:25 PM   #8 (permalink)
kuzmi4
Casino Cash: $4165
Sportbike: 04 R6
Thanks everyone for help.
Damn it, changed buld, there is power on the incoming connector, both headlight connectors seem to work, still no lights.
Aghrrrrrrrrrrr...
Headlight and Headlight Stay Install - HELP! TJPalmer6774 YZF-R6 1 02-08-2008 09:27 AM
Smoked headlight protectors CCHOUSEKY FZ6 58 02-07-2008 10:43 PM
Lights problem midnightlife85 Help Me Fix It 2 09-10-2007 10:18 PM
2007CBR600RR Problem! adrenalinchick97 Florida 11 08-24-2007 09:06 PM
2002 gsxr 1000 headlight not working 1wheelgixxer Help Me Fix It 2 08-04-2007 05:01 PM
