It actually got up to 65 here in the northeast yesterday! Popped the battery back in, but for some reason didn't remember to tighten down the -negative terminal.
The bike ran perfectly to work.
Upon leaving, the bike hesitated around 3-5k rpm,, and would not hold a consistent throttle input. It would surge slightly.
It also died on me once.
The problem seemed to go mostly away, and after tightening down the terminal i didn't get a chance to take it for a ride again.
Information:
-Tested the voltage across the battery (13.4-14.5V),,RR should be ok. The voltage dipped to 12.5V when the fan came on. Seems ok.
-Gas had been in there for 8 wks with no stabilzer (maybe a shot of water settled?)
-Air filter is not clogged
-Oil level ok
Could a loose terminal cause surging of any kind? Anyone ever had this problem? Thoughts?
I'd say it's VERY possible. If the connection to the battery is lost, the voltage is not constant and at the level it needs to be, it will definitely affect the way the bike performs.
It will absolutely do everything you described. I've had it happen on bikes as well as cars.
Most recently, i could not keep my truck running at idle for some reason. It had worked fine the day before. BUT- i had disconnected the battery cables because i left the hood up for a long time and didn't want it to die.
Well, the terminal was SO corroded that when i put it back on, it would not make contact anymore. A new terminal and all the symptoms went away.
And FYI, it would die whenever i put ANY electrical draw on the system. Even turning on the interior lights made the engine stall.
I had this exact same thing happen to me on my old 00 GSXR 750. Every once in awhile the bike would chug and stall on me. Finally in the middle of nowhere the bike died on me. Did a little investigating and found the negative loose. I tightened the negative and never had another problem with it.
You start out motorcycling with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
Some people are like slinkies; they're good for nothing but they still bring a smile to your face when you push them down a flight of stairs.
