SportbikeTrackGearMotoGiya.comAnnitori DistributingSoloMotoPartsCycleGear.comArnottAirRideBazzaz PerformanceNice CycleJazzMotorsports.comRacerPartsWholesaleSportbikeTrackGearSee your ad here!
Old 12-26-2007, 10:50 PM   #1 (permalink)
zeroplace
Casino Cash: $1187
Sportbike: 1993 Suzuki RF600R
zeroplace is on a distinguished road
Default Carb Sync help...
Is there any simple (can be done) way to manually sync my carbs with no manometer or sticks? I have tried the "build it yourself" tool with the yard stick and tubes but it just sucked water into my carbs. I just need to get them sync'ed. I am getting a carbon knock and my sylinders are fighting each other for fire. Please help.
Z
zeroplace is offline   Reply With Quote
Old 12-26-2007, 11:54 PM   #2 (permalink)
emw
IDDTD
emw's Avatar
Casino Cash: $22318
Sportbike: Sold
emw is on a distinguished road
1.) Try using a heavier liquid, like motor oil.
2.) You can try doing a bench sync. Take the carbs off a bike and get a guitar string (bum one off a musician friend or get one from the music store. I used the three thinnest strings of a six pack - mine had a green/purple/silver ball ends). What you want to do is slide the appropriately gauged wire underneath the butterfly valve and adjust the gap until you feel a slight resistance on the wire. The guitar string will slide in between the crack of the butterfly valve and the body of the carb. Try not to nick the surface of either. Do the same for each butterfly valve until they are all relatively at the same height/position.
This is not an entirely accurate way to sync the carbs, but it should be enough to get it to start and idle okay - more syncing will need to be done.
Originally Posted by Nightfall View Post
kickage of the derrier, that helmet is epic sauce winnage to the maximo bra!
emw is offline   Reply With Quote
Old 12-27-2007, 09:00 AM   #3 (permalink)
Veefer97
Casino Cash: $27389
Sportbike: 98 900RR
Water is heavier than oil
Get the carb sticks or pay someone to do it. It needs to be done right
Old 12-27-2007, 04:55 PM   #4 (permalink)
emw
IDDTD
emw's Avatar
Casino Cash: $22318
Sportbike: Sold
Poor wording - use a "thicker" liquid.
Old 12-28-2007, 01:29 PM   #5 (permalink)
Chris527
Chris527's Avatar
Casino Cash: $3587
Sportbike: 2005 FZ6 and a broken 2001 Ninja 250
Chris527 is on a distinguished road
Here is a link here to build a slightly more sophisticated home made manometer than the yardstick type one. Takes another trip to the hardware store but it wont suck fluid into the engine if the pressure difference is too big.
Hope that helps
Chris527 is offline   Reply With Quote
2006 Katana carb troubles BlackKat Help Me Fix It 5 04-16-2008 11:27 AM
Need to sync my carbs... matt500r Tennessee 1 04-17-2007 11:48 AM
7R Carb Synch. 777R ZX-7R 5 03-13-2007 08:34 PM
Carb. Synch. Question, did it for the first time today 777R Help Me Fix It 12 03-13-2007 10:10 AM
Carb Sync Jackal79 Help Me Fix It 1 06-27-2004 09:11 PM
