SportbikeTrackGear
JardineProducts.comCycleGear.comSportbikeTrackGear
Allstate
Motorcycle.com Classifieds!AdvanstarMotorcycleShowsBluTek HelmetsSoupy's PerformanceSee your ad here!
Old 11-18-2007, 09:12 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
jetblack3s
NoclUe
jetblack3s's Avatar
Casino Cash: $3113
Sportbike: 2008 Aprilia rsv1000r
jetblack3s is on a distinguished road
Default change my oil pan on my 04 zx6r
i was doing my oil change on my zx6r, i guess i tighten the drain plug too much the oil pan cracked. lol, now i need a new one, how hard is it to change the oil pan? do i need new bolts and gasket when i get a new or used oil pan? and where can i get one for cheap?
jetblack3s is offline   Reply With Quote
Old 11-19-2007, 12:25 PM   #2 (permalink)
Veefer97
Casino Cash: $52831
Sportbike: 98 900RR
You can fix the oil pan for $30
OK so you messed up. In your hurry to get the oil changed you applied too much torque and that sickening feeling of the plug turning without tightening is keeping you up at night. Have no fear, there is an easy fix. Easy if you have some basic mechanical knowhow. Of course you striped the threads so the basics are in question. Never mind, just follow the steps
1 Go to any decent auto parts store and buy the Thread Repair System ($30).
Hint: take the plug with you on the off chance that they carry multiple sizes
2 I prefer to lay the bike on its side as it is easier to work on. You do what you want.
3 Place grease on the tapping tool so that it may catch any aluminum chips.
4 Using a socket and ratchet thread the tool into the stripped hole until the tool goes in to the top of the second set of threads
5 Remove taping tool. See all of the chips on the tool. Aren't you glad that you put grease on the tool.
6 Clean out the hole of any chips. I used a dentists pick and some paper towels to drag any chips out. That would be beyond the hole. You may also want to flush the pan out with a cheap quart of oil or for you anal types just take the oil pan off and don't send me any nasty replies about how you did it better.
7 Clean any oil off the threads using the chemical of your choice. I also use a Locttite primer, nice but not necessary.
8 Select the proper lenght of insert by measuring thread depth.
9 Thread the insert on the first tapped portion of the tapping tool. The knurled portion of the insert should be the last part to go into hole. Look at the pictures on the box or the next photo
10 Apply locktite to insert
11 Thread the insert into the hole until it bottoms out with no threads of the insert outside the drain pan hole.
12 Place swager into the insert and strike with hammer to expand the knurled portion of insert
13 Put the drain plug back, you are done. Next time be more careful with aluminum threads
Veefer97 is online now   Reply With Quote
Old 11-19-2007, 06:29 PM   #3 (permalink)
jetblack3s
NoclUe
jetblack3s's Avatar
Casino Cash: $3113
i am not sure if you know what i meant, the oil pan cracked? not the bolt..
Old 11-19-2007, 08:04 PM   #4 (permalink)
Veefer97
Casino Cash: $52831
Sportbike: 98 900RR
Sorry, did not read post as close as I should have. You need a new or good pan.
Old 11-20-2007, 12:54 AM   #5 (permalink)
jetblack3s
NoclUe
jetblack3s's Avatar
Casino Cash: $3113
is the job difficult? i just need to put the bike on stand, and take out all the bolts holding the oil pan, then clean the edge, then install new pan and gasket right?
Old 11-20-2007, 01:15 AM   #6 (permalink)
Fred
Chief Booty Knocker
Fred's Avatar
Casino Cash: $28369
Sportbike: 2007 GSX-R600 Race / 2003 GSX-R750 Street
Fred will become famous soon enough Fred will become famous soon enough
Total Awards: 4
its not very hard at all to be honest. Look on ebay for a pan. Order a gasket and your all set. You can always go to Ron Ayers and order a new pan for a good price. Ron Ayers Motorsports - Motorcycle, ATV, Jet Ski and Generators Parts and Accessories
Fred
SBN Administrator & Webmaster
Sportbike - 2007 Suzuki GSX-R 600 Race Bike
Showparts - Sportbike Parts - Arata, Vortex, Pitbull, Videos, Undertails, T-SHIRTS, etc..
OnTheThrottleTV - Your Sportbike Video Source - AMA Coverage like you have never seen before
Fred is offline   Reply With Quote
Old 11-20-2007, 01:21 AM   #7 (permalink)
kevinwilly
former murder victim....
kevinwilly's Avatar
Casino Cash: $83676
Sportbike: None! Sold it!
kevinwilly will become famous soon enough kevinwilly will become famous soon enough
Total Awards: 4
What's it made out of?
If it's steel or aluminum you could take it someplace and have it welded. Then you could use the thread repair insert.
Most likely easier to just replace it, though.
And yeah- you'll need a gasket, some rtv for good measure- the red stuff works great for this, and a new oil pan.
Oh- and obviously new oil.
I can't remember exactly what you have to take out on the 636 to get the oil pan off... it's been a while since i worked on one. My GF has an 03 that i'll be riding this weekend. If you want, i can take a look and tell you exactly what you need to know. But honestly, i'm sure you can figure it out if you take your time.
Old 11-20-2007, 07:26 AM   #8 (permalink)
Veefer97
Casino Cash: $52831
Sportbike: 98 900RR
The exhaust system may have to come off. Sometimes the radiator needs to be loosened or removed as well in order to remove the exhaust. Not hard but time consuming. When you do get the new oil pan on and fill with oil, loosen the oil filter so that there is a slight gap between the oil filter gasket and engine case. As soon as the engine is started, oil will pour out of the gap. Shut engine off and secure oil filter. Kawasakis are prone to losing the oil pump prime and many people have toasted their engine due to it.
Old 11-20-2007, 10:18 AM   #9 (permalink)
marko138
Salty Old Buzzard
marko138's Avatar
Casino Cash: $1623
Sportbike: 2005 Buell XB12R
marko138 is on a distinguished road
Don't forget to get under the bike and scrape the old gasket material off of the crank case. If you don't you'll be doing this again...cuz that sucker will be leaking oil.
Marko138
When you grow up you'll buy a Buell.
marko138 is offline   Reply With Quote
Old 11-20-2007, 12:16 PM   #10 (permalink)
adamp961
adamp961's Avatar
Casino Cash: $19142
Sportbike: 94 CBR600F2 - sold, 99 ZX6R Wrecked (deer), 07 ZZR600 - sold
adamp961 is on a distinguished road
When you use the red rtv silicone, remember not to over due it. Lightly coat the gasket because if you over due it the extra will come out the sides and get into you oil system and maybe clog the oil pump or filter.
adamp961 is offline   Reply With Quote
Old 11-21-2007, 05:50 PM   #11 (permalink)
jetblack3s
NoclUe
jetblack3s's Avatar
Casino Cash: $3113
yes, sir, thank you very much!
LinkBack to this Thread: http://www.sportbikes.net/forums/help-me-fix/373826-change-my-oil-pan-my-04-zx6r.html
Help Me Fix It - Sportbikes.net This thread Refback 11-29-2007 08:44 AM
why my oil change cost me over $300 Magseal FZ6 45 11-13-2008 07:51 PM
Did an oil change in my F4i, now it won't start... OSUrid3r Help Me Fix It 13 11-13-2007 07:41 PM
new oil pan th12t33n Help Me Fix It 29 09-19-2007 10:37 PM
Oil Filter Change Frequency Lucky_Devil FZ6 24 06-02-2007 04:18 AM
Oil change without chainging the filter??? flip1199 General Sportbikes 21 05-19-2007 07:06 PM
