Tuck & Run Clothing CoSoupy's PerformanceGravesMotorsportsBikeBanditMcCoyMotorsportsBritish Motorcycle GearAdvanstarMotorcycleShowsCycleGear.comMotoworld IncSee your ad here!
Old 11-02-2007, 10:02 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
OSUrid3r
Track day addict
OSUrid3r's Avatar
Casino Cash: $1857
Sportbike: '02 CBR 600F4i, '07 600RR
OSUrid3r is on a distinguished road
Default Did an oil change in my F4i, now it won't start...
So I did a routine oil change in my '02 F4i with 12,000 miles and zero problems. Put 3 quarts in, started the engine to fill the filter, then topped it off to get the level between the indicators. Started the engine again and it idled really rough and at about 1000rpms. I thought maybe I overfilled it or something. Drained the oil and filter, put 3 new quarts in, and tried to start the engine again. This time, zero combustion.
So I pulled a plug and found it covered with oil. I looked inside the airbox and didn't see any oil at all... its totally clean. So I took all four plugs out, cleaned them up, tested them for spark by holding one on top of the engine and hitting the starter, then put them back in... there's spark, but no combustion.
What did I do to my bike? This is one mega mystery...
OSUrid3r is offline   Reply With Quote
Old 11-03-2007, 12:56 AM   #2 (permalink)
iaresev
Official SBN Bookie
Casino Cash: $27490
Sportbike: 05 600RR
iaresev is on a distinguished road
I'm not familiar with the bike but possibly there is a limp mode or similar? I know many cars if run with too low oil levels will disable themselves until some sensor is reset.
Check in your manual about this.
iaresev is offline   Reply With Quote
Old 11-03-2007, 09:03 AM   #3 (permalink)
Veefer97
Casino Cash: $52931
Sportbike: 98 900RR
It is not the oil change. Are you getting fuel to the cylinders? Does the fuel pump run when you use the starter?
Old 11-03-2007, 10:33 AM   #4 (permalink)
OSUrid3r
Track day addict
OSUrid3r's Avatar
Casino Cash: $1857
Fuel delivery is definitely working; the plugs are wet with gas after attempting to start it.
Old 11-05-2007, 04:07 PM   #5 (permalink)
Gilitar
Casino Cash: $5575
Sportbike: 2007 GSX-R600
Gilitar is on a distinguished road
Disconnect the battery for a bit and then reconnect. Then try to start it again.
Gilitar is offline   Reply With Quote
Old 11-05-2007, 04:32 PM   #6 (permalink)
Tuffguy #2
Speed Racer
Tuffguy #2's Avatar
Casino Cash: $7571
Sportbike: '02 F4i, '99 VFR, '99 1100xx
Tuffguy #2 is an unknown quantity at this point
<assuming you are new to bikes which may be wrong>
Did you fill it with the bike level or on the kickstand? Meaning, the sight glass only works if the bike is upright.
Ron Paul supports the John Birch Society
Video of RP talking at the JBS 50th anniversary. http://www.jbs.org/index.php/about/jbs-50th-anniversary
Advocating personal responsibility and less government for decades, with no political affiliation.
www.jbs.org
http://www.takeyourmoneyback.com/
Tuffguy #2 is offline   Reply With Quote
Old 11-05-2007, 05:59 PM   #7 (permalink)
Smooth7
make wheelies
Smooth7's Avatar
Casino Cash: $5069
Sportbike: 2003 CBR 954RR, ex250 track slut
Smooth7 is on a distinguished road
pretty sure an F4i holds closer to 4 quarts than 3.....
disclaimer: anything i say can be wrong. anything i say in the above post cannot and will not be used against me. all comments void after 24 hours. under some circumstances i may be lying. under other circumstances, comments may be full of shit. use your best judgement. i am not at fault for any harm or death caused to you or your loved ones.
$1 for my thoughts
Originally Posted by Smooth7
Arguing with a fool only proves there are two.
Smooth7 is offline   Reply With Quote
Old 11-05-2007, 10:22 PM   #8 (permalink)
OSUrid3r
Track day addict
OSUrid3r's Avatar
Casino Cash: $1857
Its level on a rear stand. Yeah, it holds about 3.5qts if you change the filter... you have to fill it then crank the engine to fill the filter, etc, then finish filling it. I haven't been able to finish it yet... but I got new plugs today and hopefully I can get out to the garage early enough to see if they work tomorrow morning.
Old 11-12-2007, 03:41 PM   #9 (permalink)
OSUrid3r
Track day addict
OSUrid3r's Avatar
Casino Cash: $1857
Well, two and a half weeks later its finally working. I cleaned out about 32 liters of oil from the cylinders then cranked it for awhile and it finally started. So I went out riding with no fairings and it was great! Thanks for the help
Old 11-12-2007, 04:32 PM   #10 (permalink)
hondajunkie
Yes I'm a FIB
hondajunkie's Avatar
Casino Cash: $10834
Sportbike: 2001 Honda CBR600F4i
hondajunkie is on a distinguished road
How the hell did all that oil get into the cylnders?
Unless u REALLY overfilled the crankcase.......
"She always brings me what I need, without I beg and sweat and bleed......Queensryche/Operation Mindcrime/Spreading the Disease 2001 Honda CBR600 F4i
Miquel Duhamel replica
hondajunkie is offline   Reply With Quote
Old 11-13-2007, 08:33 AM   #11 (permalink)
yamirider
I want to ride again :(
yamirider's Avatar
Casino Cash: $15912
Sportbike: Sold :(
yamirider is on a distinguished road
You should have been blowing warm fronts of blue smoke if you had that much oil in your cylinders.
yamirider is offline   Reply With Quote
Old 11-13-2007, 12:47 PM   #12 (permalink)
Tuffguy #2
Speed Racer
Tuffguy #2's Avatar
Casino Cash: $7571
32 liters? The bike is only a 0.6L bike! LOL
www.jbs.org
Old 11-13-2007, 12:59 PM   #13 (permalink)
mikem317
You got that right.
mikem317's Avatar
Casino Cash: $18219
Sportbike: Honda CBR600 F4i *sold*
mikem317 will become famous soon enough
Green Token: Green SBN Token - Issue reason:   Yellow Token: Yellow SBN Token - Issue reason:
Total Awards: 2
32 liters? Maybe 3.2 liters?
Regards,
Mike
mikem317 is offline   Reply With Quote
Old 11-13-2007, 07:41 PM   #14 (permalink)
OSUrid3r
Track day addict
OSUrid3r's Avatar
Casino Cash: $1857
Well.. maybe it was more like 7 fluid ounces, but it seemed like the entirety of BP's oil refining industry at the time
LinkBack to this Thread: http://www.sportbikes.net/forums/help-me-fix/372646-did-oil-change-my-f4i-now-wont-start.html
Help Me Fix It - Sportbikes.net This thread Refback 11-12-2007 05:31 PM
To change or not to change (the oil) LarryC FZ6 24 10-11-2007 10:47 PM
help with oil change on pocket bike. fazer512 Pocketbikes 1 10-03-2007 01:08 PM
Help on an oil change FookEmAll Suzuki Sportbikes 12 06-02-2007 09:38 PM
Bought new FZ6- oil change question Yamaha Elwood FZ6 18 05-29-2007 12:15 PM
oil change on 92 GSXR 600 help! Miniguinea1705 Help Me Fix It 3 05-10-2007 09:56 AM
