SportbikeTrackGearMotoGiya.comAnnitori DistributingSoloMotoPartsCycleGear.comArnottAirRideBazzaz PerformanceNice CycleJazzMotorsports.comRacerPartsWholesaleSportbikeTrackGearSee your ad here!
Old 09-10-2007, 05:01 PM   #1 (permalink)
Harsh
Harsh's Avatar
Casino Cash: $4211
Sportbike: 2002 SV650S
Harsh is on a distinguished road
Default Leaking Bleeder Screw
I have a problem with lever travel. When I pull the lever it goes about half way before it engages. The lever has felt like this since I put the gsxr front end on my bike (mid April). I just finally decided to get the lever to where I wanted it to be. Right now I have the lever set all the way out so that it won't make contact with the grip when it is fully squeezed. Any other position and the lever will touch the grip when fully squeezed. The stopping power is great once it engages, but it just takes too long to get there.
I have an 99 GSXR 750 front end on my bike (02 Suzuki SVS) which has the 6 pot calipers and has steel braided lines.
Upon the suggestion of some friends I went out and bled the piss out of the brakes (filled the reservoir twice) and the lever was in the same place. So completely distraught I decided that there was something else wrong. I was cleaning up and noticed there was a little fluid on the threads of the bleeder screw. So I took a rag and wiped it off. Just as I was removing the rag I noticed a little bubble of fluid come from where the bleeder screw goes into the caliper. The bubble that I see is extremely small and you would be hard pressed to see it if you weren't looking for it. I made sure the screw was tight, which it was. I watched for a bit and I could see a little bubble every now and then.
What do I do? Do I have to replace the caliper, the bleeder screw, coat the screw threads in something?
Harsh is offline   Reply With Quote
Old 09-10-2007, 06:58 PM   #2 (permalink)
iwannagofast
iwannagofast's Avatar
Casino Cash: $100
Sportbike: 04 gsxr 600, 07 gsxr 1000
iwannagofast is on a distinguished road
use teflon tape.
iwannagofast is offline   Reply With Quote
Old 09-10-2007, 08:57 PM   #3 (permalink)
Veefer97
Casino Cash: $27389
Sportbike: 98 900RR
Teflon tape will not work as the threads are not the sealing component of the system. You may have to replace the bleeder screw. It has a taper at the end and that gets jammed into the caliper. If the taper is corroded then there is a path for fluid to go through the bleeder screw. Your soft lever may be caused by a mismatched master cylinder to calipers. Another cause of soft lever is improper bleeding. To bleed the master cylinder, bleed brakes normally then remove the master cylinder from clip on. Hold master cylinder horizontally and slowly squeeze the lever. A bubble will come out into the reservoir. That buble was traped inside the master cylinder between the hole in the banjo bolt and the top of the cylinder.
Old 09-11-2007, 03:29 PM   #4 (permalink)
Harsh
Harsh's Avatar
Casino Cash: $4211
Thanks Veefer I will give that a try. I have heard of air getting trapped there, but it is usually gone after a couple of refills of the mc.
Old 09-11-2007, 03:43 PM   #5 (permalink)
Liquids
Liquids's Avatar
Casino Cash: $9986
Sportbike: Ninja 250 - Official bike of SBN - modded to 232cc
Liquids is on a distinguished road
I've used teflon tape for that problem before on my rear caliper and it worked great.
Liquids is offline   Reply With Quote
Old 09-11-2007, 04:40 PM   #6 (permalink)
Veefer97
Casino Cash: $27389
Sportbike: 98 900RR
Did you place the teflon tape over the tapered portion? Just curious as I was thinking of placing it over the threads but that should not work. While that may work I would rather buy a new bleeder screw.
Old 09-11-2007, 04:42 PM   #7 (permalink)
Liquids
Liquids's Avatar
Casino Cash: $9986
just over the threads. it actually suggests to do that in my factory shop manual
Windshield Screw replacements arshishb FZ6 9 05-12-2007 06:12 PM
Leaking gas problem squaly Help Me Fix It 8 01-21-2005 02:12 PM
leaking oil..... heyboy Help Me Fix It 1 10-10-2004 06:44 PM
leaking fuel from my GSXR freeflyer52 Help Me Fix It 4 09-04-2004 04:36 AM
Puig Windscreen - Not exact fit - Broken screw C.K. FZ6 2 08-28-2004 12:43 AM
