'97 gsxr 750..carb problems - Sportbikes.net
User Tag List
post #1 of 14 (permalink) Old 07-21-2007, 03:11 PM Thread Starter
Quoted: 0 Post(s)
Angry '97 gsxr 750..carb problems
i have a 97 gsxr750 .. hd carbs cleaned when i bought it a few months ago. the dealer said the diaphrams were stuck.revs fine in nuetral but now it runs like crap below 4000rpm..taking off sucks, you have to feather the clutch or it wants to die. this is really making me hate riding for the time being...talked to several others and they said all gsxrs run bad under 4000rpm..not what i wanted to hear..a change to fuel injection is out of the question due to finances as well as i hear its a huge job..wiring and everything..any help greatly appreciated....i am so pissed i am thinking about selling the bike..thanks again in advance
the only perfect person was crucified....the rest of us all have problems...
ooopster is offline
post #2 of 14 (permalink) Old 07-21-2007, 09:05 PM
World 500 GP Racer
Quoted: 0 Post(s)
Sounds like the guy who cleaned the carbs needs to do it again properly.
Veefer97 is offline
post #3 of 14 (permalink) Old 07-21-2007, 09:10 PM
rebel litre
leemajaz's Avatar
Quoted: 0 Post(s)
sounds like you need them to be properly jetted. i don't think the mechanic did a good job with the reinstall.
current bike:2000 gsx-r600
previous bikes:77' kz650b-86'vfr interceptor 500 v4-
88'kawasaki ninja zx6-a(gpz)-
myspace.com/elboogiey
Originally Posted by jim schmidt View Post
I'm not feeling it. Sorry, but a buddist in the family doesn't make you open-minded. It just means you're bangin' a buddist.
Originally Posted by zx6rracer View Post
race had everything to do with why he got elected. it was NOT about the issues. do you realize how many ******s are going around with their hip hop attitudes celebrating cause they got a mulatto elected?
leemajaz is offline
post #4 of 14 (permalink) Old 07-21-2007, 11:35 PM
fireball8716's Avatar
Quoted: 1 Post(s)
I got the book on my bike, took the carbs completely apart, cleaned them and replaced some of the parts because they were deteriorating due to it being twenty years old. It will take a couple hours, but you'll learn a lot from doing it, and I found it pretty easy to do with the manual.
fireball8716 is offline
post #5 of 14 (permalink) Old 09-03-2007, 10:55 AM
Quoted: 0 Post(s)
carb problems
Hi, did you ever fix the problem with your bike where it would rev fine in neutral but when starting from a stop it ran like crap? I am having the exact same problem and was wondering if you ever got it fixed. Dont believe anyone who tells you these bikes normaly run this way. Thanks for any info.
need4machspeed is offline
post #6 of 14 (permalink) Old 09-03-2007, 04:09 PM
World 500 GP Racer
Quoted: 0 Post(s)
You may have to syncronise the carbs.
Veefer97 is offline
post #7 of 14 (permalink) Old 09-03-2007, 11:24 PM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
Synchronization of the carbs really only affects idle and off idle throttle response. Once the plates are open, it almost negates the effect of synchronization.
Pain, necessary to know.
Redstar11 is offline
post #8 of 14 (permalink) Old 09-04-2007, 07:27 AM
World 500 GP Racer
Quoted: 0 Post(s)
Synconization affects the full rpm range but is most noticable at low rpm since one of the cylinders is doing most of the work. Since his problems are mostly off idle with symtoms of poor power, synchronization should be looked at.
Veefer97 is offline
post #9 of 14 (permalink) Old 09-04-2007, 11:34 AM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
I disagree, synch'ing carbs opens the throttle plates to a certain degree around 15-25 degrees or so in relation to one another. The adjustments are very minute, unless the throttle plates are somehow extremely mal-adjusted. However, once the plates are open, due to the pitch of the throttle plates, and the change of restriction of airflow past the throttle plates, the effect of synchronization rapidly disappears. It is the same reason there is a much larger difference in throttle response/engine response from 0-1/2 throttle, as there is from 1/2 throttle to WOT.
However, I do agree that since his problems seem to the rooted at RPMS under 4000 RPM, he does need to check his synch, make sure the carbs are completely unrestricted, and verify that all of his vacuum slides are functioning properly.
post #10 of 14 (permalink) Old 09-04-2007, 12:42 PM
World 500 GP Racer
Quoted: 0 Post(s)
In synchronization the throtle plates are adjusted so that all the cylinders have the same vaccum. This means that each cylinder producess the same amount of power as the rest. The full throtle range is effected by synchronization however one may not notice the symtoms at high rpm because they are masked due to the power that is produced by the strong cylinders that are carying the weak cylinders. This unsynchronized condition leads to a power loss but as I stated it is not noticable in everyday riding at a higher RPM.
As for the difference in in throtle response from 1/2 to WOT there is much more going on than just throtle position such as inertia of the recipricating parts and at which point on the horsepower curve you are located at. Cam and ignition timing as well as cam overlap also are a huge contributer to the spooling up of an engine.
Veefer97 is offline
post #11 of 14 (permalink) Old 09-04-2007, 06:58 PM
Superbike Champion
768-Ryda's Avatar
Quoted: 0 Post(s)
sound like you need to rejet the bike again, might want to let someone with alittle more knowledge take a look at them carbs for ya
04 Kawasaki ZX 636
pc111 with custom map
ram air mod, k&n filter with airbox mod
factory pro ignition advancer, d&d shorty exhaust
lowered, stretched, geared
768-Ryda is offline
post #12 of 14 (permalink) Old 09-05-2007, 01:44 PM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
Try hooking up a vacuum gauge up to a set of carbs and hold the bike at 1/4 throttle. See how little difference adjusting the synch screws has on vacuum when the throttle plates are open.
post #13 of 14 (permalink) Old 09-05-2007, 03:49 PM
World 500 GP Racer
Quoted: 0 Post(s)
I have. It makes a difference in airfow and volume
Veefer97 is offline
post #14 of 14 (permalink) Old 09-05-2007, 05:47 PM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
OK, well I have to, on a number of different bikes, a number of different times. We will just have to agree to disagree.
On another note, I used your Honda CCT trick the other day on a customers bike. Works great!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Major Problem w 2004 gsxr 750 trifle66 Suzuki Sportbikes 3 06-05-2007 09:16 AM
03 GSXR 750 forks & lower triple SVmike Parts For Sale 0 02-03-2007 05:29 PM
01 gsxr 750 clean title damaged rickmancc Bikes For Sale 0 10-19-2004 06:18 PM
97 GSXR 750 Custom Paint--Tampa, Florida Blue Bikes For Sale 4 10-11-2004 01:17 AM
STOLEN GSXR 750 OHIO red/silver/black Shaigirl General Sportbikes 8 10-06-2004 03:52 PM
You may post new threads
You may post replies
Refbacks are Off
