My chain is making noise - Sportbikes.net
User Tag List
post #1 of 13 (permalink) Old 06-23-2007, 02:04 PM Thread Starter
yama-ryder
Quoted: 0 Post(s)
my chain is making a clakking noise whenever i put power on the throttle.
it doesn't do it so bad when cruising or at high speed. i tried tightening it
and that didn't work. i am an experienced rider, this is my fifth bike, but i have never had a chain do this. is my sprocket bent? could it be a frozen link in the chain? someone help!
motodrummer35 is offline
post #2 of 13 (permalink) Old 06-23-2007, 02:41 PM
Mess with the Bull.....
L8 Braker's Avatar
Quoted: 159 Post(s)
Clean it?..Lube it?...Sprocket teeth getting shorter?...Kinks?
Whatever you do, don't make it too tight..
SBN Moderator
to PM me with any questions or concerns
L8 Braker is offline
post #3 of 13 (permalink) Old 06-23-2007, 02:48 PM
World Superbike Champion
taino's Avatar
Quoted: 0 Post(s)
I had the same issue once, kinda like a Crunchy sound at take off and slower speeds. Turns out the chain was dry. Lubed it up, noise gone.
But still check for proper tension and teeth on the sprockets
taino is offline
post #4 of 13 (permalink) Old 06-23-2007, 05:58 PM Thread Starter
yama-ryder
Quoted: 0 Post(s)
tried that
i tried lubing it, noise is still there. only when the bike is under load, if it is on
the center stand, the noise isn't there.
post #5 of 13 (permalink) Old 06-23-2007, 06:02 PM
Andy Bell is my hero.
Justin726's Avatar
Quoted: 236 Post(s)
How many miles on the chain?
Mine is doing the same thing, and I am right about at the mileage that I usually put on a new chain.
SUPER MODERATOR
Maturity is vastly overrated.
Don't let it get in the way of a good time.
Best piece of advice,
Justin726 is online now
post #6 of 13 (permalink) Old 06-23-2007, 11:06 PM
slckeys's Avatar
Quoted: 0 Post(s)
Did you check your rear sprocket? My old bike made a clunking noise whenever I would get on it pretty hard. Turned out I was actually hearing it break a sprocket tooth off every time I did that and it was starting to skip on the rear sprocket.
'99 in pieces...
'05 always going.
slckeys is offline
post #7 of 13 (permalink) Old 06-24-2007, 10:10 AM
User Name's Avatar
Quoted: 1 Post(s)
If it's clunking and popping and it won't go away with lube, it's time to change it, especially if it's got any significant miles on it. Mine lasted about 25,000 miles before it started to make any significant noise, I nursed it along with plenty of lube for another 3,000, but that was it.
User Name is offline
post #8 of 13 (permalink) Old 06-25-2007, 06:31 AM Thread Starter
yama-ryder
Quoted: 0 Post(s)
25,000 miles on it. i just ordered the new chain and sprocket kit. i found it was missing one of the bushings covering the link, so there is no contact with the sprocket at that link. can i still ride it to work or should i leave it in the garage? i have owned/ridden a lot of bikes, never encountered this. i'm probably gonna leave it at home considering i haven't even had it a week yet. thanks for all the help guys!
post #9 of 13 (permalink) Old 06-25-2007, 12:02 PM
User Name's Avatar
Quoted: 1 Post(s)
If you don't have to ride it, don't. I know it's tough to have a bike in the garage and have to take a car, but a lot can be damaged by a snapped chain. If you have to ride it to the dealer to have the chain riveted, just be very easy on it.
post #10 of 13 (permalink) Old 06-25-2007, 12:19 PM
L8 Braker's Avatar
Quoted: 159 Post(s)
DO NOT RIDE IT!!!
It's not worth the risk...
Among other things that can go wrong..
--it could break and the part that's still going towards and through the front sprocket could damage lots of expensive things
--if it breaks, it might get stuck and cause your wheel to lock up, which means you're probably going down
SBN Moderator
post #11 of 13 (permalink) Old 07-02-2007, 12:52 AM Thread Starter
yama-ryder
Quoted: 0 Post(s)
replaced the chain and rear sprock, new front sprock on the way. noise is gone. by the way, when should i shim my valves? is there a good way for me to tell or do i go by mfg suggestion?
post #12 of 13 (permalink) Old 07-02-2007, 01:14 AM Thread Starter
yama-ryder
Quoted: 0 Post(s)
by the way, thanks for all the help guys
There are two kinds of riders, those that have been down and those who are gonna go down. Which are you?
post #13 of 13 (permalink) Old 07-02-2007, 02:16 AM
RayOSV's Avatar
Quoted: 1 Post(s)
25,000 miles on a chain/sprocket set is a lot. Yours lasted as long as it should.
Valves on bikes tend to get tighter with wear so don't make noise until one gets smashed by the piston. Check your valve clearance if you don't know when it was last checked and change the shims as indicated. From there check it at suggested intervals.
RayOSV is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
DuPont Teflon Chain Lube PCHbreeze General Sportbikes 77 12-24-2009 11:49 PM
Chain noise rs50asu Help Me Fix It 6 06-01-2007 10:45 PM
New chain and sprockets, interesting noise... Boudreaux Help Me Fix It 15 02-20-2007 10:31 PM
Chain Noise Phly6 Help Me Fix It 2 09-04-2004 01:34 PM
Front sprocket/new drive chain engagement noise G T Help Me Fix It 3 08-27-2004 01:31 PM
You may post new threads
You may post replies
Refbacks are Off
