British Motorcycle Gear
AdvanstarMotorcycleShowsMcCoyMotorsportsCycleGear.comBritish Motorcycle GearMotorcycle.com Classifieds!SportbikeTrackGearMotoworld IncAnnitori DistributingTuck & Run Clothing CoSee your ad here!
Old 06-11-2007, 01:32 PM   #1 (permalink)
chris1998
chris1998's Avatar
Casino Cash: $3261
Sportbike: 2002 Honda CBR F4I
chris1998 is on a distinguished road
Default 98Yamaha YZF600 throttle situation
I am having some throttle sticking issues when I stop at stop lights. It always sticks between 2500 and 3500 rpm. IF I rev it up the throttle will stick for a few seconds then drop back down slowly. Also after I come to a stop, and its sticking, after about 5 seconds it will slowly come back down as well. It seemed like if I put some force on the throttle grip and tried to twist itfurther than the stop, that it would also drop in rpms a little bit. But I am not sure if thats just a coincidense or not. The throttle feels nice and smooth and its not hanging up anywhere. Any ideas?
chris1998 is offline   Reply With Quote
Old 06-11-2007, 02:24 PM   #2 (permalink)
Noltz
The Quiet One
Noltz's Avatar
Casino Cash: $350
Sportbike: Old skool Gixxer
Noltz is on a distinguished road
Sounds like you have a vacuum leak! It would explain all the problems you're having. I'd check on that, and if no fault found, pull the airbox and make sure the plates are closing all the way. Turn your bars left-right and see if the RPMs jump or drop, indicating a hanging cable somewhere.
Good luck!
-Noltz
Noltz is offline   Reply With Quote
Old 06-11-2007, 03:01 PM   #3 (permalink)
Lady Sprocket
Lady Sprocket's Avatar
Sportbike: Yamaha FZR 600r
Lady Sprocket is on a distinguished road
I can't remember if the 98 is carbed or not...but if it is I would suspect the carbs are getting "hung up" & need cleaning.
Otherwise I would try lubing the throttle cable if it hasn't been done for a long time.
I have 600cc between my legs, what could you possibly have to offer me?
Lady Sprocket is offline   Reply With Quote
Old 06-12-2007, 10:28 AM   #4 (permalink)
zzr-jason
Casino Cash: $8653
Sportbike: 2007 kawi. zzr600
zzr-jason is on a distinguished road
Give us a little more info. Does the bike have a jet kit ?, was there any service work just performed ?, does the bike sit outside ?, did it just happen or has it been getting worse over time?
zzr-jason is offline   Reply With Quote
Old 06-14-2007, 02:14 AM   #5 (permalink)
chris1998
chris1998's Avatar
Casino Cash: $3261
I just got the bike about 2 months ago. I turned the idle down to about 1000 rpms and its not doing it anymore. As for the jet kit I have no idea, and the bike sits inside.
Another thing I noticed though was when you get on the throttle and rev it up, it bogs down a little bit. I wonder if the the air/fuel mixture needs adjusted, or if the carbs are out of sync a little bit.
Old 06-14-2007, 01:50 PM   #6 (permalink)
Lady Sprocket
I should have thought about the idle...as odd as it sounds I got defensive a few days ago when my RPM's were hanging a bit, but then I turned my idle down a tad & it hasn't done it since, LOL!
I know when I'm running low on fuel and I go for a wheelie (lots of sudden throttle) mine will bog out instead of getting the power, I call it "falling on it's face"...so it may be your mixtures like I mentioned earlier being a bit off if you have eough fuel in your tank.
A guide for learning wheelies. Justin726 Stunterz Corner 176 10-20-2009 02:44 PM
Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) FZ6R FZ6 524 04-04-2009 08:03 PM
"Wheelies 101" brentsR6 Stunterz Corner 8 07-10-2008 10:21 PM
Throttle lock/Vista Cruise install Craigmri FZ6 Mods 0 05-13-2007 11:48 PM
i can't wheelie! Mucho Gonzales General Sportbikes 62 09-13-2006 02:34 PM
