SportbikeTrackGear
SportbikeTrackGearGravesMotorsports Motorcycle.com Classifieds!British Motorcycle GearSoupy's PerformanceMcCoyMotorsportsAnnitori DistributingBikeBanditSee your ad here!
Old 06-06-2007, 08:59 PM   #1 (permalink)
Bee_TX
Bee_TX's Avatar
Casino Cash: $3121
Sportbike: 2003 Suzuki GSX-R600 Alstare Edition (stolen 10-19-06)
Bee_TX is on a distinguished road
Default '03 GSXR600 Secondary Throttle Porblem, help!!!
OK, I'm at the wit end of the problem I'm trying to solve. I have a '03 600 that has problem with the Secondary Throttle. The code is C28 and C29. Here's what I've done so far:
1. Tried 3 different Throttle Bodies, same codes.
2. Tried 2 different ECU (PN. 32920-39FD0), one gives me a -C28, -C29, the other one gives me a _C28, _C29 on the same throttle bodies.
3. Unplugged the STV actuator and checked for voltage coming from the ECU on start-up, got 0V (supposed to be 5.6VDC)
4. Checked for open or short on the wires...all good.
5. Did some research, and on some bikes, there is a STC module (PN. 32910-39F00) that is plugged into the connector by the diagnostic port. I have that too, and it doesn't do anything while it's on or off the bike.
6. Applied some voltage to the STV actuator on all 3 throttle bodies I have and they moved, so they shouldn't be bad.
Currently the bike runs, just won't go past 9500 RPM. So, can the 2 ECUs I have be bad? I don't want to bring the bike to stealership and get charged $650 for a new ECU. I need a known good ECU to verify that it's the problem. What's your suggestion or pointer on something I might have missed? Or anyone living in Rowlett-Garland, TX area that can stop by and let me borrow and plug it in to see if the throttle bodies come to life? Thanks
Bee_TX is offline   Reply With Quote
A guide for learning wheelies. Justin726 Stunterz Corner 176 10-20-2009 02:44 PM
Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) FZ6R FZ6 524 04-04-2009 08:03 PM
"Wheelies 101" brentsR6 Stunterz Corner 8 07-10-2008 10:21 PM
i can't wheelie! Mucho Gonzales General Sportbikes 62 09-13-2006 02:34 PM
How to do all the wheelies explained dennisred69 Stunterz Corner 2 01-16-2005 05:27 AM
