Register Subscribe Casino Garage FAQ Members List Calendar Arcade Blogs Search Today's Posts Mark Forums Read
Sponsored by: Leo Vince Racing
Bazzaz PerformanceCycleGear.comBritish Motorcycle GearBikeBanditPartsPitStopSee your ad here!
Old 04-19-2007, 08:44 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
manatee
Gameroom cash: $450
Sportbike: 2000 Suzuki GSX-R600
manatee is on a distinguished road
Default Oil leak from water pump?
Hi all,
I bought a used 2000 GSXR 600 about a year ago. It has dripped oil very slowly since then. After an hour of riding, there would be a drop of oil on the bottom of the drain plug. If I let the bike sit overnight, there might be a single drop on the ground. This would continue whether I rode the bike or not.
Over the last couple weeks, I've let the bike sit in my garage to see if I could pinpoint the drip. I checked everything I could see once I took off the plastics, lifted the tank, and removed the coolant reservoir. The engine block is dry, and so is the casing / joint around the generator cover. The drain plug isn't leaking either.
After a day or so, the only place I can see oil beginning to pool up is on the bottom of the water pump. Everything else I can see, except the clutch assembly area, is still dry.
Is it possible for a water pump to leak oil? Or is something above it more likely leaking and then the oil is running down and collecting on the bottom of the water pump?
I've included a couple pics that show the view as I'm lying under the bike. The red arrow shows the point where the drop of oil forms on the bottom of the water pump. The yellow arrows mark the seam in the pump where oil is also collecting (over the course of a day or so).
Any ideas would be greatly appreciated. I'll probably have to take the bike in to the shop to get it fixed since this is out of my skill and available tool range.
Thanks for your help!
manatee is offline   Reply With Quote
Old 04-19-2007, 08:54 PM   #2 (permalink)
Justin726
Andy Bell is my hero.
Justin726's Avatar
Gameroom cash: $90357
Sportbike: 2003 Hayabusa, '04 KX250 (for the dirt)
Justin726 has a spectacular aura aboutJustin726 has a spectacular aura about
Since there is no oil in your water pump, it can't be coming from the pump housing itself. It's probably not the gasket your arrows are pointing to. The water pump slides into the side of the engine where it mates up with the "driving unit" that spins the water pump. Well the shaft part of the water pump (that slides into the engine) has an O-ring on it to seal against the hole in the side of the engine (to keep the oil from leaking out). I'm guessing it's probably that O-ring is bad and that is causing the leak and running down the back side of the water pump where you are seeing it. I actually just replaced my exact O-ring on my Busa 2 days ago. I had the same type of very slow leak. I haven't had time to test it to see if it completely fixed the problem, but from what I could find out on the Hayabusa boards, the O-ring was my problem. Your water pump looks identical to mine, so I'm assuming the setup is very similar. Hopefully somebody can verify this or tell me I'm full of shit.\
This is the best picture I could find of a 600 water pump. It is from an older version but it shows the O-ring on the shaft very well. Talk to your techs at the dealer and see if they think that might be the problem. Good luck.
SUPER MODERATOR
Maturity is vastly overrated.
Don't let it get in the way of a good time.
Best piece of advice, WEAR YOUR LEATHER
Justin726 is offline   Reply With Quote
Old 04-20-2007, 11:37 AM   #3 (permalink)
Veefer97
Gameroom cash: $73602
Sportbike: 98 900RR
Could the leak be from the transmition shaft seal (behind the front sprocket)?
Old 04-20-2007, 04:16 PM   #4 (permalink)
manatee
Gameroom cash: $450
Thanks for the pic of the water pump shaft! It sounds like that could very well be the problem. I'll definitely ask them if that's the likely problem. I'll also ask them about the transmission shaft seal.
Old 05-23-2007, 02:33 PM   #5 (permalink)
manatee
Gameroom cash: $450
It's all fixed now. It was the O-ring!
Old 05-23-2007, 02:40 PM   #6 (permalink)
Justin726
Justin726's Avatar
Same as mine. Good to hear you're back up and running.
SUPER MODERATOR
Old 05-23-2007, 02:48 PM   #7 (permalink)
Choco
mmm mmm good...
Choco's Avatar
Gameroom cash: $20706
Sportbike: '03 R6
Choco has disabled reputation
had the same problem on my 6 as well.....think theres an old thread here somewhere.
Old 06-20-2007, 12:23 PM   #8 (permalink)
dpthdiver
Gameroom cash: $34297
Sportbike: 94 Kawasaki ZX11
dpthdiver is on a distinguished road
I used this thread and fixed my 94 ZX-11. Thanks!
dpthdiver is offline   Reply With Quote
Old 06-20-2007, 04:55 PM   #9 (permalink)
Justin726
Justin726's Avatar
Glad we could help. That's what we're here for.
SUPER MODERATOR
Old 07-03-2008, 03:04 PM   #10 (permalink)
DUX
Gameroom cash: $851
Sportbike: GSX-R 750
DUX is on a distinguished road
Same issue with mine.
Guy sold it to me claimed there were no leaks. When I got it home and pulled the fairings, the oil pan had been wiped clean.
One small drop of oil would seep out every few days and collect on the drain plug. Not enough to worry about, but I still wanted it fixed.
Thanks to you guys and the posts. I took it up to my local speed-shop and we pulled the water pump. Like I said, bottom of the engine was wiped clean but a lot of crud was behind the water pump b/c he couldn't reach it. Sure enough, the o-ring was pinched, probably at the factory.
New o-ring, fresh oil, and labor.....$20. No more leak. Good deal on the bike b/c he was dumping it...priceless.
DUX is offline   Reply With Quote
LinkBack to this Thread: http://www.sportbikes.net/forums/help-me-fix/350545-oil-leak-water-pump.html
GSX-R Oil Leak - MotorcycleAddicts.org This thread Pingback 07-08-2008 06:09 PM
oil leak cypee Speed Four 3 04-04-2007 11:14 AM
Went down and now oil leak..... nxtxracer Help Me Fix It 1 01-01-2005 04:05 PM
oil leak! help wickedninja ZX-7R 2 09-14-2004 08:16 PM
Contest! Oil Leak and Gas Leak?!?!?! superman89 FZ6 11 09-10-2004 01:19 PM
help...water from radiator directly in the oil sump..... hori Help Me Fix It 4 08-21-2004 11:59 PM
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
