SportbikeTrackGear
KomodoGear.comAdaptiv Technologies LLCWilzGarageSportbikeTrackGearHardRacing.comJazzMotorsports.comSumOfAllParts.netSoloMotoPartsMotoGiya.comCycleGear.comArnottAirRideCheapCycleParts.comSpringfield ArmorySee your ad here!
Old 04-07-2007, 05:50 PM   #1 (permalink)
cirsory
cirsory's Avatar
Sportbike: 91 Honda CBR 600
cirsory is on a distinguished road
Default bar risers, throttle sticks
I installed some convertibars on my bike. Had to reroute throttle cables to the right side of the fork leg. Now the throttle wont go back to closed freely, wont snap back. if its turned to the right, it will almost snap back but theres some friction. if i turn it to the right it wont move back at all. I came to a conclusion that the decelrator cable is being curved too tightly when turned to the right. The cable isnt long enough to go in between the fork legs and back to the throttle. so is there anything else i can do besides a new cable. attached is a pic of what it looks like when pushed to the right.
cirsory is offline   Reply With Quote
Old 04-07-2007, 06:01 PM   #2 (permalink)
CBRAWR
CBRAWR's Avatar
Casino Cash: $2524
Sportbike: '96 CBR 600 F3
CBRAWR is on a distinguished road
did you push the throttle side grip on too far? when i installed my new grips i pushed the throttle side on a bit too far and it made the throttle stick. also check that your bar end isnt touching the end of your grip too.....other than that all i can suggest is you check the length of the throttle cable and see if you can adjust it at the carbs to allow a little more slack so it'll snap back
R.I.P Shawn "Krazy Hawaiian" McCallister
July 11, 1956 - July 23, 2007
We will miss you.
CBRAWR is offline   Reply With Quote
Old 04-07-2007, 07:24 PM   #3 (permalink)
cirsory
cirsory's Avatar
nope the grip isnt rubbing on either. thanks for the help though.
Old 04-07-2007, 09:56 PM   #4 (permalink)
RayOSV
RayOSV's Avatar
Casino Cash: $37404
Sportbike: '05 sv1000s
Depending on how far up the grips moved, you may need to replace the throttle cables with longer ones (others as well?). Did the instructions give any hint about this?
Old 04-07-2007, 11:14 PM   #5 (permalink)
2001FZ1
~ Master Technician ~
2001FZ1's Avatar
Casino Cash: $11742
Sportbike: 2005 Suzuki GSXR 1000 & 2004 Kawasaki Ninja 250
2001FZ1 is on a distinguished road
You have too much of a bend in those lines. Did you get longer cables with the convertibars? If so, re-route them a different way. If installed correctly, the throttle should act normal no matter what position they are in or which way the bars are turned. Take a look at this post: ConvertiBars have been installed!
it shows a couple pictures of my bike. You can see how my throttle lines do not have near the bend in them that yours do. If you can't figure it out, call the Convertibars manufacturer and ask for help. They helped me with mine when I was having the very same issue you are having. The guy on the phone told me to run the lines different than what the directions said to do....directions were wrong.
Feel free to email/PM me if you need any more help.
Joe
My Resume
Need a better riding position? Check out www.convertibars.com. They are great!
Past bikes: '82 Yamaha Maxim 750, '89 Kaw. ZX7, '94 Kaw. ZX9R, '01 Yamaha FZ1, 04 Kaw. EX-250 ~ over 12 years & 90,000miles of riding experience.
2001FZ1 is offline   Reply With Quote
Old 04-08-2007, 12:41 PM   #6 (permalink)
cirsory
cirsory's Avatar
thanks for all the help, i'll take it to the shop tommorow to get different lines put in. I cant reroute these lines. If I put them in the front then i cant get to the bolt to adjust them.
Throttle Position Sensor Issues (Are you Experiencing Poor Idle/Mileage, or Stalls?) FZ6R FZ6 518 10-03-2008 09:05 AM
A guide for learning wheelies. Justin726 Stunterz Corner 158 05-31-2008 10:38 PM
Bar risers - looking for recommendation bzbatl General Sportbikes 6 02-15-2007 02:23 AM
Gen mar bar risers kangaroooski FZ6 4 12-28-2004 09:18 AM
Gen mar bar risers kangaroooski FZ6 Classifieds 0 12-27-2004 09:31 AM
