Motoworld Inc
Bazzaz PerformanceMcCoyMotorsportsSoupy's PerformanceBluTek Helmets British Motorcycle GearLevel One RacingBikeBanditMotorcycle.com Classifieds!See your ad here!
Old 04-04-2007, 03:25 PM   #1 (permalink)
fisher
Casino Cash: $13100
Sportbike: 1999/Kawasaki/Ninja 6r
fisher is on a distinguished road
Default Leaking water
I've been experiencing a rather bad water leak from the water pump area on my 93 Ninja 600. I've pulled the water pump cover put the leak is deffenetly behind the pump and not from the cover. Looking at this schematic
http://www.bikebandit.com/partsbandi...dept_id=299035
It appears there is an o-ring behind the pump. My question is, does the pump just pull out?? I saw no way to unscrew the pumps blades. Any help would be greatly appreciated as of now im refilling the water every 2 days.
fisher is offline   Reply With Quote
Old 04-04-2007, 05:25 PM   #2 (permalink)
fisher
Casino Cash: $13100
Got the water pump out. O-ring was fine, but there is a small hole in the shaft past the o-ring. Dont know what the purpose of this hole serves as that is deffenetly where the leak is coming from.
Old 04-04-2007, 05:37 PM   #3 (permalink)
hybrid
RESIDENT ASSHOLE
hybrid's Avatar
Casino Cash: $3557
Sportbike: too many to list
hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute hybrid has a reputation beyond repute
Its called the "weep" hole
It means one of the seals in the pump is bad.
You can have it rebuilt or buy a new one..........the new one is usually cheaper if you dont know how to rebuild it yourself.
www.walmartmovie.com
hybrid is offline   Reply With Quote
Old 04-04-2007, 06:18 PM   #4 (permalink)
fisher
Casino Cash: $13100
thanks hybrid,
do the manufactures put that there as a indicator for pump failures??
aslo, do you or anyone know how the blades come off?? r they just pressed on??
Old 04-04-2007, 06:53 PM   #5 (permalink)
hybrid
RESIDENT ASSHOLE
hybrid's Avatar
Casino Cash: $3557
Yes.........that is for the indicator of a problem
Or the other seal woud blow and dump water in the oil.
Isnt there a nut on it? the blades are connected to the shaft pressed I believed.
I dont know the specifics of that pump.
Leaking gas problem squaly Help Me Fix It 8 01-21-2005 01:12 PM
Link between elevated/decreased ESTROGEN levels in water and homosexuality? ten31 Open Forums 7 11-10-2004 09:18 PM
leaking fuel from my GSXR freeflyer52 Help Me Fix It 4 09-04-2004 03:36 AM
help...water from radiator directly in the oil sump..... hori Help Me Fix It 4 08-21-2004 11:59 PM
