Output shaft spinning in neutral
Hi, i recently replaced the transmission on my 03 r6 after i ended up grinding several teeth off of 2nd gear.
I put everything back together, and now when its in neutral, the output shaft spins while the bike is idling. I dont have a sprocket installed or a chain. It is necessary to give the bike a little bit of throttle for it to idle, and when you do give it gas the speedometer goes up.
However, i can spin the output shaft with my fingers with a little effort, i dont feel the motor turning over, when i turn the drum and put it in gear, its impossible to spin.
I put the shift forks in the proper locations, and neutral is where its supposed to be according to the shift drum.
Also, for what its worth i dont think the clutch is properly installed, but that shouldnt be a problem if the bike is in neutral ?
Is a little spinning of the output shaft normal in neutral and i just need to put the sprocket and chain on, or have i screwed something up.
Any help or advice is appreciated.
