zx7r suspension setup - Sportbikes.net
User Tag List
post #1 of 4 (permalink) Old 10-25-2006, 10:42 PM Thread Starter
man in black
Quoted: 0 Post(s)
hi all
looking for good suspension setup for my 98 zx7r 750p. i weight about 90 kg and have been plaing with the setup but the rear never seems to be right. any ideas.
also thinking about installing dynojet kit but not sure if it is worth it. Any ideas on mods for my bike.
cheers
Name:	Birthday Cake 028.jpg
kwaka is offline
post #2 of 4 (permalink) Old 10-25-2006, 11:51 PM
RayOSV's Avatar
Quoted: 1 Post(s)
They don't seem to list suggested settings for your bike in the last section, but this may prove useful:
http://www.sportrider.com/tech/146_0006_susp/
RayOSV is offline
post #3 of 4 (permalink) Old 10-26-2006, 12:41 AM
Duc hunter
bobbo84's Avatar
Quoted: 0 Post(s)
first off, set your sag for your riding weight ie how much you weight with your helmet, gloves, suit, boots on. 30-35mm sag up front and 25-30mm sag in rear is a good place to start. some chassis, like mine, like to ride a little deeper in the suspension travel than others. just something you learn. A general idea of preload is that if you press down on the bike in the middle (like at the back of the tank) both ends should compress equally and together.
Follow the above posted guide to how to set sag and then go from there. There's a lot of test and tune on rebound and compression. You generally want rebound set so that when you compress on either end it rebounds to the original position but doesn't go any higher and then sink back down. If that happens, you need to up the damping some. If it takes forever to nudge back up to the original postion, take out some damping. Compression is half a comfort feel and other half traction, but again they both take a bit of test and tuning.
- Bobby
Follow the litre
It's always Duc season in my book
Nothing like twins messing around between your legs.
bobbo84 is offline
post #4 of 4 (permalink) Old 10-26-2006, 01:38 PM
RESIDENT ASSHOLE
hybrid's Avatar
Quoted: 0 Post(s)
When I built that bike into a superbike on the factory team.........we had the 96 frames with the adjustable swingarm pivot but Ill give you this much........ours were set so the axle was roughly 450mm off the ground if I remember correctly..........so somewhere around that. Take a couple shims and put them inbetween your shock clevis and your frame.....to raise the ass up.
Drop the front so you have about 10mm of fork showing out the top of the clamps.............If its too much the bike is going to spin the back tire a bit easily.
Next you need .95 kilo springs for your weight...........
Id get the shock replaced the stocker is shit.........seriously its garbage.
Dont get the dyno jet kit use the FACTORY BRAND TUNING KIT with new emulsion tubes.
Get rid of that boat anchor you call an exhaust while your at it.
Keep the stock airfilter, there is no performance one that works better.
<---- a great one!
hybrid is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Suspension & tire setup help ! 05 636 R fordfasterr ZX-6R 3 08-15-2005 11:53 AM
Stock F2 suspension setup. SwiftTone Honda Sportbikes 3 04-11-2005 11:06 PM
Suspension Setup Guide Bdog1v1 On The Track 0 03-01-2005 05:47 PM
ZX6 suspension setup? adamf2 Help Me Fix It 1 08-18-2004 09:12 PM
how to setup the suspension after lowered katie14 Help Me Fix It 4 08-09-2004 05:05 PM
You may post new threads
You may post replies
Refbacks are Off
