How to: 3 wire to 2 wire indicators/running lights - Sportbikes.net
LinkBack (14) Thread Tools Display Modes
Old 07-13-2006, 05:56 PM   14 links from elsewhere to this Post. Click to view. #1 (permalink)
killernoodle
Theres no I in threesome
killernoodle's Avatar
Gameroom cash: $45872
Sportbike: 2005 Yamaha FZ6
killernoodle will become famous soon enough
Default How to: 3 wire to 2 wire indicators/running lights
So you have a strong desire to mount super cool LED turn signals to the front of your ride, but you also want to have running lights for nighttime saftey. How in the heck do you hook up those 2 wire indicators to your stock 3 wire mount and still have running lights?? Well, you can go out and spend lots of money on a pre fabbed kit just for this task, or you can do it the old fashioned and visit your local radioshack. So you have never ventured into the electronic parts section of your local shack? Shame on you!
Here is what you will need for this mod:
2x 12v triggered SPDT relays. I picked the 10 amp mini ones instead of the micro ones because it is rated for higher temperature ratings, important since this is going under my tank. Yeah its overkill, and yeah it makes an audible click when it flashes, but that only makes it way cooler! You can also use automotive relays if you dont have soldering gear, I believe you can buy crimp on connectors that slide right on.
A small PCB for mounting your stuff if you want to centralize your flasher stuff like I did (if you go with soldering the PCB mount components like I did).
Some wires and some connectors to hook wires to other wires. I used some molex connectors from old computer junk.
Some time, possibly a few beers (not too many if you are going with the soldering route)
Just follow this simple wiring diagram to hook up your relays. Yours will most likely not have this layout, but it will have all the same basic labels. The colors of the wires will most likely differ from bike to bike, but generally green is a ground (or -) my blue wire was my running light's + wire (always ON) and the black wire was the flasher. They also usually differ from right side to left, if you get it backwards you can always unplug them and switch them around. The indicators I bought had blue as the + and green as the -.
If you want to slow down the blinker, install one of these between the flasher signal and the coil. It will add resistance just like a regular bulb and you will not have to buy a new flasher relay. I personally like a slightly more frantic flash so I didnt install one
This is what it should do when you're done: http://video.google.com/videoplay?do...01953182957322
Let me know if you have any questions.
killernoodle is offline   Reply With Quote
Old 09-16-2009, 11:30 AM   #2 (permalink)
pohlcat01
Apex Predator
pohlcat01's Avatar
Gameroom cash: $33162
Sportbike: 2001 CBR600F4i
pohlcat01 is on a distinguished road
thanks for the info! Had to buy bigger lights to pass inspection and the 3 wire signals are far and few...
pohlcat01 is offline   Reply With Quote
Old 09-16-2009, 12:44 PM   #3 (permalink)
pohlcat01
Apex Predator
pohlcat01's Avatar
Oh, btw, have you had any problems with the RS relay??
The website says max temp is 65 Fahrenheit. so you cant signal in summer??
Old 09-17-2009, 11:59 AM   #4 (permalink)
Liquids
Liquids's Avatar
Asteroids Champion!
Gameroom cash: $18756
Sportbike: an old one
Liquids is on a distinguished road
there is a how-to section ya know...
http://www.sportbikes.net/forums/how-tos-section/
Liquids is offline   Reply With Quote
Old 09-17-2009, 12:20 PM   #5 (permalink)
pohlcat01
Apex Predator
pohlcat01's Avatar
Um, ok... I guess...
Old 03-26-2010, 02:59 PM   #6 (permalink)
Sceptre6
Gameroom cash: $101
Sportbike: 1999/Honda/CBR600F4
Sceptre6 is on a distinguished road
ok i know this is an old thread but was wondering if anyone could help me i have the relays and stuff hooked up i tried with and without resistors but i still cant get them to flash here is the lights i have Amazon.com: Honda CBR 600 F4i Flush Mount LED Clear Turn Signals: Automotive if anyone has any ideas that would be awesome
Sceptre6 is offline   Reply With Quote
Old 05-08-2010, 10:46 AM   #7 (permalink)
KyleC_F4I
Gameroom cash: $201
Sportbike: 2005/hoda/cbr 600 F4I
KyleC_F4I is on a distinguished road
Im havin the same trouble so if u find out let me know!
KyleC_F4I is offline   Reply With Quote
Old 05-08-2010, 11:39 AM   #8 (permalink)
RayOSV
RayOSV's Avatar
Gameroom cash: $94058
Sportbike: '05 sv1000s
RayOSV will become famous soon enough
Without a wiring diagram and instructions, it's hard to know why they don't work. Are they 2 wire or 3 wire? How did you connect them?
BUT, why would you want to RECESS your turn signals?!?!?!? Flush mounts are bad enough, but those signals would be invisible from the front if mounted as shown in the picture.
RayOSV is online now   Reply With Quote
Old 10-25-2011, 10:56 AM   #9 (permalink)
vernonea
vernonea's Avatar
Gameroom cash: $604
Sportbike: 2007 FZ1 Black (PURCHASED 07/24/07)
vernonea is on a distinguished road
Default Need some additional help.
This is what I did and all I git was a locked signal indicator, nothing works until I unplug it.
http://www.sportbikes.net/forums/images/attach/jpg.gif
Let me know if you have any questions.[/QUOTE]
vernonea is offline   Reply With Quote
LinkBack to this Thread: http://www.sportbikes.net/forums/help-me-fix/319205-how-3-wire-2-wire-indicators-running-lights.html
Quick question ref DRC Flashers.. This thread Refback 01-26-2013 12:47 PM
Brake light blowing fuse...well three so far... This thread Refback 03-03-2012 04:03 PM
little noob help : Honda CBR 1000RR Motorcycle Forums: 1000RR.net This thread Refback 12-07-2011 09:13 PM
One Passion...One Site...NBRiders.org • View topic - who has installed a integrated tail light? This thread Refback 07-28-2011 11:22 AM
One Passion...One Site...NBRiders.org • View topic - who has installed a integrated tail light? This thread Refback 07-28-2011 11:11 AM
Brake light blowing fuse...well three so far... This thread Refback 10-27-2010 12:42 PM
Brake light blowing fuse...well three so far... This thread Refback 10-27-2010 12:40 PM
BluEyedTiger's Bookmarks on Delicious This thread Refback 10-23-2010 03:03 PM
I just got after market - FixYa This thread Refback 05-05-2010 07:11 AM
Quick question ref DRC Flashers.. - Supermoto Junkie This thread Refback 11-09-2009 02:46 PM
Quick question ref DRC Flashers.. - Supermoto Junkie This thread Refback 11-09-2009 02:33 PM
Greggs Customs Question - R6Central.com : Yamaha R6 Forum This thread Pingback 06-19-2008 03:13 PM
FZ6 2 wire flashers/running lights - Google Video Post #1 Refback 02-07-2008 12:57 PM
FZ6 2 wire flashers/running lights - Google Video Post #1 Refback 10-18-2007 12:00 PM
How to bypass the 186mph speed restriction on a Kawasaki ZX-12R zz_3.14_zz ZRX-1200R 3 08-26-2009 01:11 PM
Pod Running Lights - How-To qualdoth FZ6 Mods 27 07-21-2008 03:05 PM
Front running lights on an 04 gsx-r600 csxfbird General Sportbikes 0 03-26-2006 01:24 PM
Accent or underbody Color LED Lights: Install Q?s Hewhois FZ6 14 10-11-2005 06:16 PM
Lockheart Phillips arrow lights. ClutchWorks Help Me Fix It 6 07-29-2005 12:05 AM
