Rust In Gas Tank and Carb Issues...Advice?? - Sportbikes.net
User Tag List
post #1 of 12 (permalink) Old 07-13-2006, 04:48 PM Thread Starter
DoppelgangerONE's Avatar
Quoted: 0 Post(s)
(sorry about the double post...I wasn't sure which forum to put it in to get better responses)
Hey everyone. My bike had been running funny...seemed really rich, and then it flooded. Well, I went to the local shops, and one wanted $125 to clean the carbs, and one wanted almost $400 (riiiiight) to do it.
I decided to do it myself. When I got the float bowls off, there was some reddish brown goo in the bottom of them. I didn't know what it was, but the carb cleaner cleaned it right out. It was caked all over the screw thing on the bottom of the carb. I cleaned all 4 floats, and all of them were like that. When the goo started to dry on the pavement, I realized that it looked like rust...so I took a flashlight to my gas tank, and there are spots of rust in the tank.
Now, my bike does NOT have a fuel filter. Should I add one to help deal with the rust, or is there some other thing that I need to do?
Also, would this rust/varnish/goo in the carbs have been the problem with my bike running strangely? I cleaned that out, and when I sprayed the carb cleaner up through the needle it sprayed out in a fine mist really well. I don't THINK that the needles were clogged, but I'm not sure. I didn't take the carbs completely apart, because I'm not very well versed in carb maintenance/repair.
I'm gonna try riding it for a while, as right now it's idling/revving better than it has since I've had it. Before I got it, I think it sat for several years.
DoppelgangerONE is offline
post #2 of 12 (permalink) Old 07-13-2006, 04:54 PM
World Superbike Champion
dartsum's Avatar
Quoted: 0 Post(s)
I also cleaned my carbs out and they had a bit of rust in the bottom. If your bike has no filter you might want to install one. Also, you can clean out and recoat the inside of the gas tank that will stop it from rusting more.
"It is better to remain silent and be thought a fool than to open one's mouth and remove all doubt."
~Abraham Lincoln
"All that is necessary for the triumph of evil is that good men do nothing."
~Edmund Burke
dartsum is offline
post #3 of 12 (permalink) Old 07-13-2006, 05:17 PM
Dirty Sanchez
apor's Avatar
Quoted: 0 Post(s)
you did the right thing by dumping out the bowls. i would suggest taking off your tank and cleaning the whole thing out with your favorite solvent (kerosene?) and discarding whatever you get out. was it full of chunks of rust, or was it just jellied gas? look inside your tank with a flashlight. if you have chunks of crap in there, there are methods of removing this stuff and recoating your tank. kreem and por-15 (or something like that) make products to do this adn recoat your tank. if you don't have big chunks of stuff, maybe just a little sediment and some surface rust, you should be ok with just installing inline fuel filters. these go on the fuel line between the petcock and your carbs, and will filter out small particles. also, if you only have surface rust in your tank, make sure you keep your tank full as it will help prevent new rust from forming and keep condensation to a minimum. it's also good to use that stuff that removes water from your gastank, as any condensation in your tank will sit at the bottom, and rust your tank where you can't even see it.
apor
apor is offline
post #4 of 12 (permalink) Old 07-13-2006, 05:21 PM Thread Starter
Quoted: 0 Post(s)
apor
It appears to be just light spots of surface rust. The stuff in the bowls was more like a jelly goo, no like little chips of rust or anything. I wasn't even sure it was rust until I saw the dry rust color on my driveway after I was done.
I think I'm gonna go get a fuel filter tomorrow. Do you think just any small one from the auto parts store should work?
post #5 of 12 (permalink) Old 07-13-2006, 05:26 PM
Mt Vesuvius
Quoted: 0 Post(s)
buy 2 and keep one as a spare in a ziplock...if its that bad it will clog it in no time...
CBRWildChild is offline
post #6 of 12 (permalink) Old 07-13-2006, 06:21 PM
Dirty Sanchez
apor's Avatar
Quoted: 0 Post(s)
jellied gas does turn kinda brown, so it may have been just that (lucky you?). when you get fuel filters, get the little clear ones that have inlet/outlet nozzles that'll fit your size fuel hose. matter of fact, take your old fuel line w/you and get new fuel lines while you're at it, then you can measure it all. if you do a search on "inline motorcycle fuel filters" in google, you should find some... here's kinda what you're looking for: http://www.jcwhitney.com/autoparts/B...+10211/c-10111
also, get some carb cleaner /water remover crap from the auto store. i have used "seefoam" brand with excellent results, though nothing takes the place of a good, thorough cleaning by hand if you want to be real sure about your results. i'd say rinse out the tank, get the filters, and see how it runs. carefully feel the exhaust headers to see if they're equally hot, see if it responds smoothly to throttle input etc. also, if this bike has been sitting, you should do a brake fluid flush, that stuff should be changed every three years or so, but nobody does it.
apor
apor is offline
post #7 of 12 (permalink) Old 07-13-2006, 06:46 PM
~ Master Technician ~
2001FZ1's Avatar
Quoted: 0 Post(s)
Kreem works very well at restoring a rusting tank. Buy the 3 step process of Kreem, install a fuel filter and clean those carbs. The bike should run like new again.
Need a better riding position? Check out
. They are great!
Past bikes: '82 Yamaha Maxim 750, '89 Kaw. ZX7, '94 Kaw. ZX9R, '01 Yamaha FZ1, 04 Kaw. EX-250 ~ over 18 years & 120,000miles of riding experience.
2001FZ1 is offline
post #8 of 12 (permalink) Old 07-15-2006, 03:16 PM
StickItGraffix's Avatar
Quoted: 0 Post(s)
apor
Get yourself 2 large bolts and a bottle of acetone. Filler up and shake the crap out of it and pour out the gas and the acetone. Then let it dry. Vent it well and fill it up with 1/2 gallon of gas , shake it up and dump it out.
IF YOU HAVE RUST IN YOUR TANK WHY THE HELL ARE YOU RUNNING IT WITHOUT A FILTER ARE YOU INSANE OR OBSESSED WITH POPPING OFF THE CARBS. . YOU ARE ASKING TO PLUG UP YOUR JETS
StickItGraffix is offline
post #9 of 12 (permalink) Old 07-15-2006, 04:21 PM Thread Starter
Quoted: 0 Post(s)
Calm down, this is the first time I ever had any idea that my tank had any rust in it...
post #10 of 12 (permalink) Old 07-15-2006, 11:19 PM
Quoted: 0 Post(s)
Im not freakin out just trying to convey to you how important it is to keep the filter on it. If its dirty and you cant get another right away just clean it out the best you can and reinstall the old one . Unless there is no flow. Blow on it and ensure you dont get a restricted flow . But ANYTHING will work as long as it fits the ID snug. You can get a cheapo at auto zone or napa.
post #11 of 12 (permalink) Old 07-16-2006, 04:19 AM
CHERRYKAT600's Avatar
Quoted: 0 Post(s)
I got some sediment/ floaties in mine. Tank looks pretty good. I'm thinking my filter needs to be replaced but would my carbs need to be cleaned too???
CHERRYKAT600 is offline
post #12 of 12 (permalink) Old 07-16-2006, 01:21 PM
Quoted: 0 Post(s)
It really depends. Clean or change the filter first and see what happens...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Used motorcycle evaluation guide Rascus General Sportbikes 12 09-30-2008 03:51 PM
GSX750 carb problems ??? adamcarlile Help Me Fix It 3 07-22-2005 11:24 PM
How-To's: When you first get your Pocket Bike Mr. Lesbian Pocketbikes 0 08-31-2004 04:21 PM
You may post new threads
You may post replies
Refbacks are Off
