Need Help Installing Lowering Links - Sportbikes.net
Old 03-13-2006, 08:23 PM   #1 (permalink)
rabbit280
Gameroom cash: $250
Sportbike: 1997 GSXR600
rabbit280 is on a distinguished road
Default Need Help Installing Lowering Links
The Title Says It All. I Have 1997 Gixxer 600. I Just Brought Some Lowering Links Off Ebay. I Need Some Detailed Instructions On How To Install Them.
Thanx To All That Reply!
rabbit280 is offline   Reply With Quote
Old 03-13-2006, 08:30 PM   #2 (permalink)
cbcinnovations
cbcinnovations's Avatar
Gameroom cash: $1065
Sportbike: 2007 Suzuki GSXR1000, 2005 Suzuki GSX1300R, 2006 Suzuki GSXR600, 1997 Suzuki GSXR600
cbcinnovations is on a distinguished road
You should be able to see how it is assembled by this picture. #13 is the links your are replacing. You need to have some way to hold up the rear of the bike other then the swingarm while you take the links out. Basically loosen those bolts and replace the links. The upper bolt should be the single eye hole in the links you bought. The lower bolt is the adjustable one. Start with the middle hole for a 2 inch drop from stock. Check the service manual for torque specs if your picky.
-CBC-
cbcinnovations is offline   Reply With Quote
Old 03-13-2006, 08:48 PM   #3 (permalink)
rabbit280
Gameroom cash: $250
Thanx. I Will Try To Hold Up The Rear Of The With Jacks And A Piece Of Pipe.
Old 03-13-2006, 09:08 PM   #4 (permalink)
cbcinnovations
Or some tie downs attached to the subframe and a ceiling joist.
-CBC-
Old 08-11-2006, 05:11 PM   #5 (permalink)
albe
Gameroom cash: $250
Sportbike: gsxr 600
albe is on a distinguished road
Default yeah i need help
yeah so i bought this bike and it needs work but i want to lower it in the front and get a longer swingarm in the back but i got these lowering links and have no idea how to do so any info would help
albe is offline   Reply With Quote
