ArnottAirRide
CycleGear.comBikeBanditSpringfield ArmoryArnottAirRideSuperbikeToyStore.comJazzMotorsports.comSportbikeTrackGearAmericanMotorcyclistAssociationNice CycleSportbikeTrackGearAnnitori DistributingChainDrain.comSee your ad here!
Old 11-03-2005, 10:49 AM   #1 (permalink)
darkducati
darkducati's Avatar
Location: Setting the world on fire, one upshift at a time.
Sportbike: 06' Buell XB9SX 74' RD350 Cafe Racer
darkducati is on a distinguished road
Default PLease help. 02' R1 not charging.
Hey guys. I have a friend with an 02' R1 and the charging system is dead. The bike has approximately 14k miles and has a new battery. We are trying to get it fixed for a trip to Deal's gap Saturday and already have a stator on the way just in case. Are stators common to replace on these? Any help is hugely appreciated!
all your piston are belong to us
darkducati is offline   Reply With Quote
Old 11-03-2005, 11:12 AM   #2 (permalink)
Redstar11
World 500 GP Racer
Redstar11's Avatar
Casino Cash: $275
How do you know the charging system is bad?
Pain, necessary to know.
Old 11-03-2005, 11:25 AM   #3 (permalink)
stoinkythepig
Sportbike: 2001 ZX9R, 1992 Bandit 400, 1986 Concours
stoinkythepig is on a distinguished road
I would say the most likely failure is the rvoltage regulator or the wiring harness. The stator is kinda simple and not likely to fail but it could happen. Can;t say I've heard of any common charging system issues with R1s either.
stoinkythepig is offline   Reply With Quote
Old 11-03-2005, 11:28 AM   #4 (permalink)
hybrid
RESIDENT ASSHOLE
hybrid's Avatar
Casino Cash: $450
Sportbike: too many to list
hybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond reputehybrid has a reputation beyond repute
On the yamahas you have to remeber that you have the stator (charge coils) the generator (large rotating bowl of metal with magnets) to produce the voltage. This goes up into the REGULATOR/RECTIFIER where thru a process of diodes is converted to 12VDC (well really it is just converted to DC and can be as high as 17 volts but thats besides the point)
So you have three suspects and all the wiring inbetween them.
You can check the stator with a an OHM meter to make sure each lead is good (3 yellow wires)
Generators usually never have problems and if it did you would know about it in a hurry
Regulator rectifiers can go bad or loose ground.
Or you could simply have a busted charge lead from the regulator rectifier that sends voltage back to the battery.
So...........like Redstar said..........how do you know the charging system is bad? Have you diagnosed any of it?
www.walmartmovie.com
hybrid is offline   Reply With Quote
Old 11-03-2005, 12:33 PM   #5 (permalink)
darkducati
darkducati's Avatar
Very low voltage and the bike has a dead battery after about 20 miles. I'll check with him and get back to you guys. Thanks for the help.
Old 11-03-2005, 01:41 PM   #6 (permalink)
darkducati
darkducati's Avatar
Okay, a tech says there is zero output from the charging system. He is going to check the resistance of the stator. I'll check back.
Old 11-03-2005, 02:40 PM   #7 (permalink)
Redstar11
World 500 GP Racer
Redstar11's Avatar
Casino Cash: $275
Stator output is just about the easiest test you can do. If any one of your stator leads is not producing the specified voltage listed in the service manual, your stator is in-fact back.
I have in 1 case *HEARD of a magneto going bad. Somehow the magnets lost a bit of their magnetizing power and the actual magneto had to be replaced.
Check a short to ground, and stator lead resistance. If there is any discrepancy there, your stator is in-fact bad.
Also, read up on Hybrids post. You may want to go ahead and check the rest of your charging system even if your stator does end up being bad.
Old 11-04-2005, 06:33 PM   #8 (permalink)
darkducati
darkducati's Avatar
Thanks for all the help guys. It ended up being the sator. Bike is once again running and we're headed for Deals gap in the morning. Thanks again!
Old 11-05-2005, 01:18 AM   #9 (permalink)
MT Wallet
Casino Cash: $7159
Sportbike: 1993 Honda CBR900rr
MT Wallet is on a distinguished road
good for you!
my stator went bad and I think messed up my regulator/rectifier
Honda also changed the wiring harness, they said to just do the stator/rectifier may not solve the problem... wiring needs to be done
electrical systems seem very sensitive
MT Wallet is offline   Reply With Quote
