JazzMotorsports.com
JazzMotorsports.comCycleGear.comGravesMotorsportsAdvanstarMotorcycleShowsAnnitori DistributingSuperbikeToyStore.comWilzGarageSportbikeTrackGearChainDrain.comArnottAirRideOPP RacingSportbikeTrackGearBikeBanditSee your ad here!
Old 08-30-2005, 03:01 AM   #1 (permalink)
libretto
Sportbike: 2001 honda cbr 929rr
libretto is on a distinguished road
Default I need some help CBR929rr 2001
Ok so here is the deal, I have a (2001 929rr) about a week now and love it. It rides just great. Now here is my problem, say im riding along at 65 in 6th gear and go to snap the throttle on. The bike doesn’t jump off but instead the bike wraps up to like 10 or 11 like i just pulled the clutch in. It doesn't hit the rev limiter but slowly accelerates forward and starts to apply power gradually, with the motor still wrapped up. I have only had the bike a week and had not snapped the throttle on till last night. If I role it on it pulls just fine, if I give it more gas then it wants it starts to rev. It does this in every gear across the board but like I said rides just fine the rest of the time. Its only under rapid throttle does it rev like this. The only think I can thing is that the clutch is not disengaging all the way and causing the bike to rev. If that was the case I think that I would see this all the time correct?? Any help or ideas you have would be great I think I am going to take it into Honda tomm and see what they say.
libretto is offline   Reply With Quote
Old 08-30-2005, 04:03 AM   #2 (permalink)
BurnMyHeartDown
World 500 GP Racer
Casino Cash: $12559
Sportbike: Honda F3
BurnMyHeartDown is on a distinguished road
how many miles are on it? Your lack of periods make it difficult to follow what you're saying, but I would say it sounds like it's time for a new clutch maybe? I can't really be certain as that wasn't the most coherent thing.
BurnMyHeartDown is offline   Reply With Quote
Old 08-30-2005, 06:23 AM   #3 (permalink)
Redstar11
World 500 GP Racer
Redstar11's Avatar
Casino Cash: $275
Sounds like clutch slippage like Burn suggested. 6th gear is the highest load for the motor and will cause the clutch to slip more than any other gear if it is worn out.
Does your lever pull feel ok?
Pain, necessary to know.
Old 08-30-2005, 12:35 PM   #4 (permalink)
libretto
Sorry about the lack of periods it was a late night i went back and tried to edit it a little bit. The bike has 9000 miles on it. The clutch lever feels fine to me but i don't have any freeplay in the lever when its out all the way. Im not sure if the clutch is releasing all the way
Old 08-30-2005, 03:17 PM   #5 (permalink)
roadracer319
roadracer319's Avatar
Sportbike: 2001 Honda CBR929RR Erion Edition (streetbike), 2003 Yamaha R6 (racebike)
roadracer319 is on a distinguished road
Adjust the lever so you have atleast a quarter of an inch of free play. If the adjustment is all the way in on the lever, use the adjustment at the other end of the cable.
That's going to leave a mark...
roadracer319 is offline   Reply With Quote
Old 08-30-2005, 05:43 PM   #6 (permalink)
MAGNUM636
MAGNUM636's Avatar
Sportbike: 2004 636, 2005 1000RR
MAGNUM636 is on a distinguished road
At the end of the lever right? Supposed to be only 2-3mm at the lever's hinge.
I HEART Petroleum Consumption
MAGNUM636 is offline   Reply With Quote
Old 08-30-2005, 09:46 PM   #7 (permalink)
Redstar11
World 500 GP Racer
Redstar11's Avatar
Casino Cash: $275
You will want to have enough room at the hinge to stick a nickel in. Try adjusting your clutch properly before assuming the clutch is bad. Also, having a mis-adjusted clutch will reduce the life of the clutch.
Also, check out this thread I posted long ago about the 929's.
http://www.sportbikes.net/forums/sho...37#post1592737
Old 08-31-2005, 12:08 AM   #8 (permalink)
libretto
Well i backed the adjustment off and now i have some free play in the lever. It appears that might have fixed the problem. Thanks for input and help
Old 08-31-2005, 12:55 PM   #9 (permalink)
hozhead
Pronounced "Hose Head"
hozhead's Avatar
Casino Cash: $251
Sportbike: '02 CBR 600F4i
hozhead will become famous soon enough
You'll probably still be replacing the clutch a bit earlier than you'd like if the previous owner was driving it around with the clutch cable set to tight.
2002 CBR 600F4i (Red & Black)
* 600RR Swingarm
* Power Commander
* 110% Awesome
http://www.boiseriders.net
hozhead is offline   Reply With Quote
Old 08-31-2005, 03:54 PM   #10 (permalink)
libretto
Yea thats what i was thinking but it still seems to have good pull and alot of plate left. I think honda put a new clutch in and didn't set the adjument right.
