i had my bike for about one year and now when i start it up when its cold it makes a very weird ticking noise kind of like lifter tick or somthing to do with valves but when warm it is not as loud????
how many miles on the bike? is it valve adjustment time maybe? I dunno...not a super braniac when it comes to that kind of stuff but who knows, maybe?
I have to say, I'm not a brand freak but I have definitely noticed that my girlfriend 636 definitely doesn't sound as smooth as my F4i. But it is definitely faster...
car lifters are hydraulic, so they might clatter untill he pressure pums up.
bike lifters are mechanical, I would say it would clatter all the time if it was valves. And also I think your valves should be way, i mean WAY OUT of spec to make a loud noise.
I know suzuki has a pair system (for emission purpose), which has a soledoid with a steel ball inside... it clatters. Does kawasaki has a pair system? That could rattle.
What is the ticking rate (eg, does it sound like 1/2 the engine RPM)? If it sounds like 1/2 the engine RPM then it very well could be something in the valvetrain.
It's possible that clearances just slightly out of spec would cause ticking until warm, when the metal expands enough to bring it back in spec.
I have also heard of guys (cars) switching oils to a non-synthetic or heavier weight oil and the ticking going away.
i know honda is notorious for the cct (cam chain tentioner) going bad and ticking like that. also heard suzuki has the same problem with it on their sv series.
Sportbike: 2002 R6, My Wife
The bike has 4700 miles on it
JIM D
If it's fast, loud and runs on a flammable liquid count me in.
engine knock maybe? I had a car that needed 93 octane once and after a few months had some ticking noises comming from it. I had to buy octane booster and the ticking noise stoped
Kawasaki's are just damn noisey, I doubt the 636's are any different. Is it a new noise, or has it been like that as long as you've had it and are just now asking about it? I've owned 2 ZX-6R's and they both were very noisey engine's. My 1980 Honda CB750F was a quieter engine than my '02 ZX-6R! Well, not really, but almost. Unless it's something really loud/bad sounding, I wouldn't worry about it. Everyone knows that Kawasaki's make the most hp and the most noise. If you're really worried take it into the dealer and have them check it out.
+1 on the mileage, you may need a valve adjustment.
Current ride - 2002 Kawasaki ZX-6R, pearl chrome yellow, Yoshi slip-on, basically stock
First bike - '97 Kawasaki ZX-6R, Dark Red, Full Yoshimura, K&N, jet kit, etc...
My 04 has about 5800 miles on it and it's been doing that for a while. I've seen several threads on the net about it and everyone says its normal. As far as valve adjustments, that is not a scheduled maintenance item until 15k. Of course it wouldn't hurt to run it by the stealership before the warranty runs out just in case.
