ERROR code F1 Suzuki gixxer - Sportbikes.net
User Tag List
post #1 of 17 (permalink) Old 03-19-2005, 07:25 PM Thread Starter
Trax's Avatar
Quoted: 0 Post(s)
Bike would not start, after 5 seconds an error code came up "F1" or "FI" on the temp gauge, red light flashed continuously!
Live life with no boundries, Explore and invent as you go. Because survival is an ART!
Trax is offline
post #2 of 17 (permalink) Old 03-19-2005, 07:31 PM
Industrial superstar
Kawisixer01's Avatar
Quoted: 0 Post(s)
it's your fuel injection warning light. A number of things can set it off. I can look in my shop manual and list them for you when i get home from school.
Kawisixer01 is offline
post #3 of 17 (permalink) Old 03-19-2005, 07:39 PM Thread Starter
Trax's Avatar
Quoted: 0 Post(s)
Thanks bro ,I would appreciate the help! BTW the bike is running now ..
had to reset ECU!
Trax is offline
post #4 of 17 (permalink) Old 03-20-2005, 01:54 AM
Location: The real world. A place jim schmidt cannot find!
Quoted: 0 Post(s)
I know what is wrong with it......... It's a GSXR HAHAHAHA. Just kidding man. Most of the time it is because one of your injectors is clugged causing an uneven flow. Throw some fuel system treat ment in at the next fill up run it threw in one day then take your tank off and look at your injectors. I bet you'll find them to be very clean.
M24SWS is offline
post #5 of 17 (permalink) Old 03-20-2005, 03:00 AM
21 natas's Avatar
Quoted: 0 Post(s)
you can go to gixxer.com and look up the FI codes there if you do the dealer mod. and hopefully it will help you out some
2006 R6 blue-the faster color; akra. exhaust, fender elim. tinted screen, pc, and other cosmetic goodies etc.etc.
21 natas is offline
post #6 of 17 (permalink) Old 03-20-2005, 05:04 PM Thread Starter
Trax's Avatar
Quoted: 0 Post(s)
Thank You!
Trax is offline
post #7 of 17 (permalink) Old 03-21-2005, 10:31 PM
Quoted: 0 Post(s)
This was a problem on the 01 also, what I was told by my delearship while I lived in Vegas that a hot blast of air going into the intake would set off the FI light, he said pull over and shut if off restart and see if it goes away.....kinda wierd.
SLOW is SMOOTH, SMOOTH is FAST, FAST is GOOD!
chsnprodigy is offline
post #8 of 17 (permalink) Old 03-23-2005, 06:51 AM
lun
Superbike Champion
lun's Avatar
Quoted: 0 Post(s)
Grab a paperclip.
Place the bike in Neutral, and take the rear seat cowling off. On the side of the bike between the tail section and the trunk you will find a connector that is covered by a rubber cap, and has two wires running into it. Remove the cap and take note of which one of the 4 sockets the two wires go to. Turn the bike ON and start it up, short the wires out with the paperclip. Where your speedo was flashing a -CHEC- with the temp should now be a CXX error code. Write this code down. Then shut the bike off. Match the code up with the list below. Grab a Manual and get to work!
(What you have just done is put the bike into "Dealer Mode". I think it's a gimick implemented so that you have to take the bike in and pay $60 for a diagnostics fee.)
GSXR Fuel Injection (FI) Code List:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR (1000 ONLY)
* I Predict a C28 Error which is one of the most common among 2000-2001 model GSXRs. The Secondary Throttle Valve was controlled by cables during these years instead of just bolting the unit dirrectly to the motor. The cables tended to fray around 20k miles or so. It's a relatively easy and cheap fix. 2001 they coated the cables in a plastic sheath which helped to solve the problem. If this is indeed your problem it will run you all of $18 for BOTH cables (if you need them) and about a half hours worth of work. Let me know if you need more assistance!
lun is offline
post #9 of 17 (permalink) Old 03-23-2005, 04:46 PM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
His bike would have still started if it was c28 error code.
By the way you are missing the error codes for Crank Position Signal Sensor.
That would have been my guess, if his bike was indeed not starting, CPS error.
Either that or TPS, or Tip over sensor faults.
Pain, necessary to know.
Redstar11 is offline
post #10 of 17 (permalink) Old 03-23-2005, 06:08 PM Thread Starter
Trax's Avatar
Quoted: 0 Post(s)
Well I did What "lun" said and came up with "c00" which i,m guessing means
there are no errors right now, Makes sense (I reset the UCU to get it to start)
probably just throw some injector cleaner in and wait for it to happen again!
Thanks for all your help guys!!!
Trax is offline
post #11 of 17 (permalink) Old 03-23-2005, 11:31 PM
World 500 GP Racer
Redstar11's Avatar
Quoted: 0 Post(s)
c00 indeed means thats everything is ' coo '
bad joke, but at least your bike should be running ok.
post #12 of 17 (permalink) Old 03-24-2005, 03:24 AM
lun
Superbike Champion
lun's Avatar
Quoted: 0 Post(s)
the C00 Is the standard code if nothing is wrong with the bike. Infront of the C00 there is a line that can have one of three positions.
_C00 -C00 C00
This tells you what position the Secondary Throttle Position Sensor (TPS) is in.
Look at the code to make sure that the indicator is in the middle ( -C00 ). if it is lower your TPS is turned too far back. If it is higher, your TPS is turned too far forward. If all is well and your FI light is still on or the bike does not run, let me know. I'll need more information to further assist you.
lun is offline
post #13 of 17 (permalink) Old 03-26-2005, 12:33 AM Thread Starter
Trax's Avatar
Quoted: 0 Post(s)
The light is off now it only came on that one time when it wouldn't start.
after I unplugged the ECU and reattached it the bike started fine and It has not done it again, that was a week ago! (-c00) position
Trax is offline
post #14 of 17 (permalink) Old 03-26-2005, 02:21 AM
lun
Superbike Champion
lun's Avatar
Quoted: 0 Post(s)
Well, Sweet! carry that paper clip in your trunk or something. If you get the FI light again pull over, leave the bike running and put it in Neutral and Put it back into 'Dealer Mode'. If you shut the bike off, it will clear the FI code and you may not be able to find out what it was.
You can also purchase a switch (or make one yourself) from http://www.jsdproducts.com/Product_I...duct_info.html
lun is offline
post #15 of 17 (permalink) Old 03-27-2005, 07:44 PM Thread Starter
Trax's Avatar
Quoted: 0 Post(s)
Cool, Thanks Man
Trax is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
Refbacks are Off
