Honda CBR 954RR Fuel Pump Wont Turn On - Sportbikes.net
User Tag List
post #1 of 8 (permalink) Old 02-07-2005, 10:21 PM Thread Starter
Superbike Champion
ncpartsguy's Avatar
Quoted: 0 Post(s)
I have a 2002 954 RR. I can't get the damn fuel pump to turn on.
I've checked all of the fuses.
I've changed fuel pump.
I've changed the Bank Angle Sensor.
The battery is showing 12.6 volts and I just plugged it up to the battery tender to make sure it charges even more while I mess with it.
Bike turns over just fine, but I don't ever hear the fuel pump kicking on.
Any ideas?
Does anyone know what wires to splice on the bank angle sensor to bypass it?
ncpartsguy is offline
post #2 of 8 (permalink) Old 02-07-2005, 10:56 PM
Jackal79's Avatar
Quoted: 0 Post(s)
If the fuel pump is good, I would bet it is the fuel pump relay. Take a look at that - when working properly you should hear and feel it "click" when pressing the ignition and the fuel pump will have power.
Edit: Make sure power is actually getting to the relay too. Your manual should have a series of tests you can do.
Jackal79 is offline
post #3 of 8 (permalink) Old 02-07-2005, 11:11 PM Thread Starter
Superbike Champion
ncpartsguy's Avatar
Quoted: 0 Post(s)
No manual. When I flip the on/off switch on, the middle relay (there's a row of 3 on the subframe) clicks. I've already replaced it and it still clicks, but no fuel pump.
post #4 of 8 (permalink) Old 02-07-2005, 11:39 PM
www.wmriders.com
Quoted: 0 Post(s)
check all the harness plugs to ensure they are secure. Safety switch on the clutch and kickstand too.
bvrider1 is offline
post #5 of 8 (permalink) Old 02-08-2005, 12:33 AM
snigg's Avatar
Quoted: 0 Post(s)
i got the manual in .pdf format. contact me and ill send it to ya
here is a screenshot of the fuel pump page.
snigg is offline
post #6 of 8 (permalink) Old 02-09-2005, 05:47 PM
yllw929NC's Avatar
Quoted: 0 Post(s)
Check the switch itself and the harness connection.
yllw929NC is offline
post #7 of 8 (permalink) Old 02-10-2005, 09:13 AM Thread Starter
Superbike Champion
ncpartsguy's Avatar
Quoted: 0 Post(s)
It's fixed! Thanks to everyone that offered help.
It was the damn ignition switch!!! I didn't know that if the ignition switch went bad, EVERYTHING would work EXCEPT the fuel pump. Isn't that a load of crap?!?!?!
post #8 of 8 (permalink) Old 05-05-2016, 05:45 PM
SBN Newb
Quoted: 0 Post(s)
did your light not function when you where having this issue
lalondj is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
Refbacks are Off
