RacerPartsWholesale
MotoGiya.comRacerPartsWholesaleMotorcycle.com Classifieds!SumOfAllParts.netKomodoGear.comSportbikeTrackGearArnottAirRideAdvanstarMotorcycleShowsSpringfield ArmoryCheapCycleParts.comSoloMotoPartsNice CycleSee your ad here!
Old 10-14-2004, 01:14 PM   #1 (permalink)
GsxrBots
GsxrBots's Avatar
Sportbike: 2002 Gsxr 1000
GsxrBots has disabled reputation
Default Wiring Diagram Ninja 250
Anyone have a wiring diagram for a 250 Ninja in pdf format or anything? I need to trace power from the coils to find out why there's no spark. Thanks a bunch!
GsxrBots is offline   Reply With Quote
Old 10-14-2004, 02:36 PM   #2 (permalink)
stoinkythepig
Sportbike: 2001 ZX9R, 1992 Bandit 400, 1986 Concours
stoinkythepig is on a distinguished road
Don't have a diagram (anymore) but can assure you the wires go directly to the "igniter" a small black box that provides a switched DC signal to the coils based on data (simple pulses) it gets from the pulsing coil down by the crankshaft. The igniter adjusts the ignition timing based on engine speed. If you have no spark, it could be the ignitor, the pulsing coil, the fuse/junction box, a fuse, the ignition switch (though if it were that or the fuse, you'd likely not get any cranking either). The most commonly failed item is the pulsing coil. Check the pulsing coil with an ohm meter. If it reads infinity, it's bad. They are not too expensive or difficult to replace.
stoinkythepig is offline   Reply With Quote
