SportbikeTrackGear
CycleGear.comCheapCycleParts.comKomodoGear.comSportbikeTrackGearSportbikeTrackGearNice CycleMotorcycle.com Classifieds!WilzGarageAnnitori DistributingHardRacing.comSumOfAllParts.netSee your ad here!
Old 10-11-2004, 05:57 PM   #1 (permalink)
joeitalyuf
Sportbike: 2002/suzuki/gsxr600m
joeitalyuf is on a distinguished road
Default huge problems
well, my battery died about a week ago.... like a complete fool... i got impatient and instead of going to get the battery charged i decided to jump it with my car (honda prelude)... of course it didnt start... i then decided to jump it with my friends bike which of course did not work either... today i just put a brand new battery in it to see what would happen... the lights and the tach all lit up... however, when i flipped on the run switch i did not hear the fuel injectors engage... did i fry my wiring? what is the next step i need to make... i am so frustrated with all of this... if anyone could lend a hand or give me some freaking direction if would greatly appreciate it...
best regards,
joe
joeitalyuf is offline   Reply With Quote
Old 10-11-2004, 07:23 PM   #2 (permalink)
HalfLiterBeater
Duct Tape Engineer
HalfLiterBeater's Avatar
Casino Cash: $4349
Sportbike: 07 Kawi ZX6R, lime green
HalfLiterBeater is on a distinguished road
I don't own a fuel injected bike man.....but my first step would be to check and inspect all of your fuses and relays. You may have just popped a fuse to the injectors.
FYI: The sound youre hearing shouldnt be the injectors engaging, but rather the pump priming itself to build pressure in the fuel system for when you crank the bike and the injectors fire. That's assuming bike fuel injection is similar to efi on a car.
"I smell blood and an era of prominent madmen"- W.H. Auden
The dead list: 04 EX500(sold), 98 VTR1000F(traded in)
07 Kawasaki ZX6R-Opened exhaust valve, Jumper mod, de-screened stock air filter, -1/+1 sprockets, green EK chain, ZG smoked double-bubble , solo cowl, Scorpio alarm.
HalfLiterBeater is offline   Reply With Quote
Old 10-11-2004, 08:30 PM   #3 (permalink)
mysubaruimp
Ducati Eater
mysubaruimp's Avatar
Sportbike: 2003 Aprilia Mille
mysubaruimp is on a distinguished road
Yes, it should be the fuel pump you are hearing, the injedtors run pretty quiet.
I second the notion of you checking your fuses, The way you describe it doesnt really sound like a dead battery. You could also go through and check all the connections, maybe one has wiggled loose.
mysubaruimp is offline   Reply With Quote
Old 10-11-2004, 08:30 PM   #4 (permalink)
mysubaruimp
Ducati Eater
Oh, and make sure your kill switch is not pushed in
Old 10-11-2004, 08:48 PM   #5 (permalink)
HalfLiterBeater
Duct Tape Engineer
Casino Cash: $4349
Not to mention fuel injectors don't prime cylinders. They don't fire until they get the signal that the engine is cranking over. Not to distract from the topic at hand or anything.... Just post-whoring so I can get a colored username.
Old 10-12-2004, 01:55 PM   #6 (permalink)
bollars
Sportbike: 99 ZX6R
bollars is on a distinguished road
Hope you had your car off when you were jumping the bike. I heard you will fry the ignition if your car is running.
bollars is offline   Reply With Quote
Old 10-12-2004, 02:19 PM   #7 (permalink)
mysubaruimp
Ducati Eater
I heard, no you wont.
Old 10-16-2004, 06:07 PM   #8 (permalink)
kdk1899
Sportbike.net junkie
kdk1899's Avatar
Casino Cash: $3686
Sportbike: '04 Yamaha FZ6
kdk1899 is on a distinguished road
Blue Token: SBN Blue Token - Issue reason:
Well which is it???
Fazr6's Fender Eliminator (Thanks Mike!)_____PCIII usb (Thanks Doug!)_____Speedohealer_____ Dual Headlight Mod_____Cheetah Alarm sys_____15 Tooth JT Front Sprocket_____BMC Air Filter_____Gel Pad installed_____My CAT eliminator.(The first homemade one for the FZ6!)_____FS6 Frame Sliders
[*url=http://www.sportbikes.net][*IMG]http://www.signaturebar.com/uploads/images/25988.jpg[*/IMG][*/url]
kdk1899 is offline   Reply With Quote
Old 10-16-2004, 06:35 PM   #9 (permalink)
mysubaruimp
Ducati Eater
Originally Posted by kdk1899
Well which is it???
Well, a bikes battery is 12 volts, a cars battery is 12 volts. So in that statement there is no argument, right? everyone agrees.
So if both bike and car are off, it will be fine because they are at the same voltage.
A bikes charging system charges at upwards of 14volts. (different bikes vary +/- 1 or 2 volts, then vary even more if under load or not.)
A cars charging system charges at 14.4 volts.
There is only .4 volts difference. If I farted into the wind I could make .4 volts from the static. The difference isnt enough to make a difference. There should be no argument here.
A bike has an ampacity off the alternator and battery of about 45 amps (again, varies by bike).
A car has an ampacity off alternator and battery of 60 amps (varies by car).
This difference in ampacity is big. But, it doesnt matter. Ampacity is dependent on resistance (things turned on). If your car was putting out 60 amps all the time, every wire in the car would catch on fire from the heat, same in a bike. They dont put out maximum amperage unless the car is calling for it (stereo bumpin, high beams on, wipers on, defroster on, etc.)
So if you hook up your bike to a car, it isnt going to get a zap of 60 amps through everything. It will only get what it needs.
Even if it did get a zap of 1000 amps and 5000 volts, you have a main fuse that would blow before any damage was done. The only thing you would damager is the battery, because you are hooked up to it directly. And even if that were to happen, the battery wouldnt get damaged because two batteries can run like that, even if different voltage/amperage ratings.
Old 10-18-2004, 02:45 PM   #10 (permalink)
Casket Crew
'is not amused....
Casket Crew's Avatar
Sportbike: ...........
Casket Crew is on a distinguished road
LOL funny story... We once jumped a bike with a truck and it blew out the headlight (like no shit blew out the glass and everything) and a mess of other stuff man it was funny as hell!
Casket Crew is offline   Reply With Quote
Old 10-18-2004, 03:50 PM   #11 (permalink)
mysubaruimp
Ducati Eater
What kind of bike?
Old 10-18-2004, 03:54 PM   #12 (permalink)
mysubaruimp
Ducati Eater
Ive been sitting here trying to figure out why that would happen, becuase logically, and technically, it cant.
Two things- Was it a really old 6 volt bike? (I am 99% sure I know the answer, but had to throw it out there)
I am 99.99% sure you must have had the jumper cables on backwards on one battery. It is the only way this would have happened.
Neg goes to Neg, Pos to Pos. Sometimes (I have seen it) jumpers break, and people need to reattach the ends. They then swap them on accident, meaning if you put red to red, black to black, It wont be right. When you do that it makes the voltage 24v DC instead of making the amperage capacity higher. When you double the voltage on dc stuff, most of the time it doesnt like it, just as your story told.
Old 10-18-2004, 04:50 PM   #13 (permalink)
Casket Crew
'is not amused....
What kind of bike?
400 bandit
Old 10-22-2004, 07:14 PM   #14 (permalink)
cruiser
cruiser's Avatar
Casino Cash: $16382
Sportbike: 91 Honda 750 Nighthawk / 06Honda VTX1300C
cruiser is on a distinguished road
Silver Token: SBN Silver Token - Issue reason:  Yellow Token: Yellow SBN Token - Issue reason:
Total Awards: 2
you could have a bad kill switch
cruiser is offline   Reply With Quote
