what jes is referring to is this situation when DOT 5 and DOT 4 or 3 are mixed.
http://www.belray.com/consumer/Q&A%20pages/q&abf.html
DOT 4 VS. DOT 5 Silicone Coagulation
Q: Sir Tech,
I bought a 1987 Harley-DavidsonÆ Sportster and I recently removed the front brake master cylinder cover to find a bunch of thick gunk inside. What happened and what should I do?
A: If you own a Harley-Davidson®, think purple! Your H-DÆ motorcycle came stock from the factory with DOT 5 silicone brake fluid and part of the regulated requirements for DOT 5 silicone is that it be purple colored so as to stand apart from the ever so popular DOT 3, 4 or 5.1 brake fluids which are glycol not silicone. Apparently, your hog’s previous owner was more concerned with his tattoos turning green than with his brake fluid being purple and most likely added some DOT 3 or DOT 4 brake fluid to the system. This is a big no-no, bad boy! What happens when you introduce DOT 3, DOT 4 or DOT 5.1, all glycol based fluids, to DOT 5 silicone, which is obviously silicone based, is coagulation! The fluid will clot and, as you so eloquently described, form “thick gunk”. My advice to you is to consult a qualified technician. After all these are your brakes we are talking about! Have him fully flush the brake system and replace all the rubber parts with new ones and then go back to DOT 5 silicone brake fluid. If you do not re-build the master cylinders and calipers or replace all the rubber parts, there will most likely be remnants of the glycol in the rubber which will cause the problem again. To avoid "thick gunk" in your shorts due to grabbing the brakes and not impeding forward velocity, I recommend you heed my advice with the utmost seriousness and expedience.
