Originally Posted by jeostang
What kind of rider experience so you need to do a track day? Does your bike need to be setup any special way? I live in the DC metro area and I don't thing there are any tracks around here but drag strips.
Summit Point. It is an hour away. You generally need to be able to ride your bike smoothly. Beyond that, it depends on the org running it. NESBA is a good place to start and others do run track days out at Summit. Two circuits are active (Main and Jefferson) and a third on the way (Shenandoah).
NESBA is the easiest to run and you can do it in jeans (I do not recommend this). They swap between Jefferson and Main. A lot of track days tend to be run on Jefferson. Shorter circuit, fewer turns. The Main circuit is awesome but challenging.
Bike prep is pretty easy. Most groups require the following:
- Mirrors removed
- Lights taped over (preferably with turn signals removed)
- Oil drain bolt safety wired (not all groups require this, good idea though)
- Coolant replaced with water or a legal coolant (check the org, some allow Engine Ice or equivalent, others allow water only)
- Centerstand removed or tied up
- Sidestand removed or tied up
You can go further. As you move up into the more advanced track days, you are required to bring a bike more and more prepped towards racing. Many advanced groups in a track day require a race-prepped bike that would pass race tech. For new track riders, the list above is usually sufficient.
Check with the local shops and groups in the area. Track days run into the Fall. I highly recommend you check out the circuit beforehand just to get a feel for it. Fun way to spend a day. Cornerworking is another way to ease into track riding as it gives you an inside view of how racing is run (plus cornerworkers get some nice perks and discounts on schools).
One piece of advice: Don't bring a bike to the track you aren't ready to repair or lose. It is not uncommon for new riders pushing themselves on the track to dump their bikes. I know someone who did it recently. It happens. Just be prepared for the possibility. It's why I haven't ridden the track yet.
