Just a little work - Sportbikes.net
Sponsored by: TCX Boots
Old 01-10-2013, 11:07 AM   #1 (permalink)
Hyena
Gameroom cash: $1335
Sportbike: 1994 Honda CBR 600
Hyena is on a distinguished road
Default Just a little work
Hey everyone! I picked up a bike last week. A 1994 Honda CBR 600. I know this goes against all the advice provided by you lot, but it was a good deal and the transaction went smoothly, which is more than I can say for the other sellers who gave me the run around. I understand that if something were to happen, it would be on me.
I spotted a stain. OIL!
So I decided I'd look for the leak. This is where I am now.
I can't remove the fairing completely 'cause the allen bolt under the shifter is stripped and I can't get it out.
I've decided to turn this into a mini project. Find the leak, fix it, change spark plugs, change oil & oil filter, and check valve clearance while I'm in there.
I have yet to find the leak... All this motorcycle stuff is new to me. Not really sure how to go about it but here is what I found so far.
Some kind of gunk in airbox... Should I be worried?
Also, there may be rust in the gas tank. Seems there is some rust residue on petcock. Kinda hard to see. I'll update with a pic of inside gas tank after I drain it fully.
Hyena is offline   Reply With Quote
Old 01-10-2013, 12:13 PM   #2 (permalink)
Hyena
Here is the inside of tank.
Old 01-10-2013, 01:47 PM   #3 (permalink)
Hyena
AHA! Found the leak. Now, what exactly am I looking at....
Old 01-11-2013, 04:29 PM   #4 (permalink)
malik ross
Already Sick of Winter
malik ross's Avatar
Gameroom cash: $46919
Sportbike: 1998 Kawasaki ZX9R for the street and a 2006 GSXR 600 for the track
malik ross is on a distinguished road
the tank needs to be cleaned. if that varnish breaks lose it will clog the fuel filter (if the bike still has one) and if it passes the filter get into the carbs. since the tank and airbox is off you might as well pull the carbs and clean them too. my guess is the carbs are in just as bad as the tank if not worse.
the leak? i have no idea where it is coming from and can't get good enough reference from the photo posted. additionally the leak my be from somewhere else and seeped and settled where you see the most of it. give the entire engine a good degreasing and spray talcum foot powder on the outside. it will show where the leak is coming from after it has sat for a bit.
a service manual is your friend. they can be found on the internet with some looking. no, i'm not going to look for you. if may be a simple engine cover gasket or something bigger.
good luck.
malik ross is offline   Reply With Quote
The Following User Says Thank You to malik ross For This Useful Post:
Hyena (01-11-2013)
Old 01-11-2013, 04:45 PM   #5 (permalink)
jeffo8
jeffo8's Avatar
Gameroom cash: $6209
Sportbike: 1987 yamaha fz 600
jeffo8 is on a distinguished road
here is a manual
https://dl.dropbox.com/u/76073625/Ho...e%20Manual.pdf
here is a repair course
Motorcycle Repair Course
+1 to the tamk cleaning, carb cleaning, and bike washing/degreasing,
Stand on Zanzibar
jeffo8 is offline   Reply With Quote
The Following User Says Thank You to jeffo8 For This Useful Post:
MegaManX (01-14-2013)
Old 01-11-2013, 05:27 PM   #6 (permalink)
Hyena
I think I found the leak. Seems it's the cover gasket. Leak was at bottom of clutch/alternator cover. Leaked onto hose pictured. Ordered gasket and now just have to wait.
Carbs are also out and ready for cleaning.
How would I go about cleaning the gas tank? Also, would you recommend I replace the fuel filter? Where would I find a fuel filter? Would places like Autozone or O'reilly carry them?
Thank you for the replies by the way.
Old 01-11-2013, 08:20 PM   #7 (permalink)
serpentracer
the joke is in your hand
serpentracer's Avatar
Gameroom cash: $80599
Sportbike: 2003 yamaha R6
serpentracer is on a distinguished road
auto parts stores don't typically sell motorcycle stuff besides spark plugs and batteries. if you need gasket sealant I love the ultra gray made by permatex. it's a high torque sealant for japanese engines. works way better than any of there other stuff.
Gasket Makers : Permatex® Ultra Grey® Rigid High-Torque RTV Silicone Gasket Maker
a dealer (will be very expensive) or online (my prefered method) is about your only options.
mr.cycles.com is a very good and usually cheap place to get stuff from.
however if you want a headache from using their awful website ronayers.com is almost always the cheapest place to get oem parts.
The Following User Says Thank You to serpentracer For This Useful Post:
mfromphilly1 (01-17-2013)
Old 01-11-2013, 08:59 PM   #8 (permalink)
Hyena
Thanks serpent. Seems the fuel filter is internal on this bike. The petcock also has a little varnish on it. Can I just scrap this off with something?
Old 01-12-2013, 09:34 AM   #9 (permalink)
serpentracer
I don't know. I believe there are some tank cleaning products on the market.
I've never had to use any before.
Old 01-12-2013, 05:30 PM   #10 (permalink)
Hyena
Found some stuff. Milk Stone Remover. Says to mix 50% with water. Should I fill whole tank, half way, etc?
I've removed the float bowl covers on the carb to clean them. Took gaskets off them so I could dip in carb cleaner solution. My question is, can I use the same gaskets when putting the covers back on carb? Will I need some kind of sealant?
Also, petcock cleaning. How would I go about this? Seems to have a little varnish on plastic pieace that goes into the gas tank.
Old 01-12-2013, 07:02 PM   #11 (permalink)
Hyena
I got carb cleaner on some rubber... Is it ruined?
Old 01-12-2013, 07:43 PM   #12 (permalink)
OldSchlPunk
Are we not men?
OldSchlPunk's Avatar
Gameroom cash: $83077
Sportbike: 02 F4i
OldSchlPunk is on a distinguished road
You should use new carb gaskets, fuel leaks are not worth it.
What does the package say about contact with rubber? I doubt it's ruined, but check the package to see what the mfg says.
For as dumb as you are, even you will remember this. - Lee Ving/ Fear
Ever feel you've been cheated? - Johnny Rotten
OldSchlPunk is online now   Reply With Quote
Old 01-14-2013, 02:17 AM   #13 (permalink)
Hyena
There was nothing on package about making contact with rubber or plastic. Seems it's not a huge issue.
This turned into a bigger project than I expected. Can't wait to have her back together and running!
Old 01-14-2013, 10:10 PM   #14 (permalink)
serpentracer
shit like that always does man, it always does. and no point on skimping while you got it apart. do it right once or do it many more times.
The Following 4 Users Say Thank You to serpentracer For This Useful Post:
jeffo8 (01-14-2013), mfromphilly1 (01-17-2013), scythe08 (01-17-2013), yup (01-19-2013)
Old 01-15-2013, 12:02 AM   #15 (permalink)
Hyena
There is a lot of sealant gunk just under the flywheel. I need to get the flywheel out to properly clean it out... and therein lies the problem. I simply CANNOT get the nut in the middle of the flywheel to turn. Manual shows a special tool being used. I've looked online to see if I could order it and no luck. I've been to every auto parts place in the area and they don't carry flywheel holders. I'm going to try Harbor Freight in the morning.
If I have no luck there either, how do I go about this? I've seen a couple youtube videos on the subject. One involves turning the engine to the compression stage and jamming shoelaces into the spark plug opening to stop the engine from turning. The other involves jamming a screw driver into the flywheel to keep it from turning. Neither of these is something I'd want to do... Are my options so limited?
People that work alot, how do you balance work and riding? shiro23 General Sportbikes 45 04-04-2007 07:44 AM
my work said i can't ride to work. mgranzow General Sportbikes 51 05-08-2004 02:37 PM
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
