Does tire size affect sag? - Sportbikes.net
Sponsored by: TCX Boots
User Tag List
post #1 of 17 (permalink) Old 12-26-2012, 11:42 PM Thread Starter
Quoted: 0 Post(s)
If I change from a 190/50 rear to a 190/55 rear, will my sag change to a point that I need to reset it..or should I be happy and leave it alone assuming its dialed in.
espacef1fan is offline
post #2 of 17 (permalink) Old 12-26-2012, 11:52 PM
Mediocre Strafer
Quoted: 0 Post(s)
Yes. It's pretty minimal, but it does. You're throwing weight forward, so the rear sag will be a bit less and the front a bit more.
For example, in a Q2 the nominal rear diameter is 25.32 vs 24.95". So .37" in diameter = .185" radius, or 4.7mm of height at the axle.
I'd get used to the new tire behavior before I fooled with it, personally. After running a 190/55, I'll never put a 190/50 on a bike again.
KeS
kevin_stevens is offline
post #3 of 17 (permalink) Old 12-27-2012, 01:06 AM
Pit Bike Legend
stnkbg1's Avatar
Quoted: 0 Post(s)
Minimal would be correct if not an understatement. You're talking about a .7" difference in diameter, or .35" difference in actual height change. Minimal enough that I highly doubt you'd ever be able to notice the difference in weight shift or sag. The bike will handle differently, but more because of the different tire profile than the suspension settings.
Dallas Ashley
You crash 'em, we hack 'em.
stnkbg1 is offline
post #4 of 17 (permalink) Old 12-27-2012, 02:58 AM
After Me Lucky Charms
Shamrock627's Avatar
Quoted: 37 Post(s)
It will change ride height more than anything. KeS is correct.
Shamrock627 is offline
post #5 of 17 (permalink) Old 12-27-2012, 06:02 AM Thread Starter
Quoted: 0 Post(s)
Thanks! I kinda figured that it changed it..but that it didnt really matter on a practical matter. However I lack working knowledge/practical experience with motorcycle suspension setup so that's why I made the thread(that and a search came up empty)
post #6 of 17 (permalink) Old 12-27-2012, 06:45 AM
Cheap Bastid
OreoGaborio's Avatar
Quoted: 0 Post(s)
No more than if you took a big dump.
-Pete
LRRS/CCS #82
(RiderCoach),
(Assistant Chief Instructor)
| Pine Motorparts/PBE Specialists |
OreoGaborio is offline
The Following User Says Thank You to OreoGaborio For This Useful Post:
ADR3NALINE FIX (12-27-2012)
post #7 of 17 (permalink) Old 12-27-2012, 08:29 AM
King of the Hopeless
Claudius's Avatar
Quoted: 3 Post(s)
The tire diameter does change ride height and geometry - but I am not so sure that it changes "sag" / preload. Let me explain. Basically when you set "sag" you are setting the preload adjusters on your bike to change the suspension range or travel. Changing preload has the secondary effect of raising or lowering your bike to fit in that desired range. It does not effect the spring rate or your compression or damping settings on most bikes.
If the tire you use increases in diameter, it changes the measured relationship between your wheel axle and the ground - which could make the bike "taller" by a couple of mm. However, it has no effect on the suspension range and preload settings - which are essentially adjusters that put more or less pressure on the springs inside the fork legs and typcially outside of the rear shock. The tire "height" has no appreciable effect on preload at all.
What tire hight does do, is change the ride height of your bike. This could potentially, relating to the changes of the tire height on your bike before you change tires, change your geometry - making your bike turn faster or slower or minimally effecting rake, trail, and squat / anti squat properties. Thus, to make up for these changes, you would want to either raise or lower your fork legs and or adjust your rear suspension linkage or ride height adjuster in the back of the bike to maintain the same geometry you had before the tire change.
Sag/ Preload does effect the ride height of your bike - but in a way that does not change the height of the wheel axle off of the ground. What you worry about when changing tyre brands or models is a change in geometry in your bike. Sag only changes the ride height as a secondary characteristic of varying the suspension stroke / range.
Claudius is offline
The Following 2 Users Say Thank You to Claudius For This Useful Post:
PCHbreeze (12-27-2012), Scissors (12-31-2012)
post #8 of 17 (permalink) Old 12-27-2012, 11:47 AM
Mediocre Strafer
Quoted: 0 Post(s)
Yeah, I kind of glossed over a step. The tire change doesn't affect your sag directly - it raises the rear axle and ride height slightly. THAT throws weight forward and thereby increases sag in front and reduces it in rear. Thanks for clarifying.
KeS
post #9 of 17 (permalink) Old 12-27-2012, 04:42 PM Thread Starter
Quoted: 0 Post(s)
KeS
This is what I envisioned when asking the question.
I am aware of the geometry change, that is an added benefit to the change..I'm primarily doing it for the better tire profile.
post #10 of 17 (permalink) Old 12-27-2012, 09:13 PM
Quoted: 37 Post(s)
Son of a gun, you must be loaded with poop!
post #11 of 17 (permalink) Old 12-28-2012, 12:35 AM
Cheap Bastid
Quoted: 0 Post(s)
Loaded? I'm FULL OF IT!
-Pete
LRRS/CCS #82
(RiderCoach),
Shamrock627 (12-28-2012)
post #12 of 17 (permalink) Old 12-28-2012, 02:47 AM
Quoted: 37 Post(s)
the hardness of a sidewall can affect sag, as well, can't it?
post #13 of 17 (permalink) Old 12-28-2012, 03:11 AM
Quoted: 0 Post(s)
Technically not as spring sag is simply the difference in spring length between loaded and unloaded. Will it possibly have a impact on overall suspension performance yes although for the average road rider even an enthusiastic one its probably not worth any serious consideration.
Nero Diablo is offline
post #14 of 17 (permalink) Old 12-28-2012, 07:51 AM
Quoted: 1 Post(s)
can you set the suspension up while on stands? or do you have to have 3 people to set it up.... was reading a bit about it a while back and it sounded like you needed the rider, a person to hold the bike upright (since the rider has feet on pegs to be "race-like") and another person doing all the measuring.... please enlighten me since i would love to set mine up before the next track day.... i have plenty of time til that happens but oh yes... it WILL happen.
If you're gonna go, go with a smile!!
2012 ZX-14R in Blaze Green.
USAFgsxr750again is offline
post #15 of 17 (permalink) Old 12-28-2012, 11:42 AM
Claudius's Avatar
Quoted: 3 Post(s)
It depends what you mean by using stands. Normally to set sag you need to take a series of measurements based upon the loaded and unloaded height of the suspension of the bike. Remember that you are measuring from two points on the bike - not from the ground. Sag is set by "preloading" the suspension so that it does not top out or bottom out the suspension. When you do this you can have the secondary salutory or negative effect of changing your geometry.
So, no, I don't think you can or should use stands to set sag. My instinct is that raising or lowering the front or rear of the bike while setting sag will screw a bit with your measurements - which can be small and are effected by stiction / friction in the forks and shock. I get the idea though that you want to use the stands so that you don't need people to hold the bike up.
So, sure you could change the adjusters while the bike is on stands - but I don't think it would be a best practice to do this on stands.
I think what Kevin was trying to say earlier by the way, is that suspension adjustements have primary effects and often also have secondary effects that change based upon what adjustement you are making and what kind of bike / quality of suspension you have. (Sorry Kevin, I don't want to speak for you - but I think that this was part of your point.)
Claudius is offline
kevin_stevens (12-28-2012), Scissors (12-31-2012)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
will going to a 190 tire affect my 600? sweetnsauer General Sportbikes 19 07-12-2010 09:50 AM
Does tire size affect wheelies? T-RO Stunterz Corner 6 04-19-2002 11:12 PM
How will going from a 120/60 to a 120/70 front tire affect handling? bgilly General Sportbikes 14 09-23-2001 06:10 PM
You may post new threads
You may post replies
Refbacks are Off
