12-11-2012, 03:42 PM
#1 (permalink)
Superbike Champion
Bike Needs a Battery I Think
I don't ride my bike as much as I would like to, so the bike sits for a week or 2 at a time occasionally. Needless to say, I had to ride it the other day and the battery was dead so I push started it and popped the clutch. Then I went for a 30 minute ride, thinking that maybe the stator (right?) would charge the battery back up. So i got off the bike, went to class, came back, and it barely gave me anything when i tried to start. It gave me maybe 1 full second of an effort and then NOTHING. So i had to push start it again. Rode for an hour and then took the battery off to be charged for 10 hours. The battery now has a full charge, but I'm going to load test it this weekend to check the voltage. Only thing is, I can't check cranking amps with a load test and I was wondering if the load test is pointless and if I should just get a new battery instead...
If i do get a battery, I have no idea which to get. The battery only has one marking on it. It says 'BS' on the side of it. No other codes or ANYTHING. How do I figure out which battery I need? Do i need to measure the battery or are motorcycle batteries specific sizes depending on the type? I've done a little searching around and am not getting the answers I need.
Thanks in advance guys.
P.S. - Somebody told me its not good to push start my bike. Is that true? I don't plan on doing it again, I just needed to do it a few times bc I was in a pinch
12-11-2012, 03:55 PM
#2 (permalink)
I think you just need to ride more and don't worry about the battery until *if* it dies again, then buy a new battery.
RIDING IS FREEDOM inked on my arm.
12-11-2012, 04:23 PM
#3 (permalink)
World 500 GP Racer
In your circumstance, this battery is aptly marked.
When Life Gets Hard, Play Harder.
The Following User Says Thank You to UltimateOG For This Useful Post:
12-11-2012, 04:49 PM
#4 (permalink)
Sounds like you need a new battery. After a while they just don't hold a charge any more. Even if you do get it charged it may only hold for a week or a few days. New batteries are not usually more than $100 or so. Call around to auto parts stores and just tell them you need a battery for year/make/model bike that you have and get quotes for the best price, that will save you from driving all over the place. Also there is nothing at all wrong with push starting, other than it being a pain in the ass and embarrassing.
12-11-2012, 06:49 PM
#5 (permalink)
Check your charging rate too !!!!
12-11-2012, 08:58 PM
#6 (permalink)
Umbrella Girl
I would buy a volt meter, $5ish, to check the battery first.
The Following User Says Thank You to iquack08 For This Useful Post:
12-11-2012, 11:11 PM
#7 (permalink)
Gameroom cash: $40041
Sportbike: 1994 1100 Sport Moto Guzzi,MGS-01
Most battery manufacturers have a fitment list either in a book or online plug in make and model comes out with recommended products from that manufacturer.
ie here Yuasa Batteries :: Motorcycle
Odyssey Drycell Motorcycle Batteries
A true load test will check cranking amps, a voltmeter across the terminals won't tell you much.
However if you want a basic guide a good but flat battery will read around 12-12.2 volts across the terminals a fully charged battery will be around 12.4-12.6 volts. Anything below 12 suggests it has dropped a cell or is about to. For a basic load test you can put a volt meter across the battery and take note of what the reading is then turn the headlights on even with a flat battery the voltage should only drop about 0.2-0.4 volts. If it dumps down to a number with anything that starts with an 11 if its really bad a 9 the battery is dead and you need a newy.
Although as I said this is a basic guide you can preform with a multimeter/voltmeter the definative answer will be a load test which most battery retailers will do for free.
The Following User Says Thank You to Nero Diablo For This Useful Post:
12-11-2012, 11:50 PM
#8 (permalink)
Batteryplus.com
Sent from my iPhone using Motorcycle.com Free App
12-12-2012, 01:53 AM
#9 (permalink)
Superbike Champion
Great info thanks guys
12-12-2012, 07:26 AM
#10 (permalink)
World Superbike Champion
GET A BATTERY TENDER!!! It'll solve most of your future problems. while i have owned/used one, never had a battery go bad. the longest i've had the stock battery in any of my bikes was the Busa... 5 years... then i sold the bike. grrr. i seem to have bike adhd
If you're gonna go, go with a smile!!
2011 GSXR 750 blue/white - mods slowly addin up
The Following 3 Users Say Thank You to USAFgsxr750again For This Useful Post:
12-12-2012, 07:40 AM
#11 (permalink)
Batteries are very fragile today
Tenders are a must if its sitting much
12-12-2012, 07:56 AM
#12 (permalink)
Gameroom cash: $13018
Sportbike: 1995 Ducati 916; 2002 Ducati M750Sie
I use a battery tender when I park the bike every night. I have a Black&Decker orange one, it's very good at keeping the battery level.
These older Ducatis are famous for their bad charging systems, so I've done all the typical steps to take care of my battery, and I advice:
1-Get a voltimeter permanently connected to the battery terminals. This way everytime I ride I monitor how well the bike is charging, and I have an idea of how good is the battery before I ride. (Nero Diablo's numbers are good in my case)
2-NEVER push start it or attempt to start it when the battery is low. This could cause other, more expensive, electrical problems.
With your symptons, I'd say it's possible that your battery is ruined or going to be ruined soon, given that it has fallen too low. My old battery had this problem, and then I recharged it but it wouldn't hold charge due to a lack of water in it. I re-filled and re-charged and it worked fine, but this is a short term solution, in general.
However, not only would I check/replace the battery, but most importantly, get a multimeter and test your charging system. An R/R failure is not uncommon on vehicles that don't have a very reliable charging systems (read: sportbikes in general).
Do it like this: http://dl.dropbox.com/u/51669068/Duc...uc%20adobe.pdf
Or, here is some useful info, too: Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums (although, when he says that at idle battery voltage should be 13V+, that does not apply to MY bike; I don't know if it does to yours)
12-12-2012, 08:13 AM
#13 (permalink)
King of the Hopeless
Gameroom cash: $22596
Sportbike: Off in the Land of Yamaha.
This.
If you do have to replace it you should seriously consider one of the lithium ion batteries. They are lighter big time and tend to hold a charge well over time.
12-12-2012, 08:42 AM
#14 (permalink)
Spiffy...
Gameroom cash: $15462
Sportbike: 2007 Kawasaki 650r Ninja, 1991 KX 125
Push starting is not going to damage the bike physically, but like Uncal said, can cause electrical issues. The first one that comes to mind is an exploding battery. It is unlikely, but I've seen it before on a lawnmower; started it with a bad battery in it, using the pull starter. After a few minutes, boom.
My frame up 650R Ninja build.
Originally Posted by nidyanazo
...the largest and most knowledgable group of motorcycle assholes on the net!
 <---official SBN welcome sign
12-12-2012, 08:52 AM
#15 (permalink)
By the way, are you a member of any specific zx6 forums? That's always a good thing, to find a good brand/model specific forum.
You wouldn't believe how much wisdom I've found in the Ducati forum. My bike would not be running without it.
There, you can search/ask what battery is recommended for your bike.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
