Bike Needs a Battery I Think - Page 2 - Sportbikes.net
Sponsored by: TCX Boots
Old 12-12-2012, 10:06 AM   #16 (permalink)
kevinwilly
Habitual line-stepper
kevinwilly's Avatar
Gameroom cash: $117785
Sportbike: none :(
Originally Posted by Aerythus View Post
Push starting is not going to damage the bike physically, but like Uncal said, can cause electrical issues. The first one that comes to mind is an exploding battery. It is unlikely, but I've seen it before on a lawnmower; started it with a bad battery in it, using the pull starter. After a few minutes, boom.
Yeah.... this CAN happen. But it's pretty unlikely.
If you've gotten to the point of having to push start a bike, then it's because you need your bike and it's your only option.
Thus- if I'm in the situation where I need to push start my bike, I'd go ahead and do it every time. First option would be a jump start... but if you are by yourself with no cars around, then you can't do that.
Old 12-12-2012, 10:13 AM   #17 (permalink)
Aerythus
Spiffy...
Aerythus's Avatar
Gameroom cash: $15462
Sportbike: 2007 Kawasaki 650r Ninja, 1991 KX 125
Aerythus is on a distinguished road
Agreed. I've push started bikes many times before, and I will likely do it again. But I can say that I've never quite felt comfy riding with a questionable battery with my jewels resting right above the battery box after seeing one blow up
My frame up 650R Ninja build.
Originally Posted by nidyanazo View Post
...the largest and most knowledgable group of motorcycle assholes on the net!
<---official SBN welcome sign
Aerythus is offline   Reply With Quote
Old 12-12-2012, 10:17 AM   #18 (permalink)
UltimateOG
World 500 GP Racer
UltimateOG's Avatar
Gameroom cash: $16433
Sportbike: 05 Ninja 636
UltimateOG is on a distinguished road
Start wearing a boom proof cup?
When Life Gets Hard, Play Harder.
UltimateOG is offline   Reply With Quote
Old 12-12-2012, 10:34 AM   #19 (permalink)
Wayne's Striple
Superbike Champion
Gameroom cash: $3029
Sportbike: Triumph Street Triple R
Wayne's Striple is on a distinguished road
Most bike manufacturers use the smallest and lightest battery they can get away with, but really the heavy lead-acid batteries are stone-age for sport-bikes these days. A strong battery is the foundation of your motorcycle; if it won't start you can't ride it so spending a few extra bucks is well worth it. I got the Shorai extra-strong 18Ah lithium battery (only weighs a couple of pounds) and their battery tender which plugs into a cable to the 5-pin port on the battery ($250 total). Lithium batteries are a bit sluggish in cold weather (until cranking perks up the ions) so I got the stronger model than standard. Shorai says their battery can last 10 yrs with proper care.
Wayne's Striple is offline   Reply With Quote
Old 12-12-2012, 10:41 AM   #20 (permalink)
Aerythus
Spiffy...
Aerythus's Avatar
What kind of care and maintenance do those batteries require?
Old 12-12-2012, 11:02 AM   #21 (permalink)
NoobKid
Superbike Champion
NoobKid's Avatar
Gameroom cash: $1524
Sportbike: 2001 kawi zx6r
NoobKid is an unknown quantity at this point
A battery tender is next on my list! Question about that as well though. You guys know the wires that go from the battery and have a connector on the end to connect to the battery tender? Well mine are too short and I can't get them to slip under the tail, meaning that everytime I would need to charge it, I need to pop the seats off everytime. That's a pain. Does anybody know what gauge wire I can solder to the existing wire to make the connector a little longer to make it more convenient for me?
NoobKid is offline   Reply With Quote
Old 12-12-2012, 12:10 PM   #22 (permalink)
Kazairl
World Superbike Champion
Kazairl's Avatar
Gameroom cash: $6571
Sportbike: 07 ZX14 03 SuperHawk
Kazairl is on a distinguished road
A battery tender only flows about 1.25A. The Battery tender jr will do .75 amp. An 18 AWG wire will be plenty. You would probably be fine going even smaller.
Personally, I would just see what size wire the battery tender uses and get that.
Kazairl is offline   Reply With Quote
Old 12-12-2012, 12:28 PM   #23 (permalink)
Bird of Fire
Bird of Fire's Avatar
Gameroom cash: $13066
Sportbike: 2005 SV650S
Bird of Fire is on a distinguished road
Wat? The battery tender comes with its own connector. You screw the adapter directly to the battery terminals on your bike and route the pigtail end to somewhere on your bike that's easy to get to. The pigtail wire is like 2-2.5' long, plenty of length. Easy peasy.
http://batterytender.com/includes/la..._BT_Junior.pdf
Bird of Fire is offline   Reply With Quote
The Following User Says Thank You to Bird of Fire For This Useful Post:
mfromphilly1 (12-12-2012)
Old 12-12-2012, 12:32 PM   #24 (permalink)
kevinwilly
kevinwilly's Avatar
Sportbike: none :(
Go to the sears auto department (many times a separate building). They sell the die hard trickle chargers and their accessories.
one of said accessories is a 2ft pigtail with an in-line fuse. It's got the ring terminals on one end and the correct connector on the other. It's like 6 bucks, I think. Maybe 8.
Cheap, and MUCH better than the short-ass ones that come with the chargers. I have one on my BMW because the battery is absolutely BURIED on that thing. So I want that thing to stay good for as long as possible so I don't have to dig it out....
Also- most lithium motorcycle batteries are absolute crap. Some people swear by the Shorai ones, but I've heard SO many negative things about them that I'm not even thinking of getting close to buying one.
Old 12-12-2012, 12:35 PM   #25 (permalink)
kevinwilly
kevinwilly's Avatar
Sportbike: none :(
Most battery tenders that I have bought (I have three) have come with the 1' long ones. A guy at work bought a bike that I fixed up for him, and it came with the 2' one with a fuse- he didn't have a charger, so I took it from him.
I recently saw them at sears. They are cheaper than the battery tender brand ones, which they have at some motorcycle dealers... but again- not all of them are the long ones.
The normal ones are too short for MOST bikes, even when the battery is just under the seat. I hate them.
Old 12-12-2012, 02:31 PM   #26 (permalink)
Bird of Fire
Strange. I got the baby battery tender that I linked, and it has more than enough slack.
Old 12-12-2012, 02:48 PM   #27 (permalink)
kevinwilly
kevinwilly's Avatar
Sportbike: none :(
They must have started shipping those in the last couple years, then. I think the last time I bought one was like 4 or 5 years ago at LEAST.
Old 12-12-2012, 03:31 PM   #28 (permalink)
USAFgsxr750again
Gameroom cash: $5174
Sportbike: 2011 gsxr750
USAFgsxr750again is on a distinguished road
yeah, mine is was waaaay long, i had to loop it a bunch to get it to hang just how i want it. no worries now. then i got to add my electric gear hookup... now THAT wire is MF'in LONG. i actually have it come out near the front of the tank.
i soo love playin with electricity... always fun til the smoke escapes.... tough as hell puttin it back in.
If you're gonna go, go with a smile!!
2011 GSXR 750 blue/white - mods slowly addin up
USAFgsxr750again is offline   Reply With Quote
Old 12-12-2012, 03:56 PM   #29 (permalink)
Bird of Fire
Yeah mine I got from amazon when it was on some kick ass kind of sale for 20 bucks about a year ago. The pigtail has a little 25a or 30a fuse if memory serves. Also has alligator clips as well for a non permanent mount. Zip tied up the extra slack and ran it to underneath the storage trunk of the bike. Works great. Just checked on it last week and it's keeping my little sv company in the garage without issue.
Old 12-12-2012, 06:42 PM   #30 (permalink)
Nero Diablo
Gameroom cash: $39837
Sportbike: 1994 1100 Sport Moto Guzzi,MGS-01
Nero Diablo is on a distinguished road
I think you'll find its 2 amps 25-30 amps is a lot and usually the rating of the main fusible link on a bike if it has one.
Nero Diablo is online now   Reply With Quote
Did Heated Gear Kill My FZ6 Battery? And Battery Tender or New Battery? Pseudo-Fed FZ6 17 11-15-2010 05:16 PM
Is it the battery or the bike? T-RO Help Me Fix It 10 05-08-2010 11:34 PM
Should bike run without battery? GR78 Help Me Fix It 59 10-28-2003 03:09 PM
car battery and bike battery tilua Kawasaki Sportbikes 2 02-10-2002 09:37 AM
