Got this info from another forum and figured I'd share it with you guys (and girls).
1. Got to this website
Proxy List 1 - Proxy 4 Free - Protect Your Online Privacy!
2. Pick a IP address from a country that you don't think gets wsbk coverage (e.i. vietnam,)
3. Open up Internet Explorer. Click tools--internet options.
4. From the connections tab click on the Lan Setting Button
5. Check the box that says "Use Proxy Server for Lan"
6. Enter the IP address from the website and the port and click OK.
This will re-route your connection through a proxy server in another country. The WSBK website will "think" that you are in that country and allow you access to all the videos.
edit:
When you're done watching don't forget to uncheck "use proxy server for lan," Otherwise you will always be routed to the proxy server.
If the first IP you pick doesn't work, try another one. I was able to watch superpole, all the races, and all the interviews.
