How to bleed the cooling system - Sportbikes.net
Sponsored by: TCX Boots
User Tag List
post #1 of 15 (permalink) Old 09-26-2008, 09:38 PM Thread Starter
leanking's Avatar
Quoted: 0 Post(s)
Today I changed the oil and decided to top off the coolant reservoir. After everything was all put back together I took the bike for a ride and noticed a slight increase in operating temperature which I know can be caused by air in the cooling system. Then I realized that I didnt put the cap back on the reservoir and figured I got air in the system and I should probably bleed it out.
leanking is offline
post #2 of 15 (permalink) Old 09-26-2008, 09:42 PM
Superbike Champion
FazerRider's Avatar
Quoted: 1 Post(s)
i would like to know too.
FazerRider is offline
post #3 of 15 (permalink) Old 09-26-2008, 10:21 PM
Hardass!
beowulf2k's Avatar
Quoted: 3 Post(s)
If you have to bleed a system, there needs to be bleeder valves somewhere.
beowulf2k is offline
post #4 of 15 (permalink) Old 09-26-2008, 10:28 PM
Otto Man's Avatar
Quoted: 0 Post(s)
The cap not on the reservoir will not induce air into the system. The cap is there to keep the coolant in and dirt and other stuff that doesn't belong in there out. You "bleed" the coolant system by removing the radiator cap (At full operating temp for best results....not) when cold, starting it up, and letting it circulate for a few minutes. As the coolant circulates, when it flows to the rad cap, any air will come out the top. Put the cap on when you think she's ready, and you are ready to rock.
'05 ZX-10
'99 Honda SuperHawk996
'03 KTM 525EXC
Originally Posted by 94rf900r
you guys are crazy mothers and i hate to say it but your all gonna get wasted someday but i'm still game for some ridin.
Semper Fi
Otto Man is offline
post #5 of 15 (permalink) Old 09-26-2008, 10:34 PM Thread Starter
leanking's Avatar
Quoted: 0 Post(s)
thanks that helps
leanking is offline
post #6 of 15 (permalink) Old 09-26-2008, 11:40 PM
Part 3 begins
DaleCaliente's Avatar
Quoted: 0 Post(s)
Correct- same procedure as a car.
07 Ninja 650R 17K Miles (SOLD)
---> 04 Ninja 636 10K Miles (SOLD)
---> 05
1000 12K Miles (CURRENT)
DaleCaliente is offline
post #7 of 15 (permalink) Old 09-27-2008, 12:02 AM
World 500 GP Racer
tarosean's Avatar
Quoted: 0 Post(s)
depends on the car......
I have bikes and cars that require it to be bled through a bleeder valve (located near the thermostat)
tarosean is offline
post #8 of 15 (permalink) Old 09-27-2008, 12:04 AM
RayOSV's Avatar
Quoted: 1 Post(s)
I changed my coolant the other week and found out my bike has a coolant bleeder screw. Open the screw until coolant starts to flow out and all the air is out of the system. It seemed to work well although I still had to top off the expansion tank a few times after each heat/cooling cycle of running the engine.
RayOSV is offline
post #9 of 15 (permalink) Old 09-27-2008, 08:20 AM
Part 3 begins
Quoted: 0 Post(s)
I thought you were just supposed to slice a hole in the coolant line and then duct tape it when you finish???
---> 05
post #10 of 15 (permalink) Old 09-27-2008, 08:27 AM
World 500 GP Racer
Quoted: 0 Post(s)
DO not open the cap when at full temperature or you will get a facefull of coolant.
Veefer97 is offline
post #11 of 15 (permalink) Old 09-27-2008, 10:47 AM
Superbike Champion
xeony2k's Avatar
Quoted: 0 Post(s)
I think he wasn't saying that, but yeah you don't want to pull the rad cap when the system is hot.
The procedure is to heat the the system up and then let it cool down if you don't have a fancy bleeder valve. Open the cap and fill the radiator more after the system has cooled if needed... if you are bleeding out air, the level of coolant will drop. Repeat until the coolant level is constant. It can take a few times if you have lots of air in the system. Typically once is enough if even necessary for me, I refill slowly with a steady controlled pour.
xeony2k is offline
post #12 of 15 (permalink) Old 09-27-2008, 12:49 PM Thread Starter
leanking's Avatar
Quoted: 0 Post(s)
will I be able to read the actual coolant level by looking at the reserve tank or is there another place I should check the coolant level.
leanking is offline
post #13 of 15 (permalink) Old 09-27-2008, 01:17 PM
Part 3 begins
Quoted: 0 Post(s)
reserve tank should have notches.
---> 05
post #14 of 15 (permalink) Old 09-27-2008, 04:34 PM
Otto Man's Avatar
Quoted: 0 Post(s)
That's usually frowned upon because the duct tape only matches the body panels paint color if it's a silver bike. Who wants unsightly silver duct tape on their bike if it isn't silver?
'05 ZX-10
'03 KTM 525EXC
Semper Fi
Otto Man is offline
post #15 of 15 (permalink) Old 10-05-2008, 04:45 AM
Quoted: 0 Post(s)
Just talked to the service manager at a local shop. He told me that on most of the new bikes the temp sensor is at the top. And some of the bikes are haveing to go through quite a few cycles for the air to bleed out. Keep an eye on the overflow tank.
crash972 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
Refbacks are Off
